Old 08-16-2011, 11:58 PM   #101
KroAutomotiveInc
KroAutomotiveInc's Avatar
Re: 1964 gmc 1000
KroAutomotiveInc is offline   Reply With Quote
Old 09-01-2011, 02:59 AM   #102
KroAutomotiveInc
Re: 1964 gmc 1000
all finished up had some problems with the oil plug but i finally got it with a over sized self tapper and its all ready to fire back up
Old 09-01-2011, 03:05 AM   #103
KroAutomotiveInc
Re: 1964 gmc 1000
Old 09-01-2011, 05:16 AM   #104
KroAutomotiveInc
Re: 1964 gmc 1000
****ing boss
Old 09-06-2011, 11:50 PM   #105
KroAutomotiveInc
Re: 1964 gmc 1000
new paint on grill and repainted the GMC
first attempt no **** ups lol
Old 09-07-2011, 09:31 AM   #106
SulphuriousSam
SulphuriousSam's Avatar
Re: 1964 gmc 1000
Great progress! Wish I was moving at your pace I think I'll pick up the speed once mine's running and parked in my garage instead of a shop 30 minutes from the house!
Your truck is really coming together nice. Love how your engine turned out looking
1966 C10 LWB, 283, 3 on the tree (lots of work to do!) http://67-72chevytrucks.com/vboard/s...d.php?t=471348
2001 Suburban daily driver
2008 HHR (wife's ride)
SulphuriousSam is offline   Reply With Quote
Old 09-07-2011, 11:14 AM   #107
KroAutomotiveInc
Re: 1964 gmc 1000
Thanks man yeah mine is at my dads shop now it sucks having to go work on it and then driving home after you have for 5 or 6 hours but i hope to have it done soon still no e break cables the ones at napa dont work
Old 09-13-2011, 12:00 AM   #108
KroAutomotiveInc
Re: 1964 gmc 1000
Old 09-13-2011, 12:03 AM   #109
KroAutomotiveInc
Re: 1964 gmc 1000
new ammo can i want to buy for center console
Old 09-16-2011, 05:57 PM   #110
KroAutomotiveInc
Re: 1964 gmc 1000
Old 09-21-2011, 03:03 AM   #111
KroAutomotiveInc
Arrow Re: 1964 gmc 1000
Going to buy a Offy 4 bbl intake, Stove Bolt exhaust headers and a heat plate from http://stoveboltengineco.com getting a carb from my old man he has a few he could part with and to go with that ill make another exhaust with a cheery bomb.
Sick of this rodsucker i mean rodchester lol it has a vacuum leak somewhere in the carb its not anywhere.
Offy Intake $235
Stove Bolt Exhaust Headers $277
Heat Plate $30
Shipping $44
Exhaust Parts/Cherry Bomb $100
Hooking Up The Heat Plate $?
Jetting The Carb $?
Linkage $?
$686 Dollars Total
Planning to be around $800 before its all done.
Question for anyone who knows.
Whats the best way to hook up the heat plate?
With the linkage should i buy the offy linkage or is there a better one to buy?
Old 09-21-2011, 03:10 AM   #112
KroAutomotiveInc
Re: 1964 gmc 1000
After doing this i will be around $1800 dollars into the truck including the $500 for the truck itself o and all my hard work!
Old 09-21-2011, 11:10 PM   #113
bubba327
HOW long until spring??
bubba327's Avatar
Re: 1964 gmc 1000
The gasket set I bought came with two gaskets for the exhaust manifold to intake manifold.
I used the solid gasket meant for propane. The open gasket allows air flow up and around the stock intake, The offenhauser is just a flat surface on the bottom which you will see when it all comes apart.
If you are using headers I would think a cork gasket would probably be fine as you wont have the heat involved that you have with the hot exhaust gases
I used the 7448 Holley 2 barrel on a Clifford adapter plate and modified a 1" aluminum spacer plate to raise things up for linkage clearance
I kinda made my own linkageName:  IMG_3005.jpg
this is an old picture taken before I changed to hydro boost brakes
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-21-2011, 11:15 PM   #114
bubba327
bubba327's Avatar
Re: 1964 gmc 1000
Here is after the brake change I added a 1 1/2 spacer to raise the air cleaner above the brake canister. It works like a velocity stack, I had to increase the main jets sizing after raising it up.
Old 09-22-2011, 03:01 AM   #115
KroAutomotiveInc
Re: 1964 gmc 1000
hey thanks man that was a lot of good info!
Old 09-22-2011, 03:03 AM   #116
KroAutomotiveInc
Re: 1964 gmc 1000
found a few old cool pics of the body drop!
Old 09-24-2011, 01:47 AM   #117
Vernski
Re: 1964 gmc 1000
Hi Kro subscribed to your build you have amazing fab skills there I've never seen anything quite like this done to these trucks it's real cool. I have a 65 GMC 1000 LWB fleetside so this really caught my interest. You mentioned your thinking about changing you intake & exhaust, here is a link that might be of interest if you haven't seen it....Vernski
http://www.cliffordperformance.net/M...gory_Code=C250
Vernski is offline   Reply With Quote
Old 09-25-2011, 07:23 PM   #118
KroAutomotiveInc
Re: 1964 gmc 1000
Thank you yes these trucks are a little big to do a body drop on but i figured what the hell may as well try it has been very fun and one hell of a learning experience!
Old 09-28-2011, 12:00 AM   #119
KroAutomotiveInc
Re: 1964 gmc 1000
Rochester B idle vent valve
where can you get a new one of these anyone know?
Old 09-28-2011, 07:10 PM   #120
Rich 5150 69
Rich 5150 69's Avatar
Re: 1964 gmc 1000
http://www.carbkitsource.com/carbs/c...uck/index.html
here maybe,
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-29-2011, 12:17 AM   #121
FetchMeAPepsi
FetchMeAPepsi's Avatar
Re: 1964 gmc 1000
Subscribed. The progress from start till today is unbelievable. Great job!
FetchMeAPepsi is offline   Reply With Quote
Old 09-29-2011, 02:00 AM   #122
KroAutomotiveInc
Re: 1964 gmc 1000
hey thank you i love to hear from people who like it ive worked very hard on it and im so close to driving it yet so far away! i cant wait till im cruising down the road living the dream ive had since ive started
Old 09-29-2011, 03:19 AM   #123
KroAutomotiveInc
Re: 1964 gmc 1000
1969 dodge charger R/T full restore
Old 09-29-2011, 03:23 AM   #124
KroAutomotiveInc
Re: 1964 gmc 1000
one day i hope to have half the mind my uncle Kent has hes one crazy mother ****er he owns at life
Old 09-29-2011, 01:29 PM   #125
SulphuriousSam
Re: 1964 gmc 1000
Body work looks great! I'm not the biggest fan of those wheels...big n littles are great but those don't seem to fit the car
60-66 chevy trucks, 60-66 gmc trucks, body dropped
