#101 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Lil 307 that could....
I remember him talking about the Summit brand of heads, but I had not heard about the intakes or the pistons. Thanks for the info
#102 |
Thanks for good write up!
I've been looking through this thread carefully to find out what parts are needed. So I'll try to post links to find out if Im in the right direction and you might help me if I'm mistaken somewhere. Vortec 906 heads Summit Stage 1 Vortec intake Summit K1103 Cam Kit Cloyes double roller chain set Felpro head gasket Exhaust valves
Johnny G -----------Vehicles-------------- * Chevrolet C-10 Stepside 1962 * Audi A4 Avant Quattro TDI 2008 * Sachs Compact 50cc 1967 |
#103 | |
60-66 Nut
Those heads on ebay are the correct Vortec heads, but the seller doesn't have a very good feedback rating. Plus with the cost of purchasing those used heads, and if they need some work to be 100%, you might be better off with a set of new heads. Either new GM heads or possible the Summit Vortec heads.
Everything else looks good, except you should not need any exhaust valves, unless you just want to upgrade the stock Vortec valves. I believe this may be what you were looking for from 'Alex's Parts' These are the upgraded valve springs, retainers and locks that screamin_c10 used. http://www.alexsparts.com/valve-spri...d-flat-tappet/ Quote:
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 09-04-2013 at 02:12 AM. Reason: added info |
#104 |
Thanks Capt'n! Lets see what happens, I'll start to the small things, new plugs, adjust carb and ignition and be happy with my 307 for a while! There is other things to consider before going over the engine..
#105 |
![]() Join Date: Jul 2012
let her rip tater chip. it will prolly run ok!
#106 |
I did a tune up, points, etc. a couple of years ago. My 307 is running strong.
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
