#101 | |
Re: Classic Industries dash pad
#102 |
What's the difference in the $189 dash pad and the $289 dash pad offered by Classic Industries? The description says the same. Are they both by Dashes Direct?
#103 | |
Location: Where I come from, it's cornbread and chicken...
Chuck. |
#104 |
It was asked before, but I didn't see an answer. I have an '85 with a badly cracked dash, the vinyl is curled on the edges of the cracks. What can be done to get this smoothed out before I install one of your dash covers, Stitch?
#105 |
There are a couple of different ways to do it...you'll first need to knock the curled up edges off or down the the original level of the dash or lower...then you can fill the dash with bondo, fiberglass, expanding foam, or closed cell foam...I think the expanding foam works really good...once the expanding foam has cured, take a hacksaw blade without the handle and cut the excess off flush with the dash...
once the dash holes and cracks have been filled and leveled out, you may need to put a layer or 1/8" closed cell foam on the top and block sand it to smooth it even further... |
#106 |
#107 | |
Thanks for your information and services! |
#108 |
No problem and thanks for the compliments.
Posted via Mobile Device |
#109 |
![]() Join Date: Jun 2007
Anybody try one of these that Cheyenne Pickup Parts sells? They are foam covered with vinyl. I was at a swap meet about 2 or 3 years back and a guy there had a really nice 87 short bed truck for sale. I started talking to him about it since he said it was an unrestored survivor truck from the Arizona desert. He told me that the only thing that he had to replace after he bought it was the dash pad since it had cracked over time like they all seem to do. I asked if he had replaced the original with a GM pad since it looked really nice and I couldn't tell at first that it had been replaced since it wasn't wavy or seem to have the problems normally associated with aftermarket pads.
He told me no, that it wasn't a GM piece, and that he had bought one of these from Cheyenne, and was very pleased with it. He told me that if I looked close at the speaker openings I would note that they were a diamond shape instead of square as original. Other than that, it looked factory. The truck was red, and the dash pad was in the original carmine color. I, like most everyone here, am willing to pay a little bit more for a better quality piece, and since these come in factory colors as well, I was just wondering if anybody here has bought and installed one of them yet? ....Joe http://www.parts123.com/parts123/yb....Z5Z5Z50000215a
I'm not speedin'! I'm qualifyin'! |
#110 | |
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
#111 |
Either Cheyenne does a poor job of keeping stock, or they had a bunch of people buy dash pads recently, as they are backordered for like 2-3 weeks til they make more. Will post back then!
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s Last edited by TheApocalyptican; 06-12-2011 at 04:45 AM. |
#112 |
Just got my dash from Cheyenne Pickup Parts. It is NOT a vinyl over foam over metal dash. It is a vinyl over foam over plastic dash. While it is not as rigid as a stock metal dash, it isn't very flimsy. I took it out of the box as soon as UPS dropped it off, and due to having it riding in the UPS truck all day, I figure at worst it'll be as flimsy as when I first unboxed it, but never really worse. Definitely isn't a wet noodle like the urethane ones. I put it upside down on a recliner here in my house, and there way no sag to it.
Hasn't been installed just yet, but everything looks great. Really like how the gauge bezel fits into it without a gap like I have seen on some of the other aftermarket pads. We'll see if it stays gapless once installed tho. Pics of the plastic underside: ![]() ![]() This is the only thing I am not completely happy with fit wise: ![]() I'll have more pics when installed. Lemme know if guys want any other specific pics of it.
#113 |
Apocalyptician have you installed the dash? I'm thinking about getting this dash depending on how it fits in your truck lol are you satisfied with it?
#114 | |
Problems: Due to the plastic rather than metal, the dash seems to bulge slightly where the dash speakers are. The area around the passenger defrost vent isn't the same height all the way around. Most of it is correct, except for one area in the very front near the windshield is lower. The picture I posted before of how the a/c duct/trim fits is also a problem area. Speaker holes are a little rough. And last is a small area between the bezel, and the dash pad right next to the stereo and a/c controls. Honestly, none of these problems are a deal breaker for me. I was also being extremely picky about the problem areas so that others no exactly what quality and fit they are getting with this pad. Spot near stereo: ![]() Speaker Holes: ![]() Spots where dash bulges due to speakers: ![]() ![]() Passenger Defrost Vent(not sure how well the problem can be seen in the pic): ![]() Other pics: ![]() ![]() ![]() ![]() Also, the two gauge bezel holes aren't drilled. Neither are the holes across the bottom where it bolts in, or the screw that goes into the passenger side of the dash. I left the passenger one out, and just screwed the others straight thru the parts of the dash where they belong.
#115 |
resident wrencher
Those look nice but they dont have my color i need a saddle color or tan the closest is buckskin
#116 |
#117 |
resident wrencher
ok there pic of the buck is brown i know buck skin gloves is tan
#118 |
What a dizzying array of opinions on dash pads! What have I gotten myself into? My Suburban (89) is one of those aforementioned 'Arizona Survivors' for the most part. What most of you are describing as cracked and beat up probably doesn't hold a candle to the powdery, crumbly, cracked, dried up mess that adorns my dash currently.
My question: What is the top of the line dash pad? How do you get an OEM dash pad? If you were to rank them (based on personal experience or research) how would you rank the dash pads? Thanks |
#119 |
Farm Truck
![]() Join Date: Aug 2006
So who sells the best dash?
1969 CST/10 1984 K5 Blazer 4x4 2016 Dodge Ram 2500 4x4 Mike Jersey Village, Tx |
#120 |
I ordered the Brothers dash July 13th. Was told it was back ordered and would ship end of July. Now they tell me it will be available Aug 12. Not the best customer communication. Only reason I purchased this one is that they stated that it used metal instead of plastic for the frame like the OEM one. If I ever get it I will post up some pictures.
1985 K20 350M/SM465/NP208/GM10/GM14 |
#121 |
Looking forward to the review!
#122 |
From everything that I have read, GM sells the best dash pad. Built exactly like the original, but available in only one color: black. Also it runs about $500, but I guess that is the price of OEM quality.
I'll just stick with my dyed and only slightly cracked OEM dash pad for now. |
#123 |
I'll tell you from experience, not what I've read on a forum.
The best fitting dash is GM. Period. It cost more at around $400-$500. Just bought one, was light gray, dyed it burgandy, installed new vents, fit is as good as can be expected. Very satisfied. I've installed several coverlays. They are an excellent fit. I like to install mine with the dash out so I can apply clamps to it while the adhesive sets up. They snap on for a perfect fit, BUT when they get hot, always bows at the passenger side defrost vent. |
#124 |
Farm Truck
That's what I kinda figured.
#125 |
78K & 79C Jimmys
what colour is this?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
