Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 03-16-2012, 10:14 AM   #101
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Project Patina Azul
Originally Posted by Flint70step View Post
I want to use 1 1/2 drop springs in the front along with the spindles and then see what 4'' drop rear springs will do for me.I would like for it to be parallel to the ground for a clean looking stance.I want it to come out looking like these Burbs or just a tiny bit lower.
I have piced up a set of 2" front spring for mine and 3" for the rear and will steal my set of ECE spindles from my SB parts pile or spring for a new set once I get it rolling.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-01-2012, 12:42 AM   #102
Nothinghead
Nothinghead's Avatar
Any updates?
Good looking build man, can't wait to see it finished.
79 Blazer 350 TH350 part time 4wd Sold!
86 GMC 1 ton something...
Nothinghead is offline   Reply With Quote
Old 04-01-2012, 02:24 PM   #103
Flint70step
Flint70step's Avatar
Originally Posted by Nothinghead View Post
Any updates?
Thanks man,no real updates yet.I still need to gather some parts before I do the drop.Yesterday me and the boy washed the Burb and then I tackled cleaning the factory floor mat.
The Burb all washed up.I really need to put the trim piece on the passenger door.I even have it,just need to get the clips for the middle with double sided tape
Here is a pic of the Burb the night that I had picked it up.The floor mat looked like it had never been cleaned.I swept it out and drove like that till now.
I wet the floor down with a big sponge making sure to it all good n wet.Then I took my time washing the outside of the Burb letting the floor "soak".After I washed the outside I then took the same sponge and got up most of the surface crud off so I wouldn't just be spreading dirt around when I attacked it for real I spread some oxiclean over the still wet floor and hit the entire floor with a scrub brush and a lot of elbow grease.I was amazed with the result and wonder why I haven't done this sooner.Tell me what y'all think
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way)
72 Custom Deluxe Burb(Arizona truck)Nice interior
Great patina
Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668
Flint70step is offline   Reply With Quote
Old 04-01-2012, 02:41 PM   #104
Nothinghead
I would never has guessed that floor was blue! Looks better now.
Old 04-22-2012, 04:32 PM   #105
firedog
firedog's Avatar
I guess i never realized that they put floor mats of any other color then black in our trucks
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 04-22-2012, 04:56 PM   #106
Flint70step
I was amazed as well.Makes the interior pop a little more now
Great patina
Old 04-22-2012, 05:15 PM   #107
Flint70step
While at the New Braunfels swap meet yesterday picked up a re-pop Driver side sport mirror for the Burb.It was $35 and was tired of not having a mirror.I took a few pics of the install today.
After some head scratching on how I was gonna go about holding the mirror and the screw,gasket and backing plate I taped the gasket to the door.
I then hung the mirror by the threads of the front most screw.I then used my right hand to hold the screw driver on the screw firmly so I could use my left guide the backing plate into position.It was not easy and it took a couple tries.
Then I got the other screws started and snugged them up when I was happy with it.I'm sure there is an easier way to do this but this is how I got it done
Great patina
Old 04-22-2012, 05:33 PM   #108
Flint70step
I also have been kicking around the idea making my seat look better until I can get it redone.
I came up with a cheap fix that will get me by till I can get the seat redone.I found some cheap blue pillow cases at Wal-mart for $5.I just happened have some matching blue thread in a sewing kit left behind by an old girlfriend.We're in bussiness
Then I went about tucking the two pillow cases into position.The idea I had was to use the cases to protect the foam and serve as a backing to stitch the remaining seat cloth to.
Then I realized that the needle I had would be a PITA to use.So tomorrow on the way home from work I will get a curved needle and some pins to hols everything in position while I try my hand at stitching all this together.It will probably come out looking like Frankenstein but it will protect the seat foam and hopefully look better
Great patina
Old 04-23-2012, 08:04 AM   #109
Nothinghead
That's pretty smart with the pillowcases! I like it!
Old 05-12-2012, 11:15 PM   #110
lynnfield
The Waco Kid
lynnfield's Avatar
Hey, I just found your thread and read thru the whole thing, nice job btw! I just picked up a blue K10 burb that I am going to part out later this summer. Contact me, and I'll let you have first look at it. Greg
lynnfield is offline   Reply With Quote
Old 05-13-2012, 05:30 PM   #111
Flint70step
sending you a PM with my number.Give me a call and we'll talk.Thanks for the heads up and the compliment on my Burb build
Great patina
Old 05-25-2012, 05:17 AM   #112
68 TT
Still plays with trucks
68 TT's Avatar
Great project.
I have been considering a very similar build but some guy in my neighborhood keeps buying all the Burbs around town to turn them into crew cabs.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-10-2012, 03:56 PM   #113
Flint70step
The Burb was in an accident this weekend and its not pretty.A young woman leaving a parking lot cut across stopped traffic in the right lane and ran right into the front of my Burb.I will be rebuilding it and that's a promise.I know its gonna be a tough fight with the insurance company but I'm gonna hold my ground and not give in until I'm satisfied.Any help in locating a frame and front clip will be greatly appreciated.
Its safe at my house now.I have a good friend who owns a tow service.
Great patina
Old 06-10-2012, 04:14 PM   #114
Flint70step
Here are some photos from last weekend at the lake that I haven't posted yet.Enjoy
Great patina
Old 06-10-2012, 08:00 PM   #115
blfuller123
blfuller123's Avatar
That sucks man
blfuller123 is offline   Reply With Quote
Old 06-10-2012, 10:03 PM   #116
mcbassin
Still Learning
mcbassin's Avatar
I knew I had seen that burb before when I saw your thread in the general section. Sorry to hear about the crash. If you were closer I have some parts that would help with the rebuild.
mcbassin is offline   Reply With Quote
Old 06-11-2012, 11:12 AM   #117
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
At a loss for words, sorry
Old 06-11-2012, 12:15 PM   #118
gcburdic
Restoration Virgin!
gcburdic's Avatar
Gosh darn it!!!....Hope everyone was ok...sorry to see this crap...this is the second one on here in recent months taking a bad hit!!!YUCK!!!
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 06-11-2012, 04:18 PM   #119
68 TT
68 TT's Avatar
Sorry to hear about the accident. At least you are OK. It's a whole lot easier to fix or replace a damaged vehicle than it is to fix physical injuries to your body.
I am still messed up more than a year and a half after getting hit from behind while I was stopped at a red light. Still fighting with the insurance companies over it too.
Good luck on the rebuild and with getting what you deserve out of the insurance company.
Old 06-11-2012, 06:35 PM   #120
Flint70step
Thanks Y'all,I have a frame located that a good friend of mine has.He even has an apparatus to lift the body off and roll the frame out.I helped him do it to his 67 panel.I think Lynnfield has a front clip the same color scheme as well as great patina.Things are looking up as far as the rebuild goes.I have some good friends that are gonna help and with the help of the board we'll get it done.
Great patina
Old 06-12-2012, 12:33 AM   #121
lynnfield
The Waco Kid
lynnfield's Avatar
Well.......I just don't know what to say...........sorry to hear it. Greg
I'll give you a call, might be a few days, working nights right now.
Old 06-12-2012, 10:04 AM   #122
502ms
502ms's Avatar
Man, I just read this whole thread...to come to this. I am sorry. Here is a question - are you sure there is frame damage? It looks like the fender and hood are the only areas really hurt (besides the bumper and front core support). Well, I guess now that I think about it, those are hurt, too. Good news is that they can be repaired...just don't toss that truck. Glad you and the family are alright
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 07-07-2012, 10:40 AM   #123
Flint70step
Yes there is definitely frame damage.I have a good friend who has another 1/2 ton Burb frame.I just need the get the Burb tub off and switch out frames.He has a lifting rig that we used to pull his 67 panel tub off its frame so I know we have a way to get all this done.H ere are some shots of the frame damage.The second shot shows how far my drivers front tire sticks out past the body.The frame moved 4-5 inches at least.There's a dent in the air filter housing from it hitting to brake booster and the alt. hit the master cylinder.
Great patina
Old 07-07-2012, 11:17 AM   #124
Flint70step
Took about 30 minutes to pull the front clip.I've done it so many times I knew all the tools I needed and made short work of it.Now I need to get the engine ready to pull and borrow an engine puller.All the body mount bolts look good and I can see the treads are not rusted.I need to get over to my friends with the other burb and hit all the body mount bolts with some PB blaster.The plan is to get the frame swap done as soon as possible but do a good job.
While I'm doing the frame swap I might as well strip and paint the new frame before it goes under the Burb.I also need to do a few mods to the new frame to get the van gas tank with in tank fuel pump in.mount my fuel lines and move and drill the trans cross member.
Great patina
Old 07-07-2012, 11:34 AM   #125
Flint70step
Here is where I really need help from the wonderful members of this site.I need an original paint med. blue front clip.Paint does not have to be perfect,patina is preferred.I do how ever want dent free,mostly rust free sheet metal.I do plan on painting my burb back to original so I want the clip to have factory paint on the inner parts.
I know shipping will be a PITA but I will pay to have my baby back.Its out there waiting for me.I know you guys will come thru for me.Don't let me down
A clip in about the same condition as mine was is what I'm after.Here is a pic for reference.
Great patina
