#101 | |
Six in a row makes it go...
![]() Join Date: Mar 2009
Re: Frustrated ...
When installing an HEI, I always by-pass the original wiring and run a new wire straight from the fuse box to the distributor. The HEI requires 12 volts at the distributor. (I usually try not to run the wire on top of the exhaust though) ![]() Someone let me know if I'm wrong about this...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#102 | |
Re: Frustrated ...
To add to this discussion..... The vacuum line was off for the trans modulator & there was a wire shorted because it was not secured properly. This would suggest 'poor' follow-up by the techs that did the work. That being said, I would go through all the basic stuff immediately. Check all wiring surrounding the engine bay. Make sure the grounds are in place & tight/secured @ the engine block, the chassis, & from the cab. Verify all vacuum related necessities for the motor have the vacuum they need & that the lines are in good shape. You need to also determine why the vacuum charcoal canister had an open port (Did the sloppy techs leave another line off? Is something else not connected? Did they break something & not correct it??). Verify you have 13+ volts going to the battery. Verify you have 12+ volts going to the ignition. I would do all of this before I drove it around the block again.
#103 | |
Re: Frustrated ...
thanks alot, did what ya said.. everything checks out.. Thanks all. I really appreciate the help i got here.. OFF FOR A DRIVE ![]() nate
72' Chevy C-10 Custom Deluxe 350 bored over .30 Th350 Tranny 3.73 gears flowmaster 40 series 87' Ford Mustang GT 302 HO Underdrive pulleys, 3.73 gear, flowmasters |
#104 |
Re: Frustrated ...
darn thing...let us know how the drive went
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
