11-02-2011, 03:22 PM | #101 |
Artist
Re: Project Goldilocks, '66 C10 SWB BBW Build
Hey Man give Doug a call... he can cut you a cam to whatever spec you want. Roller too!
877-497-2787 Ask for Bruce, tell em Kasey sent ya... He'll hook you up!!
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
11-02-2011, 03:34 PM | #102 |
Artist
They can help with Pistons too!
11-02-2011, 11:41 PM | #103 |
http://www.ebay.ca/itm/Chevrolet-C-K...t_39120wt_1270
This link is a '69 same colors as yours, sure looks great. Good luck with the 6 refresh. |
11-03-2011, 08:24 AM | #104 | ||
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-03-2011, 08:34 AM | #105 |
Since we're on the subject of look-alike trucks, here's a pic of one I found on ebay that's a similar color. I also did a rough lowering job with MS paint. I posted some pics in the photoshop thread hoping someone would be able to drop it and swap 18's with stock caps on it, no luck yet.
11-04-2011, 08:34 PM | #106 |
Got the rest of the bed floor support rails out tonight, no pics but they'd be pretty boring to look at anyways. Gunna take them and the new strips to the powdercoater monday and hopefully they'll be done within a couple weeks. That should give me time to get the wood painted and the bed sides undercoated before it all goes back in, that is if its warm enough! All the work on the bed has been done under an open shed so far, and its been gettin pretty cold once it gets dark so I'll probably start loading it up and hauling it to our shop when I work on it. My VW doesn't have heat so it'll be nice to get to drive this thing through the winter next year!
11-04-2011, 09:36 PM | #107 |
Artist
Here ya go.... all you had to do was ask... GOSH!
11-04-2011, 10:18 PM | #108 |
Now I just got to make the real truck match that! Thanks so much!!
11-19-2011, 03:57 PM | #109 |
Not much to report. I've been sick the past week so no progress other than having alot of time for planning and researching.
I've decided to cup the lower control arms to get the bags into their design height at ride height. I've noticed alot of trucks running upper plates and lower cups with larger bags like my D2600's don't have enough heigth for the bag to be properly extended at ride height. Cupping the LCA's will gain about 2.5" more bag height than using bag cups in the factory spring pocket. I've found a pair of LCA's locally so I don't have to cut up the original LCA's. This mod should gain a better riding and handling truck. I'm also planning on tearing the frame back down to paint and detail it. The powdercoat wasn't applied thick enough in places, especially around brackets and tight areas- thin enough that its already getting a thin coat of surface rust in places. I can spot blast the thin spots, then prep and paint the frame with a few coats of low gloss black enamel. I've been very impressed with Valspar's Tractor and Impement enamel for it's durability and finish quality so I'll pick up a gallon and hardener from Tractor Supply. I know its just going to be a driver, and it should be low enough that nobody's going to be looking under it but I'm more concerned about the frame being protected properly. I'll paint the bed floor strips insted of getting them powdercoated since I haven't been real happy with the quality of work I've seen from our local powdercoater lately, including the truck frame. It's alot more work but it'll be worth it once it's all back together. Posted via Mobile Device
11-19-2011, 06:44 PM | #110 |
Here's a shot of one of the rusted areas. It's not that bad but I don't want it getting worse.
11-21-2011, 10:51 AM | #111 |
Artist
Oh Id be flipping out! As expensive as powdercoating is... that wouldnt fly! I used the tractor implement paint on mine.... been driving it for awhile and it holds up great! I used gloss black just because it cleans easier. and with being a driver.... thats needed!
11-21-2011, 01:24 PM | #112 | |
I like gloss black and it is easier to clean, but scrubbing it would make spiderweb/swirlmark type scratches and that would drive me crazy. I hate fine scratches worse than deep scratches. I used to detail cars when I was in high school and swirl marks or towel marks drive me insane! I don't care they're on a hood, or trailing arm, or an air filter lid, I see them and it makes me want to polish them out so bad... satin paint helps me keep my sanity.
11-21-2011, 01:58 PM | #113 | |
Rollin' Old Skool
sucks about the powdercoat though...have you told them what happened, or will you just let it slide?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-21-2011, 06:07 PM | #114 |
They do good prep work and have done quality work in the past so I'd like to be able to use them again. If I do take anything else to them I'll definitly mention that the frame didn't get good coverage and that I'd like for them to spend a little extra time making sure everything is coated well.
11-21-2011, 07:30 PM | #115 |
Truck and auto performance nut
subscribed....for educational purposes!
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-22-2011, 08:15 PM | #116 |
PROJECT 7DEUCE
For the stuff you build id take that back and say hey....fix this...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-22-2011, 09:56 PM | #117 | |
Hang around, you'll learn that I usually don't know what I'm doing!
They'd re-do it if I asked them to, no doubt; they're stand up dudes. I'll paint it though, might even spot blast around the rivets and weld up all the rivet heads to stiffen up the frame. I'm also thinking about building some bolt in round tube crossmembers to minimize frame flex/twist. That should make the truck ride/handle better and have a more solid feel. If I paint it I can add the braces later and paint them to match and the texture/sheen will match. Gotta have matching sheen on all the chassis parts! I can also prep the frame myself, spot prime and wetsand it first to get it slick. Then seal the seams and shoot a few coats of paint. Dang project cars! I keep getting deeper and deeper into this thing! Posted via Mobile Device
11-23-2011, 05:53 PM | #118 |
well...what ever it is then...... it seems to be working!
11-26-2011, 01:38 AM | #119 |
I got the rear bags finished up today. At their minimum design height I'm not sure it'll sit as low as I want for the ride height so I may add two inch blocks to lower it without collapsing the bags under their design height. I definitly don't see how guys are using these bags with cups unless they want a near stock ride height.
Aired up. Aired out. Should sit slightly lower once the weight of the bed is on the frame More frame rust. What's with all that mess on the floor? Might have something to do with this? Yep, I decided to box the frame rails. The truck won't ever get finished if I keep heaping more and more on the "to do" list! This will strengthen the frame and make it easier to mount the X member. The front will be boxed up to the steering box but I'll need to figure out a way to keep the crossmember and control arm hardware accessible. Unfortunately after all that hard work, adding the cardboard plates didn't add as much structural rigidity as I had hoped they would. And after thinking about it more, if they ever got wet they'd lose some of their strength, so I decided I'll have to step up and get 1/8" plate cut to fit and welded in. Better not take any short cuts at this point, right? I've been researching X member designs and found one that I like. It's got a solid tube as the center section. Round tubing is very strong against torsional twisting so this design should limit frame flex better than an open square shaped design. I'll start a separate thread on X member designs and frame bracing to get more input before I decide on a final design. Also planning on using my tubing roller to arch the main tubes of the X member for more strength. Posted via Mobile Device
11-26-2011, 03:35 AM | #120 |
Since you are not going to use the cardboard, can I have it?
I will run out and get a bottle of Elmers Glue and be in business!!
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
11-26-2011, 04:06 AM | #121 |
I am really enjoying your build thread and I was an avid follower of your last build. Your attention to detail is amazing and as a person that is also very picky about how things are done, I appreciate that. However, I just have to kinda chuckle when I go back to the start of this build and read how it was going to be different. To quote from page 1, "I wanted to find one to build for myself. I didn't want a show truck like the '65 turned out to be; more of a solid beater that was nice enough to tinker with and drive as found." I had a feeling that this would turn out to be more than that but I'm loving it. Keep up the good work. It gives me inspiration for perfection.
11-26-2011, 01:57 PM | #122 | ||
Thanks, I'm glad you're enjoying the builds! It's still going to be a daily driver that doesn't get pampered, and I'm still not goint to paint it. I've already had to tell myself that I'm not going to weld the frame plates on flush and grind the welds down like I did the C notches; I'm going to weld them in about a 1/4" deep so I can't get the grinder in there! Hopefully I can make decent enough weld beads so they aren't too hard on the eyes. I was hoping to find a truck that was running and driving but this one came along and was a good price for the condition it was in and the work that had already been done so I didn't want to pass it up. Trucks with bodies this nice just don't exist around here anymore! It is getting deeper than I expected but while it's torn down this far I may as well go ahead and do it right, once, and be done with it. If I didn't do it now, it would be in the back of my head as long as I own it that I should have done it while it was apart and easy to do. It takes longer that way, but once it's done it'll really be "done". Well, atleast until I get a wild hare to do something else to it...
11-26-2011, 02:39 PM | #123 |
1 thing at a time is progress.
Watch out for those wild hairs. I've got so many in my head they are starting to grow out of my ears...........really.
Alan
Philippians 2:14-16 |
11-26-2011, 04:55 PM | #124 | |
And are you sure you are not going to end up like the one fellow here who started to build a shop/parts runner truck, and ended up putting it in car shows?? I know I am going to show mine as a work in progress, though mainly it will be a hauler for my Tempest to the shows. Something about a 66 trailering a 66 just seems like it will be cool to me I really enjoy your build threads man; I learn so much from the guys around here like you!
11-26-2011, 05:35 PM | #125 |
I think the biggest problem I have is reading in the forum. So many good ideas get stuck in my head that I'd like to do it's hard to stay on track with the original plan.
