Old 02-12-2025, 02:22 PM   #101
Dude68
Re: 1968 redo
I got the floor and behind the cab sprayed the other day. You cannot tell in this pic but the steering column is a different shade of blue with metallic. Door panels and top of dash between pad and windshield will be this color as well.
Joey
Dude68 is offline   Reply With Quote
Old 02-12-2025, 02:25 PM   #102
Dude68
Re: 1968 redo
Working on the cracks in the steering wheel with epoxy.
Joey
Old 02-12-2025, 02:28 PM   #103
Dude68
Re: 1968 redo
Turn signal switch replaced. Was a little bit of a booger getting it in. Had to refer to a few posts on here.
Joey
Old 02-12-2025, 02:33 PM   #104
Dude68
Re: 1968 redo
I am in need of all of these little parts that are supposed to go inside the circle on the clutch rod. Its being held in there with a cotter pin currently. All of the parts disintegrated when they were removed.
Joey
Old 02-12-2025, 02:41 PM   #105
Dude68
Re: 1968 redo
Working on the carb. It's a monojet. Removed and ready for disassembly and a good cleaning.
Joey
Old 02-12-2025, 02:47 PM   #106
Dude68
Re: 1968 redo
Carb is torn down and cleaned up. I hope I can remember how to put this back together.
Joey
Old 02-12-2025, 02:49 PM   #107
Dude68
Re: 1968 redo
It is raining here and 40 degrees. Ended the plans to paint the door panels and top of dash today. So, I started work on the manifolds. Broke a stud off the exhaust manifold and found a crack. I'm gonna be needing a new exhaust manifold.
Joey
Old 02-12-2025, 03:01 PM   #108
Dude68
Re: 1968 redo
Anyone know why this hole was filled?
Joey
Old 02-12-2025, 05:57 PM   #109
pjmoreland
pjmoreland's Avatar
Re: 1968 redo
Nice progress! Here's the clip that normally goes where you have a cotterpin in your clutch rod.
https://classicparts.com/1960-81-clu...attaching-clip
pjmoreland is online now   Reply With Quote
Old 02-12-2025, 06:15 PM   #110
Dude68
Re: 1968 redo
Thanks I have the clip, but seems like there was a bushing or grommet. Kinda like the linkage stuff on upper shift rod
Joey
Old 02-12-2025, 07:04 PM   #111
pjmoreland
pjmoreland's Avatar
Re: 1968 redo
The setup I put in my truck came out of a '67, and it did not have a bushing or grommet. Maybe they added that later.
Old 02-12-2025, 08:19 PM   #112
Dude68
Re: 1968 redo
So just the pin?
Joey
Old 02-13-2025, 01:02 AM   #113
pjmoreland
pjmoreland's Avatar
Re: 1968 redo
A search indicates that some trucks did have a bushing there. See this thread, for example:
http://67-72chevytrucks.com/vboard/s...d.php?t=653944
Also, take a look at the first photo on this website. They show a little white bushing sitting next to the end of the push rod.
https://4speedconversions-com.3dcart...k_linkage.html
This might be the right part. It could also be the larger pedal shaft bushing though. Hard to tell its size in the photo, but the description seems right:
https://classicparts.com/1971-84-clu...sh-rod-bushing
Old 02-13-2025, 04:01 AM   #114
Dude68
Re: 1968 redo
Yes, the little white bushing is what crumbled when we took it out. Thanks.
Joey
Old 02-13-2025, 10:25 AM   #115
raggedjim
raggedjim's Avatar
Re: 1968 redo
You sure that's not a dirt dauber nest???
raggedjim is online now   Reply With Quote
Old 02-13-2025, 11:42 AM   #116
Dude68
Re: 1968 redo
it is solid white. what is the hole for?
Joey
Old 02-13-2025, 03:03 PM   #117
raggedjim
raggedjim's Avatar
Re: 1968 redo
Not sure, did it hang in there through the cleaning process?
Old 02-14-2025, 01:09 AM   #118
Dude68
Re: 1968 redo
No it came right out and is clean as a whistle.
Joey
Old 02-14-2025, 02:04 AM   #119
Dude68
Re: 1968 redo
Got the exhaust manifold ordered. Got a new one. I posted on the board for advice on color to paint the intake and exhaust manifolds. All black or intake blue and exhaust black? Refer to post #90 in this thread to see my engine and look at post #108. The intake is on top of exhaust. I was considering blue on intake and black on exhaust.
Joey
Old 02-15-2025, 10:33 PM   #120
Dude68
Re: 1968 redo
I was wire brushing the intake manifold this morning, hitting that last bend on the end and found a crack running from top to inside to bottom. Thought we would try brazing, but it did not look like it would do. Ordered a matching casting used intake from 12bolt.com. New one is on the right. Looks different but it is same casting number.
Joey
Old 02-15-2025, 10:36 PM   #121
Dude68
Re: 1968 redo
Hit an estate sale in Hot Springs this morning, scored this folding aluminum bench for $15. Used it today spraying dash. Gonna come in handy when we are ready to spray the cab roof!!
Joey
Old 02-15-2025, 10:56 PM   #122
Dude68
Re: 1968 redo
Painted interior dash that was a different color of blue as well as door panels. They match the steering column. A little metallic in it. I am considering doing the buddy bucket tool box the same color instead of gluing vinyl on it.
Joey
Old 02-15-2025, 11:03 PM   #123
Dude68
Re: 1968 redo
Painted buddy bucket seat frame with rust encapsulator as well as buddy bucket tool box. Had a lot of rust. I may go over the tool box with the blue.
Interior prep work coming up next, waiting on an intake and exhaust manifold. Next week temps are going to be in the 20's with snow on Thursday.
Joey
Old 02-22-2025, 05:37 AM   #124
Dude68
Re: 1968 redo
It was 15 F on Thursday, had a little sleet and closed schools for 3 days. Prepping manifolds for paint. I got them cleaned up yesterday. Next week will be in the 60s. Planning on completing painting the interior next week.
Joey
Old 02-28-2025, 02:03 PM   #125
68 C10 Driver
Re: 1968 redo
Outstanding progress on your truck, great work so far. That area under the dash which is part of the cowl air intake system for the vents and heater is a real bear to repair. I removed my dash panel (drilled out 38 spot welds) in order to repair it. I used a section of an old inner fender to use as a patch panel. It will never rot out again - I coated the whole area inside the cowl with Raptor Liner using a brush.
68 C10 Driver is offline   Reply With Quote
