Old 12-07-2011, 10:22 PM   #1
Todd68Chevy
Todd68Chevy's Avatar
Parting out a 1972 Chevy Cheyenne C10 ***Parts list added 12-17***
*************Parts list added in post 59*************************
I have a 1972 Chevy Cheyenne 10 that is rough but I figure there are a few parts that need to be saved before the truck is disposed of. It was originally a v8 automatic but engine and transmission are missing. I am parting out the entire truck but I do have some parts already sold locally. I am planning on disassembling this truck Saturday December 10th. Post to the tread with interest and I will check and get pictures as soon as I can. I will need to remove most parts before the shipping charges can be figured. I accept PayPal or Bank Money Orders.
Items that are already sold locally:
Power brake booster, brackets, push rod, m/c and prop. valve
front cross member, suspension and brakes
rear differential
power steering box and power steering pump
Items I see that are worth saving:
******Parts list***** added 12-17****
1. Shifter linkage & Frame Pivot-- missing transmission tab $20.00 plus shipping
2. Grille brace- rusty-- Free plus shipping
3. Hood latch-- $15.00 plus shipping
4. Hood pin and latch plate (attaches to hood)-- $6.00 plus shipping
5. Small block engine stands-- SOLD
6. Interm. steering shaft-- $10.00 plus shipping
7. Evap. Canister bracket-- $5.00 plus shipping
8. Flange for exh. pipe against exh. manifold-- $5.00 pair plus shipping
9. Washer bottle bracket-- $5.00 plus shipping
10. Washer Jug-- FREE plus shipping
11. Core support to fender brace-- rusty but solid-- Free plus shipping
12. Exh. bracket that rivets to the frame by transmission crossmember--$10.00 plus shipping
13. Tailgate support links-- SOLD
14. Tailgate pivots-- SOLD
15. Heater hose clip/ bracket-- $2.00 plus shipping
16. Center bumper brackets-- $5.00 pair plus shipping
17. Battery hold down bracket-- $2.00 plus shipping
18. Steering column, automatic-- $40.00 plus shipping
19. Steering column mount-- under hood with clamp-- $10.00 plus shipping
20. Steering column mount-- strap attaches to brake pedal bracket-- $6.00 plus shipping
21. Steering wheel (cracked) with horn button and horn parts-- SOLD Locally
22. Steering column trim (goes up to cluster)-- $6.00 plus shipping
23. Throttle cable bracket-- $5.00 plus shipping
24. Carrier bearing bracket-- rivets to the trailing arm crossmember-- $15.00 plus shipping
25. Misc. parking brake cable items including center cable-- SOLD
26. Door panels and armrest wood grain worn, extra holes drilled, chrome trim good-- $30.00 plus shipping
27. Gas tank, small spot that looks like possible rust below strainer-- SOLD
28. Rear step bumper-- SOLD
29. Tail light harness, See issues pointed out in post 138-- $15.00 Shipped
30. Harness from firewall to taillight harness-- $10.00 plus shipping
31. Headlight harness-- $18.00 plus shipping
32. Dash harness, fuse box looks ok, gauge cluster, non-a/c and no cig. ligher-- $20.00 plus shipping
33. Dome light-- SOLD
34. Fuel gauge wire, from tank to fuse box-- $5.00 plus shipping
35. Fuel lines that hook to the sending unit-- $5.00 plus shipping
36. Evap. lines-- $5.00 plus shipping
37. Sunvisors, sticking is loose--$15.00 plus shipping
38. Sunvisor clips-- $5.00 pair plus shipping
39. Dash cluster w/ gauges, no tach-- SOLD
40. Headlight and washer knob-- $5.00 plus shipping -- Washer Knob- SOLD
41. Glove box lid-- $20.00 plus shipping
42. Glove box latch catch (attaches to dash)-- $2.00 plus shipping
43. Reverse light housing, right side-- $5.00 plus shipping
44. Reverse lense-- SOLD
45. Taillight lense-- SOLD
46. Taillight housing-- $10.00 pair plus shipping
47. Cheyenne fender emblems-- $25.00 pair plus shipping
48. 8/350 emblems (frt. fender)-- $15.00 pair plus shipping
49. Headlight bezel-- $20.00 pair plus shipping
50. Left outside door handle-- $6.00 plus shipping
51. Jack tool hold down items-- $5.00 plus shipping
52. Speaker bracket-- SOLD
53. Door lock lever and retainer-- $5.00 plus shipping
54. Brace under steering column (flat panel)-- $5.00 plus shipping
55. Door handle and window crank (inside)-- SOLD
56. Automatic brake pedal-- $35.00 plus shipping
57. Heater controls (face rivets are a little loose, levers are good and move)--SOLD
58. Inside heater box with cables-- $35.00 plus shipping
59. Outside heater box-- rechecked and found a rusted hole in the metal part
60. Cowl panel, extra holes-- FREE NO shipping
61. Driveshaft-- $20.00 NO shipping
62. Cig. lighter delete-- SOLD
63. Roof panel (cut at the bottom of the a pillar and acrosss the rear below the double panel)-- $75.00 NO shipping
Let me know what else you are interested in and I can inspect, get pictures and price. I will ship anything I can but I am limited on larger items and sometimes finding boxes. I do not have Greyhound shipping as an option.
Thanks for looking
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
