12-22-2015, 08:02 PM | #101 |
But Found Her 25yrs Later!
Re: Gas guzzling alternatives
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-22-2015, 08:29 PM | #102 |
So if you borrowed $5000 at 10% interest, and that $5000 saves you $5000 in gas in 5 years, you'll break even in 6 years and only have 60,000 on the motor and tranny.
12-22-2015, 08:36 PM | #103 |
Anyone see anything wrong with my calculations?
12-22-2015, 08:42 PM | #104 |
I don't know. It cost $6,373.80 over 5 years to save that $5000 in gas?
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
12-22-2015, 08:46 PM | #105 |
Yes, but in 6 years you're real close to breaking even.
Or, another way to figure it is: It costs you about $100 a month on the loan to save $100 a month in gas.
12-22-2015, 09:10 PM | #106 | |
The biggest motivation for me was the coil packs, as I believe again that there are moderate power and efficiency gains to be had having 8 coils firing once in a rotation, vs 1 coil firing 8 times. Also eliminates some wear/tear issues with a cap+rotor, potential arcing. Will also let me do my timing from a computer instead of with a wrench, timing light, etc. It's been too many years for me to do a mileage comparison of before and after (before being a TPI), but I thinking I can push this to 17-18mpg highway with the setup I'm building. |
12-22-2015, 09:15 PM | #107 |
Here's an interesting old poll:
http://67-72chevytrucks.com/vboard/s...d.php?t=172346 . Here's a LS Swap Cost FAQ. http://67-72chevytrucks.com/vboard/s...d.php?t=473560
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 12-22-2015 at 09:31 PM. |
12-23-2015, 01:15 AM | #108 | |
LOST: please make sure you subtract the cost of a rebuild on the stock engine from your breakeven. to be a fair comparison, you have to figure the opportunity cost of NOT doing the swap, in other words what you would spend on rebuilding the stock engine and replacing the carb in a few years time. This is why I like spreadsheets, you can figure not only the costs but the timing of the costs. early money beats late money every time.
and feel free to pick my brain, I helped a friend megasquirt his truck after mine so I have 2 systems experience. but I am telling you, its so easy. you will grin ear to ear and want to drive around with the laptop on the seat. thanks, its a beautiful truck for someone else now though. just like electrical engineering I like the transient state more than the steady state because thats where all the action is.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-23-2015, 01:09 PM | #109 | |
12-25-2015, 05:39 PM | #110 |
I did find that the monojet carb was way better than the older Rochester at getting good milage .. My one ton 65 would get better than 15mpg with a 250 .. The dual venturi really helps...
12-27-2015, 12:58 PM | #111 | |
From another thread :
That's one main reason I'm swapping in a th350. - I don't by any means need an OD. Even backing up my semi steep driveway with a trailer was a total work out. So, my top of list upgrades I'm doing right now is power steering and the th350. But after doing much research the last couple weeks on EFI, I'm thinking I'm a good candidate to see a huge improvement in my driving experience, because of my areas driving conditions. Our weather varies much also. . So, the 283 is a fairly new rebuild, in fact the previous owner said he had his mechanic build it as a 327. Would one these be a quick and easy solution for EFI? http://www.hotrod.com/how-to/engine/...iant-efi-test/
12-30-2015, 07:39 PM | #112 |
Ordered me the 600hp unit along with the Fuel Command Center from Summit.
12-30-2015, 08:12 PM | #113 |
Awesome I'd love to check it out sometime!
12-31-2015, 12:25 AM | #114 |
12-31-2015, 01:28 AM | #115 |
12-31-2015, 06:19 AM | #116 |
Yep. I'm pretty anxious.
01-17-2016, 01:33 AM | #117 |
01-17-2016, 01:56 PM | #118 | |
