Old 04-10-2013, 10:51 AM   #101
mooseknuckles
mooseknuckles's Avatar
Re: My new project 86 Silverado
you can get away without using a c-notch with a flip kit if you remove the bumpstop and bracket...as long as you don't haul too much you'll be o.k.
mooseknuckles is offline   Reply With Quote
Old 04-10-2013, 10:51 AM   #102
Jonboy
Slots go on anything!
If you are doing a flip in the rear, you absolutely need to remove the bumpstop, or it will be hitting constantly, and ride like doo doo. If you are doing a C notch, the bracket gets cut out.
Old 04-10-2013, 10:55 AM   #103
naphtali5725
naphtali5725's Avatar
those bolt in c-notches just seems like it would make the rear of the frame flex at that point...
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-10-2013, 01:06 PM   #104
naphtali5725
before i go any further, can you guys verify i have the upper CA's on the right side
My build thread...
Disabled Veteran
Old 04-10-2013, 02:27 PM   #105
mooseknuckles
you're good.....
Old 04-10-2013, 03:25 PM   #106
naphtali5725
pressed in LCA ball joints, what a friggin pain in the a$$
installed Energy Suspension bushing upper/lower
that's all for today, will pick back up tomorrow...
My build thread...
Disabled Veteran
Old 04-10-2013, 03:27 PM   #107
naphtali5725
Originally Posted by mooseknuckles View Post
you're good.....
thanks moose!
My build thread...
Disabled Veteran
Old 04-12-2013, 11:36 PM   #108
luifer76
luifer76's Avatar
looking good bro, nice job....
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 04-12-2013, 11:56 PM   #109
77ChevySharkBite
77ChevySharkBite's Avatar
Nice man!!!! Looking sweeter and sweeter each time!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 04-13-2013, 07:58 AM   #110
naphtali5725
thanks guys, i appreciate it!
rained yesterday, hope to do some more today...
My build thread...
Disabled Veteran
Old 04-13-2013, 06:13 PM   #111
naphtali5725
flipped the cab over to work on the bottom, the PO butchered the tunnel, I assume to change to the TH400 that came with it.
I need to buy a grinder, a DA or hand sanding is not going to cut it...
will be installing LCA's tomorrow...
like I said before, I have both a 10 bolt, and a 12 bolt rear... trying to decide which one to go with since i'm waiting on the flip kit... decisions, decisions
My build thread...
Disabled Veteran
Old 04-13-2013, 06:49 PM   #112
77ChevySharkBite
What's the gears in the 10 and 12 bolt? Posi?
Looking good man, sucks the PO tore the tunnel up to only make it harder on you, but think of the positive something else you get to learn for experience
Korwin
Old 04-13-2013, 08:29 PM   #113
naphtali5725
thanks
Both are 3.08's unfortunately no posi...
the patch tunnel has enough overlap so I can seal it, and bolt/screw it back down to cover the hole. never know when I may need to get at the transmission or something... but who knows, i may weld it back together we'll see when I get to that point
My build thread...
Disabled Veteran
Old 04-14-2013, 10:54 AM   #114
77ChevySharkBite
Well I have a 12 bolt in mine with 3.42 gears and I love it, people have asked which is better out of the 10 or 12 bolt and from what I've seen it's gone both ways. So I think it's more of person preference more than anything.
Korwin
Old 04-14-2013, 11:07 AM   #115
naphtali5725
well i pulled the 12 out of the woods ...
My build thread...
Disabled Veteran
Old 04-14-2013, 11:09 AM   #116
naphtali5725
are there enough leaf's in these rear springs? LOL
My build thread...
Disabled Veteran
Old 04-14-2013, 11:13 AM   #117
77ChevySharkBite
More than enough lol! Supposedly from what a friends dad of mine told me is that back when our trucks were built they had a heavy duty rear end, with 8 leafs on each I think the typical leafs on a truck of our generation was 10 or 12 total but as you can tell there's 16 lol on the 12 bolt
Korwin
Old 04-14-2013, 11:15 AM   #118
naphtali5725
I believe 2" drop Bell Tech's
A PM and a pre-paid shipping label and they're yours...
My build thread...
Disabled Veteran
Old 04-14-2013, 11:19 AM   #119
naphtali5725
oops... look what else I found in the woods... my 67's front and rear
I just wish it had a track-bar rear
i guess it's my next project...
My build thread...
Disabled Veteran
Old 04-14-2013, 08:30 PM   #120
naphtali5725
since i have a 10 bolt that came with my truck, and a spare 12 bolt out of a Burb, I have been doing some reading...
it appears that a truck 10 bolt has a larger pinion than a truck 12 bolt, a car 12 bolt is stronger than a truck 12 bolt. so basically a truck 10 bolt is built stronger than a truck 12 bolt...will have to keep researching to see if it is worth the swap. if the truck 12 bolt is weaker, then i'll keep my 10
anyone confirm this?
My build thread...
Disabled Veteran
Old 04-15-2013, 12:04 AM   #121
wileecoyote427
wileecoyote427's Avatar
i like yer build droppin the 455 in there how are you gonna mount it with the 350 deisel mounts since they close or make new mounts and how radical of a motor is the 455 gonna be?
wileecoyote427 is offline   Reply With Quote
Old 04-15-2013, 07:15 AM   #122
naphtali5725
the olds 455 is an excellent motor, makes A LOT of torque at low rpm's without much work. mine will be a mild build, 10.1:1 compression, .030 over, stock heads and a pretty decent cam.
mine will make 500+ ft/lbs of torque from idle through 3000rpm. Peak HP will be around 4-4500 rpm... not too shabby, since the rebuild kit for one is only 700.00+, and the motor cost me about 300-400 i think.
will be using a TH400 tranny, that's why I am asking if a truck 10 bolt is stronger than a truck 12 bolt, i'll probably twist one in half with 500+ ft/lbs of TQ
all Olds engines are the same width between the motor mounts, it is the deck height that is different, the big block is taller...
so same motor mounts for the small block fits the big...
depending on circumstances, may need to use the two forward holes on the block to mount the motor mounts.
can use car or truck frame mounts, just have to use the motor mounts that fit the frame mounts(they have to match depth of the motor mounts etc.)... and of course will have to set the engine in, and figure out where you will need to mount the frame mount, may have to drill holes, or weld them in.
in my situation, since my truck is all apart, i'll set the engine/tranny in, and make sure i have it far enough back so my driveshaft fits, then i'll bolt in the frame mounts, and tranny crossmember and i'll be good to go.
My build thread...
Disabled Veteran
Old 04-16-2013, 10:52 PM   #123
naphtali5725
supposed to rain over the next several days.... so i may not have any updates until it dries out...
My build thread...
Disabled Veteran
Old 04-16-2013, 10:56 PM   #124
rs74
rs74's Avatar
Yeah it is heading your way. We are on day two of the rain.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-16-2013, 11:30 PM   #125
77ChevySharkBite
At least y'all's is somewhat predictable in Texas it can be 80 1 day and next day it be 60 and pouring down rain, it's safe to say Texas has it's own Eco system
Looking forward to the progress when you get it, we all have to deal with the elements one way or another.
Korwin
