Old 05-17-2012, 01:54 PM   #101
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: 67CST rebuild down under
Over 2,000 views already! This truck is going to be so bad a$$.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-19-2012, 05:12 AM   #102
aussie67c10
aussie67c10's Avatar
Thanks dave , i will be back home in 12 days ,to do some more work on the truck
BOWTIE OR NO-TIE
aussie67c10 is offline   Reply With Quote
Old 05-21-2012, 08:11 AM   #103
aussie67c10
a few more parts rolled up today. thanks brian atkinson
BOWTIE OR NO-TIE
Old 05-23-2012, 12:16 PM   #104
Krooked Kustoms
Krooked Kustoms's Avatar
Originally Posted by aussie67c10 View Post
Hey check this out , i brought a high/ low dimmer ac delco and look at the box , Made in china . ime a little disapointed .
I always get a little disappointed when I read that to haha coming along real nice mate! Bet your toungin to work on it. Just breath deep and count to 10, it won't be long :P haha keep it up mate! Cheers.
Krooked Kustoms is offline   Reply With Quote
Old 05-24-2012, 08:24 AM   #105
aussie67c10
MY new wipers rolled up today . they should clean up real nice.thanks tom aka tll 74.
BOWTIE OR NO-TIE
Old 06-03-2012, 07:18 PM   #106
Tinkermc
lookin good
Tinkermc is offline   Reply With Quote
Old 06-04-2012, 10:33 PM   #107
Krooked Kustoms
Updates?
Old 07-31-2012, 10:37 AM   #108
aussie67c10
I've been a bit busy with other things the last few weeks but i have some time now to do a bit more to the truck . the axils rolled up i pressed on the cclip eliminator kit and screwed in the new studs . dummy fitted the disc brakes ,it all looks ok . got the front end back from the painters and started to put that back together to.
BOWTIE OR NO-TIE
Old 07-31-2012, 10:41 AM   #109
aussie67c10
I will have more work done tomorrow so more pix to come.
BOWTIE OR NO-TIE
Old 08-02-2012, 05:04 AM   #110
aussie67c10
I put the diff in today all went well I got the radiator support back from the painters today. thanks brian for sending me a good one
BOWTIE OR NO-TIE
Old 08-02-2012, 05:57 AM   #111
aussie67c10
one more pic
BOWTIE OR NO-TIE
Old 08-02-2012, 12:14 PM   #112
67cheby
67cheby
67cheby's Avatar
Looking good !
67cheby is offline   Reply With Quote
Old 08-03-2012, 07:46 AM   #113
aussie67c10
I silicone the axil flange to the cclip for final fit and finished assembly on the top wishbones . put the rear brake hoses in place ,just have to make new hard lines
BOWTIE OR NO-TIE
Old 08-03-2012, 07:50 AM   #114
aussie67c10
Originally Posted by 67cheby View Post
Looking good !
BOWTIE OR NO-TIE
Old 08-03-2012, 05:20 PM   #115
sharpmark
great job you have done-like the way it is looking.
does the c-clip kit increase the width of the diff??
1969 stepside-305/4spd/12 bolt posi
http://67-72chevytrucks.com/vboard/s...d.php?t=477157
1968 pontiac lemans convertible-350/pwrglde/10 bolt
1934 oldsmobile sedan-350/350/12 bolt posi
1930 model a pickup-350/350/jag ind
1928 model a roadster-283/350/9"
sharpmark is offline   Reply With Quote
Old 08-03-2012, 05:29 PM   #116
Tuff Gong
Tuff Gong's Avatar
Your truck is going to be awesome!!! Great work. Please keep the up dates coming.
Tuff Gong is offline   Reply With Quote
Old 08-03-2012, 05:48 PM   #117
aussie67c10
Hi the c clip eliminator kit does not increase the width of the diff but if you are using stock axles there is some machining to do . i cut the diff 2.1/4 '' each side and used custom length moser axles . when i ordered the axles i told moser i was using a cclip eliminator kit and they machined the axles to suit.
BOWTIE OR NO-TIE
Old 08-03-2012, 05:51 PM   #118
aussie67c10
Hey Brian did you spot the radiator support you sold me. it cleaned up nice
BOWTIE OR NO-TIE
Old 08-03-2012, 05:54 PM   #119
Tuff Gong
Tuff Gong's Avatar
I sure did! I couldn't believe it was the same one! I'm really glad it worked out well for you.
Old 08-04-2012, 12:18 AM   #120
aussie67c10
here is the paper i got with the kit.
BOWTIE OR NO-TIE
Old 08-04-2012, 12:31 AM   #121
aussie67c10
nealy ready for the wheels
BOWTIE OR NO-TIE
Old 08-04-2012, 05:13 PM   #122
sharpmark
thanks for showing those instructions.
i've wondered how the kit works and as i have two 12-bolt diffs (pickup and oldsmobile) which both have wear in the c-clips and the axles move in and out over 1/2 inch will need something done about the problem.
kits are $425 nz here for a "strange" one
Old 08-05-2012, 02:15 AM   #123
aussie67c10
Hey bud just went to the strange web page on cclip eliminator , i dont like the look of there product , just throwing my ten cents worth in .
BOWTIE OR NO-TIE
Old 08-05-2012, 03:22 AM   #124
sharpmark
thanks for that.
that was one i found on trademe- our equivalent of ebay
will do some more homework before rushing in.
Old 08-05-2012, 05:19 AM   #125
aussie67c10
put the diff in for good and filled it up with oil . Here is a brake down of the cost 373/1 strange gears $450 Moser custom axles $700, yoke $90, Detroit locker $950, bearing kit $100 shorten housing $300, brace $160 build diff $300, total for a shortened 12bolt excluding brake set up is $3,050
BOWTIE OR NO-TIE
