Old 08-12-2012, 04:37 PM   #101
1947hillbillytruck
Re: Dutch 1955 build
I don't see any Koni carlift's around the shop.kinda wierd since you're dutch.....
-a pleasure to look at your work..keep it up!
1947hillbillytruck is offline   Reply With Quote
Old 08-12-2012, 04:51 PM   #102
63split
63split's Avatar
Koni only has hydraulic lifts and they cost 3 to 4 times more
and i doubt they make them there selfs
the 2 2post lift we have are spindle type lifts
some how these give me a more save feeling
63split is offline   Reply With Quote
Old 08-12-2012, 04:59 PM   #103
1947hillbillytruck
yeah they are very expensive,but unbeatable quality.thought they were made in holland,says so on ID plates on my lifts.
Old 08-15-2012, 02:13 PM   #104
63split
63split's Avatar
have been working on the shifter and handbrake assembly
and made 2 holes in the floor cover
found out i had room enough for the flush fuel cap
so i have lifted the fuel tank up 1.1/4 inch more into the frame and hides the tank a little more
also been working on the firewall filled up the piece i cut out, to give the right cillinder head some room.
also checked how the new doors fit the boddy, well they need some work
to get perfect staight and even lines all around
Old 08-15-2012, 04:05 PM   #105
Kim57
Kim57's Avatar
Looking good.
I'm thinking about using the same set up for my trans shifter and e-brake.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-15-2012, 04:39 PM   #106
63split
63split's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
it fits petty nice but only i have moved the e-brake up 4 inch
Old 08-17-2012, 02:08 PM   #107
63split
63split's Avatar
did some more on the firewall cleaned up all the holes pfff........
also got the new steering wheel in the mail last week
could not resist to put it on to see how it looks
Old 08-17-2012, 03:43 PM   #108
Kim57
Kim57's Avatar
Looking good. That's a nice wheel.
Kim
My build thread
Old 08-17-2012, 04:20 PM   #109
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Awesome work!
ChuckDriver is offline   Reply With Quote
Old 08-17-2012, 09:21 PM   #110
_Ogre
_Ogre's Avatar
i like the look
shave that standing seam and you will have this look
shop air compressor timer
Old 08-17-2012, 09:38 PM   #111
_Ogre
_Ogre's Avatar
to fix this...
my cab was worse, it had been dropped on the firewall (long story, don't ask)
an old time body man helped me straighten the cab
blue line is what we had, red line was what we were after
white brace is in line where he jacked the A pillar against the lower rear corner of the step well
he used a porta power body jack to move the cowl forward
might make your rear door seam better too
we jacked a lot, problem was we were afraid to go too far
we should have gone one more pull of the jack
now if i torque the cab on a twisty driveway entry, it chips the paint in that spot
Old 08-17-2012, 10:54 PM   #112
candyx
candyx's Avatar
Believe it or not ,that tool will fix anything that he's holding in his hand!!!
candyx is offline   Reply With Quote
Old 08-18-2012, 12:12 PM   #113
63split
63split's Avatar
that looks verry nice mmm i might need to do that too
Old 08-18-2012, 12:22 PM   #114
63split
63split's Avatar
to fix this...
dont think i need to do that because the fit is pretty close
and the door lines up to the A pillar
by jacking it up might mess that up
i will adjust the arc of the door to the cab
thanks Sander,
Old 08-18-2012, 02:28 PM   #115
63split
63split's Avatar
have been working on the left fender today
it had some nasty dent and didnt follow the contour of the door
had to tweak the brace to get it back in shape
then made a new piece and welded in in
the driverside door has a large gap in the rear and doesnt run parallel
and needs some adjustment here
but will first put the inner and outher roof panel in, that i will get in Monday
finaly.......
would be better to live in the Usa for that reason
also working on the bedwood
Some Q.
I have been looking for wheels for the Truck seen some nice stuff
from Raceline
now i am looking for a supplier who has Raceline wheels
i have tried Raceline directly, at first they answered promptly with sizes and pricelist. then i send them a 2e email for more specs and that i want to order
but got no answer, dead silence since ?
does any one know a good supplier i need 2 custom made wheels for the rear
thanks Sander,
Old 08-18-2012, 07:54 PM   #116
Kim57
Kim57's Avatar
You're doing a real nice job.
Sorry I can't help on the wheels.
Kim
My build thread
Old 08-19-2012, 11:02 AM   #117
oldman3
oldman3's Avatar
Sweet....Jim
oldman3 is offline   Reply With Quote
Old 08-19-2012, 02:15 PM   #118
63split
63split's Avatar
had some fight going on with the hood hinges
had 2 new ones but there crap they didnt close propperly.
compared them with the old ones and they end up in a whole different angle
and dive to deep down and hitting the cowl with hood not even fully closed.
ended up with the original hinges and now the hood closes nicely
also did some adjustment on the right fender
had a large gap it curved out from the cowl till half way the fender
here i need to add some matal to line up with the cowl
Old 08-19-2012, 03:45 PM   #119
Kim57
Kim57's Avatar
I think that is a common problem with these trucks. I had to fix mine in the same place.
Kim
My build thread
Old 08-19-2012, 03:48 PM   #120
63split
63split's Avatar
Kim
yes i saw it in your thread
Old 08-20-2012, 06:28 PM   #121
63split
63split's Avatar
today got some parts in inner and outher roof and seats
and checked out how they will look
then started cutting up more roof left overs
now i have the new inner roof i know exactly what i had to remove
all spotwelds drilled out
also bought a boattrailer fender will cut it in 2 for the mini tubs
Old 08-20-2012, 07:47 PM   #122
papastrk
A wide custom motorcycle rear fender makes a very nice set of wheel tubs. Just a suggestion. Very nice work so far!
papastrk is offline   Reply With Quote
Old 08-20-2012, 11:37 PM   #123
Kim57
Kim57's Avatar
I like those seats.
You've taken so much off the roof maybe you should just make it a roadster.
Kim
My build thread
Old 08-21-2012, 12:28 AM   #124
OrrieG
OrrieG's Avatar
Sure a lot of TF roadster talk on the forum lately. It is turning out nicely. chop or stock height cab?
OrrieG is offline   Reply With Quote
Old 08-21-2012, 12:40 AM   #125
JML55
JML55's Avatar
Nice work.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
