Old 09-26-2012, 12:48 AM   #101
mud.man.rj
mud.man.rj's Avatar
Re: 56 step/C5/C6 Z06 BBC
That is one very cool 6, oh ya.
mud.man.rj is offline   Reply With Quote
Old 09-27-2012, 11:01 PM   #102
Chevette
Chevette's Avatar
Got a couple of things done today. Fixed a mistake I had made on the front suspension and started to weld things up. Just about then I ran out of wire. Changed the spool and couldn't weld worth a $hit. Got that sorted out and made out ok. Got my front shock brackets welded in and welded the shock brackets on the rear.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 09-27-2012, 11:30 PM   #103
reinmeister1951
Looking Good. Did you get the easy grind wire yet?
Doug
48 chev LWB pickup 350 turbo400 tri power
48 GMC S10 350 700R4
48 che 5 window 2012 Camero suspension & power train
reinmeister1951 is offline   Reply With Quote
Old 09-28-2012, 12:42 AM   #104
Kim57
Kim57's Avatar
Looks nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-28-2012, 09:35 PM   #105
Chevette
Chevette's Avatar
No, but thanks for reminding me. I'll pick it up this weekend and let you know how well it works.
56 Chevy PU
Old 09-28-2012, 09:41 PM   #106
Chevette
Chevette's Avatar
Thanks, Kim. I'll be studying your bodywork threads real soon, as I will be shifting into that phase as soon as I get the chassis on the ground.
56 Chevy PU
Old 09-28-2012, 10:15 PM   #107
shadow1967
shadow1967's Avatar
Looking good. Make sure you post a lot of pics of chassis. Eager minds want to know!
Build for my 1959 Fleetside...
http://67-72chevytrucks.com/vboard/s...d.php?t=518308
shadow1967 is offline   Reply With Quote
Old 09-29-2012, 03:13 PM   #108
Chevette
Chevette's Avatar
Turns out I had made a mistake on the wire. My friend told me today that the wire he had mentioned to me was Silicon Bronze. Now I have to read up on it and decide whether I want to try it. He tells me using it doesn't warp the sheet metal as easily and it hammers very well. Trouble is I use 75/25 argon mix in both bottles and I must use 100% argon for the Silicon Bronze. This means I won't be trying it for a couple of weeks as one of my bottles is full and the other is 1/3rd full.
56 Chevy PU
Old 09-29-2012, 03:15 PM   #109
Chevette
Chevette's Avatar
Thanks Shadow. I'll make sure I do that.
56 Chevy PU
Old 10-03-2012, 01:44 PM   #110
Chevette
Chevette's Avatar
I did a little (heavy on the little) more work on the crown molding removal. I think I like the look. I guess I had better like it, because there's no turning back now. I think it will make the rear window look more centered vertically. I will take the peak off the face of the window frame (door) and remove the rest of the gutter and crown on the weekend to match it all up. I bought a Uni Spotter kit and 500 studs the other day. It will be interesting to see how many studs I use up trying to smooth it all out.
56 Chevy PU
Old 10-03-2012, 05:51 PM   #111
Kim57
Kim57's Avatar
Looking good.
That's going to be a ton of work to remove the peak.
Kim
My build thread
Old 10-04-2012, 01:35 AM   #112
Chevette
Chevette's Avatar
Originally Posted by Kim57 View Post
Looking good.
Kim
Um....why didn't you tell me that before I started. It's nothing compared to some of the mods you have done.
56 Chevy PU
Old 10-15-2012, 03:18 PM   #113
Chevette
Chevette's Avatar
Very little progress lately. However, I did find time to remove the crown molding from the drivers door.
56 Chevy PU
Old 10-15-2012, 06:17 PM   #114
Kim57
Kim57's Avatar
You're getting there.
Kim
My build thread
Old 10-15-2012, 08:09 PM   #115
xpickup
xpickup's Avatar
Chevette, looking good. I love the little changes. They are the ones everybody knows somethings different but can not point it out. Keep chopping.
Shannon
xpickup is offline   Reply With Quote
Old 10-17-2012, 09:57 PM   #116
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Great thread....Your doing great work...I will be back for sure
Nice to see someone so close to me doing such great work and I look forward to seeing it driving around
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 10-17-2012, 11:51 PM   #117
Chevette
Chevette's Avatar
Thanks for the kind words. I've been following your build, and it's very impressive. You'll be driving yours way before I get mine on the road.
BTW.........."Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away". Is that 45 mins before or after the new bridge is open? Are you in the Abby?
56 Chevy PU
Old 10-18-2012, 12:02 AM   #118
mud.man.rj
mud.man.rj's Avatar
That crown molding is a lot of work isn't it, nice job.
Old 10-18-2012, 12:21 AM   #119
wutnxt
Thanks man..
I hope my harness shows up friday ....and if it does I should be ready to fire next week...fingers crossed . That new bridge is a mess....I am glad I don't go into town often anymore......and ya you can put me down for Abby. Your truck is going to be killer when it's done you have done some great work.
Old 10-23-2012, 08:36 PM   #120
Chevette
Chevette's Avatar
Got the cab back off and started welding up the frame. I will use the shop crane hoist to lift the frame/frame table up for the tougher welds. My overhead welding skills are................not that good.
56 Chevy PU
Old 10-28-2012, 06:28 PM   #121
Chevette
Chevette's Avatar
Got a bit more done on the crown molding removal/replacement. I should have the other side done in a day or two, then do some dinging and dolly-ing. Got to watch how you say that.
56 Chevy PU
Old 10-28-2012, 07:04 PM   #122
xpickup
xpickup's Avatar
Chevette, looks great. It will be one smooth looking truck. Great job. I love all the subtle changes.
Shannon
Old 10-28-2012, 07:35 PM   #123
Kim57
Kim57's Avatar
Looks like your making good progress.
Kim
My build thread
Old 10-29-2012, 10:27 AM   #124
JML55
JML55's Avatar
Great work.
JML55 is offline   Reply With Quote
Old 11-08-2012, 08:51 PM   #125
Chevette
Chevette's Avatar
I got a bit more done on the chassis. Built and installed the cross brace. It ought to hold the frame rails steady.
56 Chevy PU
