Old 09-08-2012, 12:09 AM   #101
UPNADM
UPNADM's Avatar
Re: Attempting the "$50 paint job"
I would also use a cutting compound and a high speed buffer to finalize your finish.
Again, just my opinion.
UPNADM is offline   Reply With Quote
Old 09-08-2012, 12:14 AM   #102
mongoose
mongoose's Avatar
looks good.... this stuff is labour intensive lol, I left mine at 3 coats... wet sand and hit it with some scotch brite.. good enough for me!
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-08-2012, 09:32 AM   #103
slam59
Originally Posted by slinginrods View Post
Looks good! If you wanna save even more buy ace hardware brand oil based paint.this is my recipe for the industrial equipment I build,trailers,farm equip ,etc. we mix a 50/50 of paint and thinner,a small amount of hardener and add a few drops of "Japan dryer". Then spray it out of a 20.00 harbor freight gun.usually two coats.its smooth as silk nice and hard,.im seriously thinking about the semigloss that ace sells on my truck.i rolled the inside of the bed to give it the textured look.i love it easy to touch up. As far as the base /clear vs. single stage automotive paint.most beginners will do the base /clear due to being able to fix any poor technique by wet sanding buffing and or respraying.single stage takes more skill to get a good finish with.they both offer the same protection,actually single stage is less likely to peel than clear over color base due to poor adhesion.its all about the prep and product quality.my kid could spray base clear and I could cut and buff it and you'd swear it was a 5 k paint job.that wont fly with single stage.looks awesome !
Sounds interesting the way you do yours slingingrods. I hear alot of people use the inexspensive harbor freight guns with great success. By chance do you have pics of the 2 stage jobs you have done? My 74 is silver 2 stage and I am wanting to redo it myself in the same 2 stage type paint, and same color. Hood is flaking off clearcoat and other areas are starting to flake as well. Thanks.
1974 C10 swb 350
1977 3/4 ton Silverado 454
1999 2 door 2wd Tahoe
slam59 is offline   Reply With Quote
Old 09-08-2012, 09:22 PM   #104
tylervalo
Coat 9 is on, had to push it in the garage since it was raining all day. Gonna do 10 in the morning and she'll be done! Should I put the back window and doors back on tomorrow or wet sand everything while it's still off the truck next weekend?
Uploaded with ImageShack.us
How everything sits now:
tylervalo is offline   Reply With Quote
Old 09-08-2012, 09:27 PM   #105
frog210
Looks good
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-08-2012, 09:32 PM   #106
JRANGER
JRANGER's Avatar
awesome man
JRANGER is offline   Reply With Quote
Old 09-08-2012, 10:58 PM   #107
68Timber
I know the pieces fit
68Timber's Avatar
Looks great!
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-13-2012, 12:14 PM   #108
JRANGER
JRANGER's Avatar
So how did coat 10 go?
Old 09-13-2012, 12:31 PM   #109
tylervalo
It's looking great, I won't be back home til tomorrow. Saturday ill wet sand it with 2k then hit it with polish compound.
Old 09-13-2012, 12:32 PM   #110
JRANGER
JRANGER's Avatar
sweet! Cant wait to see it!
Old 09-13-2012, 01:06 PM   #111
frog210
I think I want to try this now but inside my cab
My cab inside is yellow, I want to a custom inside maybe like green and white, maybe have the inside
Done in white, you think it will get dirty quick?
San Antonio, TEXAS
-Frog
Old 09-13-2012, 06:15 PM   #112
Firebirdjones
Judging from that one close up shot earlier, as rough as that paint looked, 2,000 paper wouldn't even put a dent in that.
Unless this thing turned out nearly glass smooth with one of your recent coats, (again going off that last close up pic) I'd start with 1,000 to make quick work of it, then work your way up to 1500, and finish with 2,000,,,,then rubbing compound and buffer.
You'll be sanding for a month if you just start with 2,000
Firebirdjones is offline   Reply With Quote
Old 09-13-2012, 09:28 PM   #113
tylervalo
It's just paint, it'll stay as clean as you keep it I guess.
I hit it with 1500 before the last coat, I did a test spot with 2k and compound....turned out SWEET. But I was saving those pics for later
Old 09-13-2012, 09:33 PM   #114
cochino12
It followed me home?
cochino12's Avatar
you are taking too long, please get back to work on this! haha
Looks great man, I've been trying to wait patiently for updates
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-13-2012, 09:34 PM   #115
Firebirdjones
Oh I see, so you've been sanding it between coats....that makes life easier.
Old 09-13-2012, 09:40 PM   #116
tylervalo
Haha! I tried to get out tonight, but I gotta go in tomorrow for like and hour then head home. Just a 4hr drive back to Knoxville though, I'll get started back tomorrow evening. Probably best though, had I been home I wouldn't have been able to keep my hands off, at least the paint has had a week to cure.
Old 09-14-2012, 02:51 AM   #117
Devillusion
Devillusion's Avatar
oddly intrigued............can't wait to see this finished. Can't believe this stuff turns out so decent.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 09-14-2012, 09:28 AM   #118
JRANGER
JRANGER's Avatar
speaking of which...What are you doing on the bottom edges you have taped off??
Old 09-14-2012, 09:31 AM   #119
tylervalo
The bottom is going be done in black bedliner. I do plan to use it off road, figured it'd protect better.
Old 09-17-2012, 11:49 AM   #120
pontgta
pontgta's Avatar
Was just about to ask the same thing.
I can't wait too see the finish product.....
pontgta is offline   Reply With Quote
Old 09-17-2012, 12:54 PM   #121
tylervalo
No pic updates but it's looking nice. I hit it with rubbing compound and a polisher, someone more expirenced at sanding could make it look real nice, mine's about a 5 footer before little things in the paint can be seen. I had a really messed up issue with my credit card (no fault of my own) and won't have my new one til tomorrow. I'm going to 2nd day air a bunch of parts I need to put it all back together. I did already order the dash, should be here Wednesday.
Edit:
Also had a very weird issue with my battery, apparently the same ground I had been using forever decided it wasn't to rust and the truck was having issues starting. I had to sand down the ground and sure enough fired right up. I'm also having issues with the cigarette lighter, I don't know if my unit is shorting out or it's not being grounded but as soon as I touch the connector to the back it pops the fuse.
Old 09-17-2012, 12:59 PM   #122
JRANGER
JRANGER's Avatar
awesome! Look forward to pics
Old 09-17-2012, 01:22 PM   #123
cory d
cory d's Avatar
a 5 footer? dang. i would be happy with a 20 footer. i have an 80 footer now ha. but im only 21 and with long trips with a couple dirtbikes in the bed and my other hobbies, a 5 footer would turn into a 20 footer pretty quick
cory d is offline   Reply With Quote
Old 09-17-2012, 01:32 PM   #124
tylervalo
Haha! I feel you, 25 and recently divorced ( I went from a 427 C5 to this -_- but I love it anways). I'm sure I'll get my share of scratches, I use it to haul kayaks to the river when me and my buddies fish.
Old 09-17-2012, 08:31 PM   #125
str8axle55
Sounds like it is coming along nice....need pics. I`d be happy with a 5 footer, in that color as well.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD
84 Chevy K30 CC SRW
55 Chevy 210 2dr post
str8axle55 is offline   Reply With Quote
