Old 05-26-2013, 01:47 PM   #101
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Well I was able to get a few hours in yesterday and heres the results...
Frame front cut
Got the stock frame up on the table....damn this this was def hit at one time, was pretty ****ed up, bit more then I thought..made things a bit of a pain
And cut cut
Got the new frame up and partially set in place...still need to get everything all fully squared up before i tack it up to measure again lol...So as said its just kinda sitting there in pics.
Also got the 3/8 aluminum line im using for the airline, also got a nice little bender 180deg bender for it.
Bodied Blazer Build
http://67-72chevytrucks.com/vboard/s...d.php?t=611842
DrppdBlazr is offline   Reply With Quote
Old 06-02-2013, 12:01 PM   #102
DrppdBlazr
DrppdBlazr's Avatar
Bagged & Bodied 79' 2wd Blazer Build
Got the Rails all welded in and was able to shave some of the humps and holes on the front clip. Not quite done with shaving everything but its getting there slowly. All the welds will be ground down as well. Next up after front clip is done will be either 4-link or workin on the stock arms to make em work till I can afford mmw arms.
Bodied Blazer Build
Old 06-23-2013, 12:59 AM   #103
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Little bit of a lack of updates...sorry bout that...heres where im at now.. got more of the front driver side rail boxed in and smoothed. Gonna wait to box the very front till I lower the frame horns down the road. Also got the axled cleaned up a bit
Cleaned up the Axle
Got rid of the Steering Box mounting spot
Smoothed it and put in the rack notch
Started to box in this front section
Stencil
Cut out
Boxed
Welded up
Smoothed...little spots still need hit like that bottom corner
Bodied Blazer Build
Old 06-23-2013, 07:13 AM   #104
67cheby
67cheby
67cheby's Avatar
Re: 79' 2wd blazer
Looking great !
67cheby is offline   Reply With Quote
Old 07-01-2013, 09:59 PM   #105
96twodoor
96twodoor's Avatar
Re: 79' 2wd blazer
I just found this build , great work man ! keep it up
96twodoor is offline   Reply With Quote
Old 07-01-2013, 11:12 PM   #106
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Thanks man
Bodied Blazer Build
Old 07-01-2013, 11:32 PM   #107
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Ok back to it....
Got the passenger side boxed and partically cleaned up lol....
Moved on to the rear end and the MMW 4link
Passenger side
Gonna cap the little humps next
Panhard Bar
Bodied Blazer Build
Old 07-02-2013, 12:07 AM   #108
jmedero
jmedero's Avatar
Re: 79' 2wd blazer
OMG...... I will blame the next 6 months of rebuilding on you.
Looks great man.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-02-2013, 08:13 PM   #109
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Looks great man.
Lol thanks alot man. I'm glad my work is liked.
Bodied Blazer Build
Old 07-03-2013, 10:45 AM   #110
67cheby
67cheby
67cheby's Avatar
Re: 79' 2wd blazer
its all looking great man, you better slow down or your going to pass me !
Old 07-03-2013, 12:01 PM   #111
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
/\/\/\ lol your a funny guy mike. Catching up to you is just never gonna happen till your far done and moved on to your next project lol.
Bodied Blazer Build
Old 07-03-2013, 02:06 PM   #112
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 79' 2wd blazer
Amazing skills!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-08-2013, 08:02 PM   #113
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Originally Posted by 72BlckButy View Post
Amazing skills!
Thanks blckbuty, always appreciate hearing compliments
Bodied Blazer Build
Old 07-08-2013, 08:02 PM   #114
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Next......
Rear bag mounts
Degreased the motor a little
Did a quick plate job on lowers to test suspension travel
Plated the humps
Bodied Blazer Build
Old 07-08-2013, 10:17 PM   #115
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: 79' 2wd blazer
been following this build for a while and I have just got to say it. Amazing fab work!!! Keep it coming!
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 07-08-2013, 10:29 PM   #116
gclark1
gclark1's Avatar
Re: 79' 2wd blazer
I don't know if I wish I had your skills or not (that much more work on my own build if I did), but I am sure impressed. Keep up the grind in this AZ heat. It is demotivating for sure, but keep pressing on.
gclark1 is offline   Reply With Quote
Old 07-08-2013, 11:02 PM   #117
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Thanks for the compliments on the fab work guys, it's great to hear, It really is... And yes the heat def is demotivating that's for sure but you just gotta get through it lol. Water and fans is a must.
Bodied Blazer Build
Old 07-09-2013, 07:02 PM   #118
Low Elco
Re: 79' 2wd blazer
Fab work looks great! Dis oughta be smooove!
Low Elco is offline   Reply With Quote
Old 07-09-2013, 07:17 PM   #119
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Frame meet concrete
Bodied Blazer Build
Old 07-09-2013, 08:28 PM   #120
jmedero
jmedero's Avatar
Re: 79' 2wd blazer
So clean.
Old 07-10-2013, 09:21 AM   #121
bagged74
its just $$$$$
bagged74's Avatar
Re: 79' 2wd blazer
Looking good.
bagged74 is offline   Reply With Quote
Old 07-10-2013, 12:13 PM   #122
68Timber
I know the pieces fit
68Timber's Avatar
Re: 79' 2wd blazer
Beautiful. Awesome work man.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 07-10-2013, 12:16 PM   #123
67cheby
67cheby
67cheby's Avatar
Re: 79' 2wd blazer
nice work
Old 07-10-2013, 01:35 PM   #124
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Thanks all
Bodied Blazer Build
Old 07-12-2013, 07:05 PM   #125
DrppdBlazr
DrppdBlazr's Avatar
Re: 79' 2wd blazer
Got me a roller..... Kinda, don't have fittings to air up front bags but its almost there.
Bodied Blazer Build
