Old 05-19-2014, 11:06 AM   #101
MitchFloyd
MitchFloyd's Avatar
Re: Randy & Jakes 64 4x4 SLOW build
Those Old 6's (from the 216 thru the 292) are some tough ole steel! Boy they were built to work no matter what you did with them! Nice job on the finds. A new cam and lifters & I bet that thing will run pretty good for a long time.
'62 Chevy K10
MitchFloyd is offline   Reply With Quote
Old 05-23-2014, 05:26 PM   #102
RANDY COX
RANDY COX's Avatar
Well I got out there today and started painting on my engine to see what it's gonna look like, the Intake is aluminum color and exhaust manifold is Cast Iron color and the only Green I found that was maybe close was a diesel Alpine green. Here are some pixs just to get an Idea...
The Brackets and pulleys and fan are a semi Gloss black. Comments are always welcome.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-24-2014, 10:35 AM   #103
61K10
61K10's Avatar
looks good to me--------
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-24-2014, 01:40 PM   #104
McMurphy
McMurphy's Avatar
Looing really great so far !!!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 05-25-2014, 05:53 PM   #105
RANDY COX
RANDY COX's Avatar
well I got out there today and did some more painting on the engine, gonna wait til I get ready to put it in b4 I clean and paint the oil pan...
Gonna go tomorrow and see If a gentleman still has a 4x4 Cross member for the 292.
1964 BBC 402 4x4
Old 05-29-2014, 06:03 PM   #106
RANDY COX
RANDY COX's Avatar
Well I'm getting ready for the Transplant, gonna try and work on Firewall are while engine is out...
One thang at a time...
1964 BBC 402 4x4
Old 05-29-2014, 06:10 PM   #107
bj383ss
bj383ss's Avatar
Isn't it amazing how much better new paint makes everything look. Glad to see the Orange go away. I myself plan on using the same paint on my 350. Is this the Dupli Color brand. I also thought about using the cast iron color on the transmission. Is it Dupli Color as well?
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 05-29-2014, 06:51 PM   #108
RANDY COX
RANDY COX's Avatar
Bret
Yes all the paint is rattle-can Dupli-color got it all at Napa store
the black is a low gloss, all of them are hi heat 500 degrees. The green is
Detroit Diesel Alpine Green. And yes a fresh coat of paint brightens up a lot...
I put atleast 3-4 coats let dry in between coats... I'm happy with the way it
turned out...
1964 BBC 402 4x4
Old 05-29-2014, 09:20 PM   #109
chad64chevy
chad64chevy's Avatar
looking good randy
chad64chevy is offline   Reply With Quote
Old 05-30-2014, 11:28 AM   #110
1963c-10
1963c-10's Avatar
Engine looks great. Nice color choice!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-31-2014, 09:16 PM   #111
RANDY COX
RANDY COX's Avatar
Well I pulled the engine today and took off the power steering pump and brackets to be cleaned and painted, Took off bell housing it was very crudy inside, Just a lot of cleaning and repainting small things now. Still need to find the passenger side engine perch, A gentlemen gave me a cross member for the 292 but the right side perch was missing.
I fell like I've been beat up pretty good, after I sit for a while then get up I'm all stiff and
Limping...feel like an old man... the batteries are dead in my digital camera or I'd posted
pictures.... maybe tomorrow after church...
1964 BBC 402 4x4
Old 06-01-2014, 02:42 PM   #112
RANDY COX
RANDY COX's Avatar
1964 BBC 402 4x4
Old 06-10-2014, 07:13 PM   #113
RANDY COX
RANDY COX's Avatar
Still cleaning and painting
1964 BBC 402 4x4
Old 06-10-2014, 07:27 PM   #114
bj383ss
bj383ss's Avatar
Looking good man. Nice to see a nice painted frame instead of rust.
Bret
Old 06-14-2014, 09:06 PM   #115
RANDY COX
RANDY COX's Avatar
Well got out there today and started back on the firewall and still needed to cut the steering shaft cuz with the power steering setup on 70 frame the shaft was too long so the PO unbolted the column from inside and pulled it back about 2" thus leaving less gut room and hose clamped it to the bracket you can see in the picture how much is was. I proly cut 2" off of shaft...
so I'm gonna weld up the shaft and sleeve it.
Took off of the heater box to be painted and also sand the firewall everybit helps...
1964 BBC 402 4x4
Old 06-14-2014, 09:11 PM   #116
RANDY COX
RANDY COX's Avatar
I also cut off the 3spd linkage setup from off the column outside for a cleaner look..
1964 BBC 402 4x4
Old 06-15-2014, 12:08 PM   #117
61K10
61K10's Avatar
Randy--looking good! I put a tilt column and slid it all the way to the dash for more room. a little bit of paint sure does make things look good.
1961 chevy K10
Old 06-15-2014, 07:17 PM   #118
RANDY COX
RANDY COX's Avatar
well I wanted to see what some paint would look like and had some Green left over from the engine. The truck is gonna be green of some type guess I need to make a decision. I think I might just leave the undercoating on there as it's a pain to get off, and seeing that it's stuck on there pretty good might be a good thang for extra protection.
This green might look pretty good on the whole truck, It's the Detroit Diesel Alpine Green...
1964 BBC 402 4x4
Old 06-16-2014, 07:42 PM   #119
RANDY COX
RANDY COX's Avatar
She's green now.
Guess now I can bolt up the bell housing to the tranny and bolt up the clutch to the 292 and get ready to slip it into it's new home..The Green paint I used looks very close to the original color...which is the 503A Light Green.....
1964 BBC 402 4x4
Old 06-17-2014, 10:55 AM   #120
TJ's Chevy
TJ's Chevy's Avatar
Randy,
That 292 is looking fantastic! Rebuild kits are on ebay for as low as $320...You can also get lifters there to I believe...I know Napa has a rebuild kit for these as well...Call them an see if they have lifters. I'm fully hotrodding mine...more cam, punched out pistons, more compression, bigger valves, lump ports ect....But if ya ever need some info bout them...give me a holler.
Far as the frame and truck....Looking good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 06-17-2014, 04:13 PM   #121
RANDY COX
RANDY COX's Avatar
Thanks TJ I used to have an Inline 6 hotrodders book from Leo Santucci, there's a lot of good info in there to... The lump port looks easily enough.. I may have to build that other six for later.....
1964 BBC 402 4x4
Old 06-17-2014, 04:30 PM   #122
1963c-10
1963c-10's Avatar
Nice progress and I like the green. I left the old undercoating on both of my current builds. My logic tells me if its been there for 50years with no issue, why mess with it now. I also undercoated both of my firewalls, but not a coarse undercoating. Came out great!!
Old 06-17-2014, 10:48 PM   #123
C@rnut001
Your truck is looking great and coming along well. Keep up the amazing job that you are doing. Even if it is a little slow, it is all worth it in the end.
C@rnut001 is offline   Reply With Quote
Old 06-19-2014, 12:33 PM   #124
61K10
61K10's Avatar
Looks great Randy, keep up the good work! Green looks great also, though i might be a little predigest for some reason lol.
1961 chevy K10
Old 06-19-2014, 04:04 PM   #125
rusty76
rusty76's Avatar
Looking good dude.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
