#101 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Chummins Build
Looks nice! I'm sure it doesn't even know that boat is back there!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#102 |
Re: Chummins Build
just read entire thread great build an you are a master fabricator!!!! ;0
#103 |
Re: Chummins Build
Practice run for a car show this weekend. Very pleased how everying works. Ready to make the 100 mile trip.
![]() 55 is big but looks Huge at this angle ![]()
Old Iron & No Payments... My Chummins swap: http://67-72chevytrucks.com/vboard/s...d.php?t=565550 |
#104 |
Re: Chummins Build
They look great together!
#105 |
![]() Join Date: May 2012
Re: Chummins Build
[QUOTE=68Cummins;6326760]Practice run for a car show this weekend. Very pleased how everying works. Ready to make the 100 mile trip.
I like what you did, would like to see it one day and see how everything fits together...bets it a pulling dude...cool pickup. |
#106 |
Re: Chummins Build
Any updates? How is it running? Fuel economy?
#107 |
Re: Chummins Build
Well, im not so glad you have asked...haha
Managed to go all winter without getting any work done to it. Maybe we will get to the body work next winter? ![]() As for fuel economy, I don't have a reliable way to track mileage so its hard telling. The only time I checked, I got about 16mpg but I was hauling 10k pounds about 200 miles and I probably could have gotten better if I kept my foot off the coal dispenser pedal. As for not so happy you asked... The other week I pulled out and about lost my rear end. 100% my fault on the fabricating end. I known better than to weld to a factory heat treated plate. My mounting plates sheared between the bolts and my welds ![]() Driver's Side ![]() Passenger Side about to go ![]() I saved the 3/4T leaf springs from the donor chevy frame. I think I am going to take that route because 50% of the time I use this truck i am hauling something and I was never sure about the fact that all the weight was hanging the way it was.
#108 |
Re: Chummins Build
Shame to loose the nicer ride of coil spring - appears the mounts sheared b/c their distance away from the center of rotation (center of axle shaft), coupled with the tremendous torque of that 6BT. I think you'd be fine if you beef up that area 100% & reinforce your trailing arms. GM added additional top and bottom plating on 3/4 ton trailing arms also (which BTW it appears you're using pedestrian 1/2 ton "unreinforced" trailing arms), but I suspect you'll need a bit more with that engine.
#109 |
Re: Chummins Build
Maybe now is a good time to switch over to air bags.
#110 |
Re: Chummins Build
Just read your build. Nice work!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#111 |
![]() Join Date: Aug 2016
Re: Chummins Build
Ok so I know this thread is old but the bug was put in my head by a fellow gear head who's only ever owned Cummins powered vehicles. After reading your thread it looks like everything fits (even though it's a tight fit) how is the truck doing since your last update?
