Old 09-16-2017, 11:49 PM   #101
Jason7121
Jason7121's Avatar
Re: sprint_9's 72 C10 Project
Looking really good like the intake and firewall work.
Jason7121 is offline   Reply With Quote
Old 09-17-2017, 04:40 PM   #102
sprint_9
sprint_9's Avatar
Small fitment issue, door gap was pretty good though.
sprint_9 is offline   Reply With Quote
Old 09-17-2017, 06:32 PM   #103
gringoloco
A guy with a truck
gringoloco's Avatar
Looks good!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-18-2017, 12:29 PM   #104
sprint_9
sprint_9's Avatar
The wait is over.
Old 09-18-2017, 12:39 PM   #105
Jason7121
Jason7121's Avatar
Like the wheel choice. 20"?
Old 09-18-2017, 01:28 PM   #106
sprint_9
sprint_9's Avatar
20x8.5, 5.5 bs. 20x10, 5.5 bs.
Old 09-18-2017, 03:30 PM   #107
Jason7121
Jason7121's Avatar
Sweet it's going to look killer
Old 10-03-2017, 09:06 PM   #108
sprint_9
sprint_9's Avatar
Been a few weeks since I have updated
Finished up the welding and metal work on the cab for the most part, began work on a paint booth, and started mocking up the body one last time before I send some stuff to be blasted. The mock up has proven useful as I have found a couple gaps that need some attention and some fitment issues with the passenger door, Thanks to Brian (MARTINSR) for setting me on the right track with it.
I should maybe be ready to send the cab off to be blasted next week if things go well with the paint booth garage door and exhaust fan this weekend. I have one gap to work on that is cab related and the rest are on the fenders and doors.
When I put the cab on its back I had to take a step back take a picture and look at it, it was hard to believe I was almost done with it, and hard to believe how much work that was, what a relief.
Old 10-26-2017, 09:17 PM   #109
sprint_9
sprint_9's Avatar
Time to update.
Been working on the truck way to much but getting alot done. Its not going to finish itself and I want to be able to drive it next summer so I need to have a good winter.
The focus right now is on getting the cab, core support, and inner fenders done. All of those have been blasted and are in various stages of being completed. The core support I think is done as of tonight, I did a lot of learning and freshening up on technique on that piece. Bottom of the cab is done as well.
Also nailed down a basecoat color finally. I was originally going with the factory Medium Blue, but the more I thought about it I wanted something a little different. Ended up picking Grabber Blue off of the newer Mustangs, its an easier color to find since its newer and its a little bit bluer which is what I was looking for. Its also a solid color so it will hopefully be a little easier to shoot vs a metallic.
Old 10-27-2017, 12:55 AM   #110
Jason7121
Jason7121's Avatar
Everything is looking awesome great work.
Old 10-27-2017, 12:55 AM   #111
gringoloco
A guy with a truck
gringoloco's Avatar
Grabber blue will look good. That’s a great color. Core support looks slick!
-Chris
Old 11-13-2017, 12:27 AM   #112
sprint_9
sprint_9's Avatar
Thanks!
Got the cab cleaned up and sealed in epoxy, then I started filler work. Filler work has taken alot longer than I anticipated, but what else is new. Im hoping to get everything scuffed, cleaned, and get another coat of epoxy on it tomorrow. From there Im putting some 2k regular build primer on top of that, then focusing on the inside first. I hope to maybe base clear that some night this week depending on how things go. If my interior goes ok, and everything blocks out on the outside, I may base/clear the outside next weekend. But thats a big if, and so far my planned schedules have been blown into oblivion.
Old 11-13-2017, 12:46 AM   #113
Jason7121
Jason7121's Avatar
Looking good keep it up!
Old 11-13-2017, 08:56 AM   #114
builtbyKane
builtbyKane's Avatar
Looks like good progress from here. Seems every time I make a schedule it goes bad pretty quick so now I just do my best at getting in the garage every evening, even if it's for just 20min. Before you know it a decade has passed and your done, lol.
builtbyKane is offline   Reply With Quote
Old 11-19-2017, 12:38 AM   #115
sprint_9
sprint_9's Avatar
Thank you. I wont have to worry about having a decade pass on mine, Ill be evicted from the shop before that happens.
Seam sealer is done, I did the drip rail, some inside the cab, and some of the door opening lip where it meets the cab corner.
I cant even begin to explain how much trouble I had with the sealer in the drip rail. I ended up grinding half of it out as it set up too fast and looked like crap. Gave it another try with some different sealer and it came out great.
Tomorrow Im spraying some high build primer.
Old 11-20-2017, 01:49 AM   #116
Jason7121
Jason7121's Avatar
Self leveling seam sealer?
Old 11-20-2017, 09:49 AM   #117
Bennett68C10
Bennett68C10's Avatar
Nice job on the cab repair. I love the new wheels and that grabber blue paint will look awesome
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 11-20-2017, 05:09 PM   #118
raggedjim
raggedjim's Avatar
Great work! I also struggled with the drivers side rocker panel, had to cut it up just like you did to make it fit.
What seam sealer did you use in the drip rail? I need to do my jimmy.
Thanks, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-20-2017, 08:22 PM   #119
sprint_9
sprint_9's Avatar
Thanks, Rg
Thank you.
I used self leveling the second go around, 3m 08307 to be specific. I jacked the cab up with a floor jack so it was pretty close to level as that drip rail has a slope to it. On the sides above the doors where it curves down and goes vertical I used 3m 08308 but 8308 is a PIA to work with. One thing that really helped me with 8308 specifically was using a bondo spreader cut to fit and rounded to smooth the 8308. Using my finger didnt work that good with it. The 8307 you can just let do its thing if you have it level, I did have to do a little sanding on it but not much where my two halves met up in the middle of the rail.
I cant wait to spray some grabber blue, everyday I get a little bit closer. Featherfill on the firewall, and the rest of the cab got a coat of SPI 2k regular build. I had some spray gun issues so that didnt go as planned on the outside, inside turned out good so Ill just do an extra session of blocking on the outside if need be.
Spray guns are worth there weight in gold. Im using just a cheap gun for build primer, but I spent some money and bought an Iwata LPH400LV for epoxy and base/clear. Ive only sprayed some epoxy with it, but man, compared to my original base/clear gun which was also just a cheapie, it is no comparison. Every time I use it I love the results, it makes it just that much easier to spray nice.
Old 11-21-2017, 11:41 AM   #120
raggedjim
raggedjim's Avatar
Thanks sprint, the good thing about the jimmy is there's no vertical drip rail!
I also need better spray guns, but so far all I've been shooting is primer and acrylic enamel.
Nice work, Rg
Roger
'70 GMC Jimmy 2wd
Old 12-03-2017, 11:57 PM   #121
sprint_9
sprint_9's Avatar
Nice work, Rg
No vertical drip rail would be alot better.
Got my blocking done, sprayed a coat of epoxy reduced down as a sealer, and got my base on. Everything has come out pretty good so far, couple small spots but I think they will be fine.
Clear coat tomorrow, I cant wait.
Old 12-04-2017, 12:41 AM   #122
BIGglaSS
BIGglaSS's Avatar
Looking good! Following along...
BIGglaSS is offline   Reply With Quote
Old 12-04-2017, 01:08 AM   #123
gringoloco
A guy with a truck
gringoloco's Avatar
Where’s the wolf whistle emoji? Looking great!
-Chris
Old 12-04-2017, 01:34 AM   #124
Jason7121
Jason7121's Avatar
Looking great can't wait to see more!
Old 12-04-2017, 02:56 PM   #125
knomadd
knomadd's Avatar
Looks good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
