06-11-2015, 10:55 AM | #101 | |
Re: factory grease pencil marks?
CHEVY/GMC VIN DECODERS |
06-11-2015, 12:01 PM | #102 | |
I have been finding this to be completely constiant on trucks also. Nothing or a T for standard trim trucks, 2T for Z62 mid level trim trucks and 4T for upper trim level trucks. I have found 4T on both Z84(CST/Cheyenne) and YE9(Cheyenne Super) trim trucks. Can't tell much about your engine/trans codes. The engine code looks like S9A, which could be short for LS9AA. Maybe the L got worn off or was never there. Can't tell much about the trans spot. Very nice blazer you got BTW.
09-22-2015, 09:56 PM | #103 |
Carpe manana
Here's the same painters mark on my "new" Fremont built 72 C30:
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-22-2015, 10:28 PM | #104 |
Awesome, Thanks for posting it. Any chance you have a "D" on the other side?
09-22-2015, 10:35 PM | #105 |
Carpe manana
[QUOTE=bruceman1968;7317395]Awesome, Thanks for posting it. Any chance you have a "D" on the other side?[/QUOTE
Yes, the "D" is there! It's subtle but there. Can post pic.
09-23-2015, 01:08 AM | #106 |
I love all the documenting. Of course the Corvette folks have it down, not only putting grease pencil marks back on but making sure the paint is not too good in certain areas and making sure there is overspray where it would have been from the factory.
Ive included my firewall penciling. Also when I bought my current daily driver I asked the dealer to not do anything to it once it was off the carrier. They, of course, had to check fluid levels etc but they were kind enough to not do any pre-delivery cleaning or removal of stickers, plastic, etc. Yes, my wife thinks I am crazy. Maybe if I keep it for 40 years someone will think it's cool. Though now I worry about leaving the protective plastic on because it may ultimately cause damage.
The lid is stuck on my jar of anti seize |
09-23-2015, 07:17 AM | #107 | |
Trucks can have up to 7 plants at the same time, two or three shifts of production and upwards to 70 jobs per hour. There's a lot more variation in that scenario. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-23-2015, 09:59 AM | #108 |
Yes, without a question. Hopefully I'm up for the challenge. It is interesting seeing the differences by plant.
09-23-2015, 11:12 AM | #109 |
A pic would be great. Thanks for posting. I know most owners wouldn't care about something like painters signing their work. I just think it's very cool and ties the truck to the people that built them. I'm also amazed that they got away with it for so many years. I'm pretty sure the General would not have approved.
09-23-2015, 11:32 AM | #110 |
We’ve talked about the variation between plants, and the variation within an assembly plant due to different operators.
What we haven’t talked about is how many different operators might be on the same job, even within the same day. This might be an appropriate place to take a second and do so. Some assembly plants shut down for “break times”. The UAW required 6 minutes of break time for each hour worked, distributed into a break in the morning and a break in the afternoon (not counting ½ hour for lunch). If that operator never takes an additional break (to use the bathroom, or for a medical issue) then you might only have one person on that job per shift. This is probably what you would expect. However – some plants use a “rolling” break technique. Said differently: the line doesn’t shut down for break, and there is a staff of “utility men” or replacement workers who go to each job and give that worker a break individually. After that assembler comes back the relief man goes to the next job* and gives that assembler a break, until everybody in the area has been covered - all this while the line keeps rolling. If you had a different relief man covering the morning break vs the afternoon break then you are up to three operators per shift; times the number of shifts (two or three); so you could have as many as 9 people touching those parts for a three shift productive operation. That assumes the person doesn’t need a quick respite, covered by a different utility man, quality man (the foreman’s right hand man) or the foreman himself (in some cases) at some other point during the shift. I say all this to say: there could be between 1 and 8 or 9 people performing the same job in the same assembly plant within a given 24 hour period. That introduces a whole ‘nother level of variation. K *one nuance to note here is that there was a person (several, actually) who could do any job within a foreman’s designated area. I was able to do every job within my area (approx 27 different operations) – sometimes more than one at once(!).
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 09-24-2015 at 11:41 AM. |
09-23-2015, 11:32 AM | #111 | |
K
09-23-2015, 12:26 PM | #112 |
09-23-2015, 10:24 PM | #113 |
Carpe manana
Here's the subtle "D"
09-23-2015, 10:55 PM | #114 |
Carpe manana
Here's another posted on a recent thread: http://67-72chevytrucks.com/vboard/s...d.php?t=683170
Look closely - see "Mustard"
09-23-2015, 11:16 PM | #115 |
This was on the outside bed front panel on mine.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
09-24-2015, 11:08 AM | #116 |
Thanks DH, Here's the same two painters on coleys truck.
Looks like they also painted mgkgmc, Lee H, Rifleman, 70shortfleet and 72Dually trucks. You guys should start a club.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 09-24-2015 at 01:50 PM. |
02-09-2016, 10:13 PM | #117 |
05-17-2016, 06:41 PM | #118 |
I have a 68 GMC ambulance and on the firewall is a series of numbers that span from right side to left side, i would love to know how to decode them and see what they all mean
05-17-2016, 07:49 PM | #119 |
These numbers are stenciled on the left frame rail behind the left rear wheel on my 71 GMC Longhorn.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
05-17-2016, 07:53 PM | #120 |
These grease marks are on the frame of my 72 1/2 ton Cheyenne Super. The first is on the front crossmember and the second is on the rear crossmember
02-06-2017, 03:25 PM | #121 |
Hi, all. Super informative thread. I believe i have what is the model number on the firewall of my 1967 K/10. It reads KE10704 and should breakdown as a 4x4, V8, 1/2 ton, swb, stepside. The numbers are hard to read but there nonetheless. The spid is hardly legible, only able to make out portions of the vin, so i wanted to be sure i was reading it as others would. Thanks!
- Robbie UNITED BY TRUCKS - classic truck video content YouTube: www.youtube.com/c/unitedbytrucks Instagram: @united_by_trucks Paw Paw '68 508 Dark Blue Custom C10 Teddy '68 GMC SWB 503 Light Green LS Build Mississippi Mud '75 Skyline Blue Patina SBC Build |
06-19-2019, 11:31 PM | #122 |
I'm trying....
Digging up this thread because I think all the marks previously identified on this and other threads have been pretty well explained or decoded by Keith and others...except for these driver's side cowl numbers. They have an obvious pattern--but I can't suss out their meaning. Hoping fresh eyes might have an idea.
1970 K20 Z62 https://67-72chevytrucks.com/vboard/...56#post9334756 1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
06-20-2019, 05:54 PM | #123 |
Thanks for the replies somehow I have missed all these responses to the GMC it is really cool to see other trucks with the same initials and markings. Neat to think the same guy wrote on all these trucks only if we knew who the employee was.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer Last edited by mgkgmc; 06-20-2019 at 06:06 PM. |
06-20-2019, 06:03 PM | #124 | |
K
07-07-2019, 08:47 PM | #125 |
I'm trying....
Here are stamped sequence numbers on our Fremont donor cab. One is just above the firewall and the other is on the back of the cab just above the bottom. Both are on the truck midline (nothing on the driver's side cowl corner as shown in previous examples in this thread.
...(another shout out to smbrous70, yours was a St.Louis 44, this is a Fremont 44)
