Old 03-29-2015, 01:21 PM   #101
greenmonsterC20
greenmonsterC20's Avatar
Re: RideTech's New C10 CoilOver Kits
I wanna get this for my c20.
69 C20 3/4 Ton 350 TH400
63 Buick Rivera 407 Nailhead TH400
greenmonsterC20 is offline   Reply With Quote
Old 03-31-2015, 08:29 AM   #102
chase@ridetech
chase@ridetech's Avatar
You can but you will have to modify the end links.
chase@ridetech is offline   Reply With Quote
Old 04-04-2015, 10:15 AM   #103
greenmonsterC20
For the sway bar?
Old 04-28-2015, 09:24 AM   #104
chase@ridetech
Originally Posted by greenmonsterC20 View Post
For the sway bar?
If you are trying to use the factory sway bar
Old 04-28-2015, 10:45 AM   #105
aod92
aod92's Avatar
Here's mine complete. Just have to install the front muscle bar.
aod92 is offline   Reply With Quote
Old 04-30-2015, 10:31 AM   #106
chase@ridetech
Your Frame looks great! paint or powder coat?
Old 04-30-2015, 11:15 AM   #107
aod92
aod92's Avatar
It's powder coated. There is a company by me that blasts and powder coats a frame for $300. Couldn't pass it up at that price!
Old 05-06-2015, 11:46 PM   #108
greenmonsterC20
I dont plan on using the original sway bar.
Old 05-06-2015, 11:47 PM   #109
greenmonsterC20
That looks awesome!
Old 08-07-2015, 11:58 AM   #110
Farm Truck Frank
Farm Truck Frank's Avatar
either one of you guys that has this installed, and specifically for Kook87, what is your tire setup? I'm looking at pulling the trigger on this shortly. thanks and glad to be here.
Farm Truck Frank is offline   Reply With Quote
Old 08-07-2015, 12:00 PM   #111
Kook87
Kook87's Avatar
Kook87 is offline   Reply With Quote
Old 08-07-2015, 12:02 PM   #112
Kook87
Kook87's Avatar
275/40/20 rears and 245/40/20 fronts. Largest I can run an no rubbing issues. I had 295/40/20 on rear but they rubbed so I sold them and went with the 275s.
Old 08-07-2015, 12:05 PM   #113
Farm Truck Frank
rubbing was on which side, just curious. thanks for the reply. your stance is exactly what I am going for. I may have more questions, sorry in advance, lol. Thanks man
Old 12-01-2015, 04:29 PM   #114
MMcMasters
MMcMasters's Avatar
Kook,
First off your truck is beautiful!! If you don't mind, what wheel width's and backspace are you running. We just received the Ridetech level 2 system for my son's 67. I would love to buy him wheels for Christmas but the truck won't be together for a few months.
Thanks,
Mike
MMcMasters is offline   Reply With Quote
Old 12-01-2015, 06:16 PM   #115
Kook87
Kook87's Avatar
Originally Posted by MMcMasters View Post
Kook,
Thanks,
Mike
Thanks. My rear end is narrowed
20x8.5 5.5 " front
20x10 4" rear
Don't sweat the petty things and don't pet the sweaty things.
Old 12-01-2015, 08:09 PM   #116
Hugger67rsss
Hugger67rsss's Avatar
Here is a pic of mine close to finished, wanted to add a 60-66 truck for reference. It's has 18x11 and 18x12 wheels. 315 front tires 335 rear. Love the stance and the front will come down about an inch still. Hard to beat Ridetech parts, this is my second kit I've installed.
Aarik Gault
1966 GMC SWB, Ridetech Suspenion
1968 Camaro autocross/track car
Hugger67rsss is offline   Reply With Quote
Old 12-01-2015, 08:27 PM   #117
duallyjams
duallyjams's Avatar
are going to use the stock inner fender ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-01-2015, 08:30 PM   #118
Hugger67rsss
Rears are factory with a 3" strip added, front will have to be trimmed across the bottom. The height of the front inners will work, just have to make room for the turning radius.
Aarik Gault
Old 12-02-2015, 12:06 PM   #119
MMcMasters
MMcMasters's Avatar
20x8.5 5.5 " front
20x10 4" rear
Thank you sir!
Old 12-02-2015, 03:45 PM   #120
GMC Canuck
I'm using this kit with the muscle bar and nolimit rack and pinion.
the sway bar interferes with the rack (or vice versa) Is there longer end links available or any suggestions as to the best way to safely lengthen the end links.
The links do come apart and it looks they are held together by a m12 -1.75 threaded rod. I'm not sure a longer threaded rod is the strongest / safest method. I need about another 2.5"
GMC Canuck is offline   Reply With Quote
Old 04-01-2016, 01:06 AM   #121
1000rrstunna
Just got the full level 2 kit and front swaybar. I was going to go air ride on my build but since it's my first ever frame off I decided to keep it simple so that I didn't get in over my head with fab work. Can't wait to start installing it.
1000rrstunna is offline   Reply With Quote
Old 04-01-2016, 09:41 AM   #122
MMcMasters
MMcMasters's Avatar
Ridetech stuff is very nice and the fit/quality is excellent. We used their coil over system on our Chevelle as well and couldn't be happier.
Old 04-01-2016, 10:24 AM   #123
MMcMasters
MMcMasters's Avatar
Sorry about the little picture, here is a better one
Old 04-06-2016, 08:44 AM   #124
chase@ridetech
Looking good!
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
Old 04-17-2016, 09:36 PM   #125
aod92
aod92's Avatar
I have this kit on my truck and the bottom control arm sits about 1-1/2 from the ground. No matter how much you change the spring height on the coil over the control arm will stay in the same place right? I took my truck for a ride and the control arms scrapped the ground multiple times.
