10-22-2013, 07:55 AM | #1 |
Re: Crossing over, the 65 rebuild.
looks great
70 SWB STEPSIDE 70 BLAZER 09 challenger |
10-22-2013, 09:57 AM | #2 |
The truck is coming along very nicely.
10-22-2013, 10:48 PM | #3 |
I was wondering where you went.
Nice score ! Even nicer redo ! Gee when do you have time to work at your job ? What a great place to work ! They let you go nuts on your own stuff there. I assume after hours of course. Gee on your trip south you past just 1/2 mile from my place. Wish I had known we could have met.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
10-23-2013, 01:14 AM | #4 |
Hey Glen,
Welcome over to here! Ill look you up on the next In and Out burger run. A few Saturday's a year ill grab a couple friends, leave at 7am and hit Redding In and Out on Hill Top by noon. Its the closest one to Eugene. The owner of our Dealership is very active in our community with the car scene and loves classics. I run the body shop and have a couple technicians that like to put in a couple hours extra most days to meet bonus which allows me (the guy with the key) to stay and tinker on my own stuff. Unfortunately I run out of small stuff (mini bikes, old gas cans etc) and have moved into stuff with tires. |
10-23-2013, 01:17 AM | #5 |
10-23-2013, 02:10 PM | #6 |
10-23-2013, 03:05 PM | #7 |
Very Nice
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
10-24-2013, 12:27 AM | #8 |
My bolt in notch didn't show up as I was hoping when the bed was loose and the boards off so at lunch I called in an order at the Steel shop. Picked up some 1/4 plate stock to box the frame and a 6" pipe to hack up and build a notch. Fired off the hot wrench and had at it after work. Roughed in the notch before dinner and will order a pizza for lunch tomorrow so I have enough cardboard to mock up the box plates. Should be all welded up , finished and painted by dinner tomorrow. Fitting all the bed boards and the million nuts and bolts Friday night. Hoping to get the first stage of the suspension done this weekend....dropped spindles, blocks, cut a coil etc and do some smokey burnouts. Air system will come a little slower and piece by piece in the eves and weekends so we can still drive it . Dual master came in with adjustable prop valve. I was going to toss that in this weekend and build some lines, but chose to order a complete prefab kit from inline tube to see what a line kit is like. I've always built them, but it takes time and I don't have many nice weekends left here in the NW so taking the dogs out as much as I can lately.
10-25-2013, 05:19 PM | #9 |
Post Whore
Looking cool!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
10-25-2013, 06:38 PM | #10 |
10-25-2013, 08:13 PM | #11 |
Truck looks bad ass John. This is Jon from the Leadheads. I need to spray my bed with that bedliner.
Jon Carr |
10-25-2013, 08:23 PM | #12 |
10-26-2013, 08:41 PM | #13 |
Finished plating the frame, grinding , painting and re squared the bed to the cab. What a pain in the A! 66 1/4" bolts and my arm is sore. I once saw a post "8 hours later the bed is together" and I thought no way, now I know he wasn't kidding. Next will be the 2"blocks, 2 1/2" spindles, cut 1 coil all the way around, dual master, disc front, disc rear, adjustable pan hard and shock relocation front and rear then wait for the bags. I'm going to tuck the tank, compressor, manifold etc to get ready, save some coin and hopefully get some tubular pocket lowers and an air management system.
10-29-2013, 10:15 AM | #14 |
Absolutely love it Fish!!I actually have a '64 GMC sitting at my In-laws waiting to be revived!
10-29-2013, 11:01 PM | #15 |
Thanks Coach! Greetings from over here.
Drilled and installed the rest of the stainless carraige bolts around the wheel tubs tonight. Ran the PO's speaker wires through grommets in the A pilar vs. Around the door gasket and into the cab. Need to figure out a better locking system, the oe plunger lost its keeper and spring and I'm missing some parts (I think they fell through the drain slot in the door ). Searching for "power locks" "ele,ctric locks" and looks like a dead end. The heaviest actuator I can find is 12 lb and the handle / latch seems a little heavier. Anyone install power remote locks and have some pictures? |
10-30-2013, 10:25 AM | #16 |
Great progress- lovin' how it's coming out! When we did the '70's bed, the air ratchet was my very best new friend!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
10-31-2013, 01:30 AM | #17 |
Thanks LowElco. I can't believe how many there are. Chevy had to set a record with the number of fastners used in a bed when they engineered this.
Today I sourced an extra wiper knob and escution. My delay wiper system arrived and at lunch I installed it. The system literally falls into place in 3 minutes. I shoved the potentiometer through the O.E. choke hole next to the wiper switch and secured it with the provided nut. I enlarged the ID slightly of the extra escution and pressed it onto the retaing nut. Slid the wiper knob on and tightened it down. Hooked up a couple wires, secured the ground ( the longest part of he install) and the system works like a charm and fills the hole that the choke used to occupy. Pics tomorrow along with another trick or treat. Happy Halloween everyone! Here's the link to the delay sold her by another member: http://67-72chevytrucks.com/vboard/s...d.php?t=592083 |
10-31-2013, 11:02 PM | #18 |
11-01-2013, 12:16 AM | #19 |
Rollin' Old Skool
Bed liner turned out nice, & I dig the dash cluster too!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
11-01-2013, 01:25 AM | #20 |
The truck looks great, man. Maybe I'll get a chance to see it live one of these days. I think the changes so far are giving the truck a nice look.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
11-01-2013, 11:43 AM | #21 |
Post Whore
Truck is coming along nicely! Keep up the good work!
11-01-2013, 04:35 PM | #22 |
Nice work!! I love the orange and white! Looks killer!
-Christian '91 318IS AW2 on black slow daily build 1Bad37: C5 Corvette Meets '37 Chevy |
11-01-2013, 06:20 PM | #23 |
Delay wipers, bed liner, the makings of a DD.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
11-01-2013, 08:13 PM | #24 |
this how someone takes a nice truck and turns it into a really really nice truck!!!!!!!!!!
11-01-2013, 08:40 PM | #25 |
Thanks guys! My wife keeps asking when she gets to drive it.
. It won't be a full time DD for her, the heated seats in her 2007 4x4 (but lowered 3" hehe) keep her comfy. I still want her to have the creature comforts like the intermittent wipers, squirt, heat, starts and runs every time etc. I didn't get much done on it in the last few days. A dog run plastic coated cable, a lock cable for my vintage fuel can, some speaker wire stuff. We have been busy at lunch and after work doing a motor swap, cab, bed, front end swap with repaint on my buddy's 76. Tonight I tackled the later cluster tach mod with volt meter instead of the old Ohm meter swap. 1st try and success! . We started on it 2 weeks ago, he had the 1st week off for vacation and spent it at work disassembling , prepping and reinstalling stuff as another buddy and I painted everything. 454, TH400, 3:88 , 37's, 60's etc with new interior, wiring, dash, exhaust, motor swap and a ton of little tid bits. It's been like 2 guys Overhaulin in 2 weeks! Cool thing is he bought it new in 1976 at the dealrship we both used to work for. It was a 2x, 350 truck and hass evolved into his mud, snow and sand dune toy. Last edited by NEWFISHER; 11-01-2013 at 09:06 PM. |
