Old 04-25-2014, 07:33 PM   #101
SCHRUMGMC
SCHRUMGMC's Avatar
Re: Project "Schrum" 1959 Gmc 100
Well, I'd like to go with Electronic ignition Orge
Now my Horn isn't working.I know it isn't the fuse, because I just replaced them..The relay is old as dirt
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 04-25-2014, 07:40 PM   #102
lowrodderchev
lowrodderchev's Avatar
man bro if it wasn't for bad luck you'd have no luck at all I rewired my whole truck but have yet to run power to it so I may be on the same sinking ship
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 04-25-2014, 08:34 PM   #103
SCHRUMGMC
SCHRUMGMC's Avatar
Welcome to my world
Ordered a New Horn Relay from O'reillys so hopefully that'll fix the problem
Where is the best place to get new tail light wiring?
1971 GMC Sierra
1959 GMC 100
Old 04-25-2014, 09:03 PM   #104
lowrodderchev
wire it yourself buy some wire bro 2 wires that's it you can buy the harness from classic parts
Old 04-25-2014, 09:06 PM   #105
SCHRUMGMC
SCHRUMGMC's Avatar
The Speedometer cable won't come out where the Transmission is? Its pissing me off, I've sprayed WD-40 on it...Still nothing, I've tried pliers
1971 GMC Sierra
1959 GMC 100
Old 04-26-2014, 11:28 PM   #106
SCHRUMGMC
SCHRUMGMC's Avatar
Well I know my Dimmer switch to works. I am guessing my headlight switch works fine..but all that doesn't work, is the Dome light. Still trying to figure out why the Right indicator light isn't blinking correctly
All of the Dash lights worked, just checked them..Dimmer switch works fine. Dome light and right indicator light doesn't working... Guessing the flasher is shorting out
The tail lights wiring has Fuse links in it so another sign of MAJOR ISSUES.
Cleaned the Fuse area and grounding wiring
Lost the Barb fitting on the end of the Vacuum line, don't ask how.. I have no damn clue !! Thankfully I have another one on the extra Vacuum advance
The truck still wants to die when I press the Gas pedal at times, I am guessing its because the Vacuum lines not hooked up
1971 GMC Sierra
1959 GMC 100
Old 04-27-2014, 01:15 PM   #107
_Ogre
_Ogre's Avatar
pm lowrodder and get his distributor for shipping. he has already offered it.
buying new parts instead of testing them is often a waste of money.
harbor fright has free multimeters right now.
pick one up and get to know how they work.
the horn rely is hot and also the main power feed for the whole wiring system
the horn button grounds the relay to make the horn work
figure out what is wrong with the system before buying parts
usually it is the horn button, easy to test by unplugging the horn button wire and ground the wire to the relay
shop air compressor timer
Old 04-27-2014, 02:52 PM   #108
lowrodderchev
funny I was looking for missing visors for my truck and found another distributor
Old 04-27-2014, 02:55 PM   #109
SCHRUMGMC
SCHRUMGMC's Avatar
Turns out it was the relay !!! Bought one from O'reillys and sure enough once I plugged it in it worked a lot better. I mean I've heard bad things bout the HEI so Im not sure about it to be honest. I've tried wiggling the old speedo out of the Transmission and it will not twist off..So I'm stuck !!!
1971 GMC Sierra
1959 GMC 100
Old 04-27-2014, 03:59 PM   #110
lowrodderchev
PB blast!!! makes WD-40 look like water ive remove broken rusted bolts out of exhaust manifolds with it they have it at oreillys
Old 04-27-2014, 05:56 PM   #111
SCHRUMGMC
SCHRUMGMC's Avatar
Fiddling with the Wiring, I got the Vacuum Wipers to work as they should(I think)
It starts up on command now.Making some good progress.
They move now.Theres a hole in the Vacuum wiper hose to the manifold, and I'm going to wrap it up. Running great, I still need to hook up the Vacuum Advance. It blows out some smoke? Guessing thats normal...its not much, only when I start it up very little
1971 GMC Sierra
1959 GMC 100
Old 04-27-2014, 06:23 PM   #112
OrrieG
OrrieG's Avatar
Found this while looking for something else, 1959 factory turn signal wiring diagram, looks like the flasher is just up under the dash.
OrrieG is offline   Reply With Quote
Old 04-27-2014, 06:33 PM   #113
SCHRUMGMC
SCHRUMGMC's Avatar
So that makes the flasher on the Left side of the dash towards I'll have to look tomorrow
Thanks Orrie
1971 GMC Sierra
1959 GMC 100
Old 05-02-2014, 01:21 PM   #114
SCHRUMGMC
SCHRUMGMC's Avatar
Okay UPDATE
Finally got the old Speedo Cable housing out off of the Transmission
Put the new one in, on the Gauge, and the Tranny
Gauge still doesn't work, I am starting to think that, that Plastic gear thing has pretty much worn itself out
1971 GMC Sierra
1959 GMC 100
Old 05-03-2014, 02:07 AM   #115
Daze57
Daze57's Avatar
if you are ambitious you might want to carefully take apart the speedo to see if anything is stuck ,
dont force anything just give it a good light cleaning and check for anything loose or gummed up
might be in the speedo head
juss sayin is all !
Daze57 is offline   Reply With Quote
Old 05-04-2014, 01:13 AM   #116
SCHRUMGMC
SCHRUMGMC's Avatar
I looked all up in the Dash, no signs of a Flasher it has to be there somewhere
Ever since i've replaced the Horn relay, the trucks horn is perfect
Making a future reference list
54-59 Stepside - SS 99.00
55-59 Cab Corner - $25.00/ $50.00 for both
55-59 Rocker Panel with Step - Left and Right $58.00/$116 for both
55-59 Door Bottom - Outer - Left/Right $36.00/ $72 for both
Door Hinge Access Panel $23.00
55-59 Cowl - Air Vent Patch Panel - Left $65.00
57012354 55-59 Door Bottom - Inner - Left $68.00
$493 Total, plus Tax
$200 Welding = $693+ $90(Headlight Bezels)=$780
I'll have $600 invested before the truck is done body wise.. and $1,000 with some extras
Lastly
The Pine Wood bed
The SS Bed Bolt Package
1971 GMC Sierra
1959 GMC 100
Old 05-04-2014, 12:50 PM   #117
OrrieG
OrrieG's Avatar
You forgot costs for primer, plastic, consumables. Also body tools if you don't have them unless you are going for the barn find look. Trace the yellow wires from the signal harness, you will find the flasher, the empty connector or a bare end.
Old 05-04-2014, 01:42 PM   #118
SCHRUMGMC
SCHRUMGMC's Avatar
Sadly, its already been primerd over with that black stuff, It has to have one connected or the Left side flasher wouldn't work
1971 GMC Sierra
1959 GMC 100
Old 05-05-2014, 09:43 AM   #119
Tomb23
Schrum, That Ebay Auction may look a bit Over the top for your BARN FIND LOOK Here's a side by side look at Polished and Satin inserts
Tomb23 is offline   Reply With Quote
Old 05-06-2014, 07:31 PM   #120
SCHRUMGMC
SCHRUMGMC's Avatar
Okay, finally figured out where the Turn signal flasher was located I was looking at it the whole time and had no idea. When I take the lever down it flashes, but when I turn it up nothing happens, I am starting to think the Turn signal switch is the issue here. I really shouldn't be worrying about the Turn signals now but I just like working on the smaller items before I move to the bigger issues
1971 GMC Sierra
1959 GMC 100
Old 05-06-2014, 08:24 PM   #121
SCHRUMGMC
SCHRUMGMC's Avatar
When I turn my headlight switch on, even when the key is not in the ignition the Gauges move? What in tarnation LOL.. I removed the dome light because it looked to be missing the connection socket..Buy another one I guess.
1971 GMC Sierra
1959 GMC 100
Old 05-08-2014, 02:49 AM   #122
SCHRUMGMC
SCHRUMGMC's Avatar
Took the Speedo Gear off
Cleaned it up after this photo, but I didn't see the plastic gear in there, and have no idea how to take it apart to replace the Gear
Currently trying to figure out when I pull the headlight switch knob the gauges work, and when I turn the key the dash lights turn on
Going to print this out for Reference
I did unplug and switch wires"I think" probably, I can get it done tomorrow if I can print this out somewhere
1971 GMC Sierra
1959 GMC 100
Old 05-09-2014, 02:49 PM   #123
SCHRUMGMC
SCHRUMGMC's Avatar
Bought a Cab Step for the '59
Bought a Left Cab corner
New Dome light
Working on one side at a time
Should be getting the bottom of the door and door skin soon
Then its Door hing cover..Then pockets
1971 GMC Sierra
1959 GMC 100
Old 05-09-2014, 03:08 PM   #124
OrrieG
OrrieG's Avatar
Always nice to get the new patch panels, now the work begins...
I would fix the doors first, hinge pocket if needed and get them aligned to the cab. Then then do the corner and step, bracing the upper part if necessary to keep the alignment. A few guys have had to modify the doors because the lower cab moved around during repair.
Old 05-09-2014, 06:42 PM   #125
SCHRUMGMC
SCHRUMGMC's Avatar
The Dome lights wiring is completely different than what is on the truck right now?
Can't find the wiring since I took the dome light off.Found out the issue with the gauges moving when I turned on the headlight switch, Some wire I had grounded to the fuse box... When I took it off when the headlight switch was on the gauges went back to normal.. I believe it goes to the Heater(NOT SURE) But when I turn on the headlights I could turn the Heater on and when they were off I couldn't really weird ...
Got a Cab corner as well
Buying Door things here soon
1971 GMC Sierra
1959 GMC 100
