02-10-2014, 01:10 PM | #101 |
Re: What did you do to your truck today part II.
02-10-2014, 03:11 PM | #102 |
It's Better With Nitro
Finally got to the initial coats of body filler for my fender modifications and repairs...lots of sanding ahead for me...
Widened rear wheel tubs, plus welded up several holes the previous owner drilled in the originals...
02-10-2014, 05:41 PM | #103 |
I installed a cup holder on the seat.
02-11-2014, 02:01 PM | #104 |
got my tested and painted rad today looks AWesOmE. only $118. some other guy only wanted to recore my good rad and charge $317 plus $197 for labor. the true craftsmen i went to used lead on the tanks and did it right!!! use only folks that do it right instead a folks looks loking for the easy way out and charge high prices for no effort.
02-11-2014, 02:04 PM | #105 |
fab'd a fuel line that fits the one i got from a well known bender online, but local in mich. theirs was too short on the fuel pump side
02-11-2014, 02:08 PM | #106 |
here is mine, i will take it to em so they can makeone correct with my specs and out of stainless, plus since theirs doesnt fit i got a credit coming that will cove the new one they make that does
02-11-2014, 05:42 PM | #107 |
well got my "correct" pre-bent trans cooler lines had to make some mods the trans inlet and outlet part of the lines went up facing the hood? anyone every hear of a rad that had the ports on the bottom? not sure how that would work as the rad sits on top of a crossmemeber with no cutouts for trans lines, unless that style of rad had no cooler and a seperate trans cooler was used from the factory.
02-11-2014, 06:23 PM | #108 |
Finished my center console. Repaint, new hardware, LED lights with switch.
02-11-2014, 11:50 PM | #109 |
Weather finally warmed up enough to get a few things done. Dropped the back 2" with blocks from way2lo2. Now the front looks ridiculously high. Next step is to bring the front down with some new springs.
Also replaced the old ramhorn exhaust manifolds with some new block hugger headers. Reset the timing. Installed a new radio antenna.
1964 Chevrolet C10 SWB Stepside (350cid/TH400) 1978 Chevrolet C10 SWB Silverado Big 10 (454cid/TH400) -"Ah, the pressure's fierce!" |
02-12-2014, 12:11 AM | #110 |
Senior Enthusiast
The console turned out beautifully!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
02-12-2014, 12:24 PM | #111 |
got two walker tailpipe hangers, looks "correct" to me only $7.50 a piece just waitn on my $54 tailpipe... the $30 muffler and $160 piece from the Y pipe to the muffler will have to wait for daddy to make some more $$$$
02-12-2014, 12:26 PM | #112 |
view A
02-12-2014, 12:28 PM | #113 |
view B
02-12-2014, 12:32 PM | #114 |
Ordered and recieved my American Autwire kit! Soon I will have upgraded wiring and 18 blocks!
02-12-2014, 11:03 PM | #115 |
Got my letters all white also did straight pipes today heck with a cat
02-13-2014, 12:48 AM | #116 |
Hahaha
02-13-2014, 02:14 AM | #117 |
Do you need a cat on old trucks? I like the small rear window, and the truck looks nice. You need back up lights. I will be putting them on my 64. And are old trucks pollution tested? We have safety testing here in Texas.
02-13-2014, 04:32 AM | #118 |
Hey gsr! Thank you.... I'm really wanting the big window... In Cali you don't have to have any smog pollution test on any car made before 1975.
02-13-2014, 09:55 AM | #119 |
not exactly today, but is a snow day and actually taking the time to post...
just put c5 vette wheels on my 66; 17" front and 18" back; adapters/spacers 5x5 to 5x4.75 and 1 1/2" wide from flea bay... wheels (plus 2 extra front tires) $85 = good ol' CL adapters $125 change of look = priceless was running 15" buick gs rally wheels for past year; was ready for something different; vette wheels will prob go black once i need tires which won't be too long since my locker loves eating up those wide rear tires... thanks for looking, WAGZ
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally used up and worn out, shouting '...man, what a ride!' GC |
02-13-2014, 10:09 AM | #120 |
Since you already had 5 x 5 lug pattern it would have been easy to drill out the 4.75" lug pattern on the front hub and the rear axle.....would not need the adaptors.........FYI We had to do that to make my 17"s fit correctly, the adaptors made them too wide. Kieth
02-13-2014, 03:36 PM | #121 |
Got my new street sign today!!!! We are territorial around here.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
02-13-2014, 06:20 PM | #122 |
test fitted my radiator, rad hoses and trans cooler lines. glad to say it all fits no problem well some tweekin took place, what do you think?
02-13-2014, 11:52 PM | #123 |
Senior Enthusiast
Put about 50 miles on the truck today just running around picking things up. First time it's been out of the garage in nearly a month. First the rewire project and then due to the miserable weather. Over the last couple of days it's gone from 6-8 degrees to almost 50! It is sure fun being behind the wheel compared to the boring practicality of a CRV.
02-14-2014, 09:51 AM | #124 |
temps in the mid 50's, no snow, dusted the 66 off and drove it to work this morning................Nice..........now to just wait for spring !!!!
02-14-2014, 04:49 PM | #125 |
Drove mine to the Conroe swap meet looking for a deluxe heater control, no luck. I'll try again tomorrow when more vendors are there. 72 degrees and sunny, great day to be out and about in the 65.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
