#101 | |
Re: Cross country…or Bust? Long trip for C10..
I once tried to buy a '76 Catalina (it had a salvage title) but the owner was always gone when he and I had my an appointment to do the deal! He was driving it daily and the price was $200.00. This was in 1998 when I was an exterminator and living in an apartment. $200.00 seemed like a lot of money to me then. In 2004 I drove my 1975 Pontiac Bonneville from WV to Niles, MI to see this girl. Then I stayed at the Holiday Express for a week, dating her, and running around in the '75. It was a lot of fun. |
#102 | |
#103 |
Cool thread! I live in San Francisco. If you and your wife decide to do this trip, consider driving a few hours out here to the coast and go south from here.
If you do come this way, you and your wife are more then welcome to stay here for as long as you'd like free of charge. I have a garage with tools and a little know how if you end up needing a little fix up time. pm me if you want and I can shoot you my contact info. We come across this type of thread alot in the motorcycling community. Theres no better way to get familiar with your machine then to drive it. We've met so many people from all across the country taking trips like this on old bikes, I only hope to get the opportunity some day. PM me! We'd love to have ya |
#104 | |
Every new beginning comes from some other beginnings end |
#105 |
700r4 starts at 1300 at Summit. This will work well with 4.11's or 3.73's. A 3.07 ratio usually works better (behind a small block anyway) with a non overdrive tranny like a TH350 or TH400. If you decide to go either of these routes perhaps a Summit sales rep at the Sparks location could steer you toward a reputable shop for the install.
http://www.summitracing.com/search/b...s?autoview=SKU
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#106 | |
soooo, without getting into a tranny swap for 2k the 307 might be the way to go. would those be luggy at all in that truck? i am assuming 3.73 would not make a huge difference from 4.11. anything in between 3.73 and 3.07 that might be ideal. gas isn't going to break the bank, its more the high revving for long periods. i wouldn't mind keeping it at or under 2500 at say 70mph. i will also likely put a bigger wheel on it (32"?) to fill out the wheel wells and raise it a touch. i believe it was dropped with 2.5 drop spindles etc.
#107 |
Maybe run it as is, figure out what's good, what's bad, and decide after you get to know your new truck. I have 3:73s and don't mind them on the highway, but I'm not on the highway much. You may find after your trip that one component needs work. It would suck to put a new rear gear in it only to find out the tranny is shot after you get home. Just have fun and enjoy the trip!
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
#108 | |
#109 | |
![]() Join Date: Aug 2008
#110 | |
Sorry to be an ass, but I was not able to comprehend any of that as written. |
#111 |
![]() Join Date: Jun 2013
By all means drive it. I drove my '54 about that far and swept a foot of snow off before I started it up.
I did that trip without the benefit of even one gauge working. Needless to say I stopped often to check oil and overheating but I had no problem. I kept the speed around 45-50 but I had no speedometer. I used my iPhone for time and the mile markers along the way to check how fast (or slow) I was going. Fuel system is the weak link. Either take a few tools or buy some cheap ones along the way. Before you leave Reno I would check the fuel filter at the carburetor. If you don't have a new one just toss the old one before if stops you cold. Then the flex line between the tank behind the seat and the steel line under the truck will collapse due to ethanol. If the truck is in use now that may have been replaced. Take a look under the truck and you'll see the flex line and the joint to the steel line. If the flex line makes a nice lazy bend it will be OK. But chances are it will have a collapsed spot at the midpoint of the bend. A NAPA store will probably have a new flex line or you can use a small tubing cutter, a piece of hose, and a couple of clamps. Another winter and a '67 truck but similar trip about 1200 miles. One tire had no tread whatsoever but I figured I could address that when it became an issue. About 800 miles into that trip a vibration got worse so I slowed a little more. After about 40 miles something left the truck and the vibration smoothed out. It was dark and cold so I kept going until a decent motel popped up. The next morning I crawled under the truck an the center carrier bearing on the driveshaft was gone. I don't mean it was shot; it was gone so that's what I heard leave the the truck the night before. I assessed the situation and the smooth solid part of the shaft was spinning on the crossmember so there was no chance of shaft or crossmember wearing thin. The driveshaft was trapped by the U-shaped bearing housing so I drove it on home without incident. Every time I needed to start from a dead stop the driveshaft hopped around for a bit but then settled in for an easy ride at 45 mph. My wife considers these trips "Gale's adventures" so I go alone. BTW I choose not to carry tools because you will usually need what you didn't bring. I just buy cheap stuff along the way and toss them when I get back to my garage.
Gale Gorman '54 3100 '67 C20 stepside |
#112 |
I posted this before reading all the preceding posts.
I would not spend a lot of stuff such as gearing changes, etc. until you get your truck home and have a chance to look it over carefully. What little you save in gasoline will be forgotten a week later. Spending a lot, carrying a bunch of tools, etc. is something like paying interest on trouble that may not come. I've done numerous long trips in old trucks or on old motorcycles and I have my laptop, cell phone, and debit card. Armed with those three I can get towed from anywhere if I need to.
#113 |
Cruzin
I won't tell you not to do it, i love road trips. Me and the wife drove out to LA last summer from TN. I highly recommend taking route 66, get on in Arizona and to OKC depends on what part of Arkansas you headed, (you need to get a guide book) the EZ66 Guide by Jerry McClanahan was the one we used for the whole Chicago to Los Angles trip. So much life off the interstates. Be proud of your wife i have one like that to she has a 67 project and not high maintenance and loves off the interstates trips. Enjoy the trip!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
#114 | |
#115 | |
ordering aaa tomorrow.
#116 |
I forgot about the gas can. That was my first purchase when I saw I didn't have a gas gauge on the '54 truck.
I ran the truck dry and put my 2 gallons in the tank to get to a station. The plan was to figure out how many miles or hours I could go between stops. When the flexible gas line started collapsing that changed because there wasn't enough pressure from weight of gasoline or suction from fuel pump to get past the crimped spot. My first temporary fix was to wrap the collapsed place with electrical tape to hold it to a round shape. I also kept the tank full to increase the weight of gasoline pushing through the hose. That got me by until Monday morning and a NAPA store popped up. When I went to Indiana for the '67 C20 I took a Garmin GPS with me with the idea I could use it to locate the nearest NAPA, etc. It was in a backpack and I broke the display before I could use it.
#117 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
April 14th is fast approaching and I'm looking forward to you blogging your trip. Are you gonna post on this thread or start a new one?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#118 |
Here's my $.02:
I'm a big fan of the back roads, and it kills me that I don't have the time to go on long road trips and see the back roads, and the small towns with the hardware stores with the wooden plank flooring, and the billboards that advertise the combine derby in August, and the trains in the distance and the old bridges and highways, old cars, trucks, tractors, etc.... (You get the point). Long story short, only once in a rare moment do the stars align, and you have the money, the time, the desire, and the approval from your wife to do something like this. Embrace the opportunity and enjoy every second of it. Also, I agree with the earlier comment about getting AAA, that will do you a lot of good. Besides roadside service, they send you maps and tourbooks for free and help plan your route. I also say, find yourself some old maps, look at the old roads, and compare them to now. Try to find the old roads because chances are they will go through the land time forgot, and in my opinion, that's fascinating. (Of course I'm biased, because I collect vintage maps). Good luck!
Cameron 1984 Chevy C20 Custom Deluxe |
#119 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I'm waiting for this blog as well. I just wish that Sacramento area was on your route.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#120 |
I'm in for the ride! Wear it out! I'll be following along.
2006 GMC Sierra VortecMax: LQ9, 4L60e, 2wd, SLE 1971 GMC Jimmy 4x4: 350, TH350, NP205 ![]() |
#121 |
thanks! what's best? it seems like I should start a new thread but keep title similar. that way no one has to scroll through 5 pages of the prep stuff. open to opinions
#122 | |
#123 |
thanks will do my best to blog on the way guys!
#124 |
![]() ![]() Join Date: Sep 2008
New thread title
Cross country…or Bust? "THE" trip.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#125 |
![]() Join Date: Nov 2001
Cross country…or Bust? THE trip.
I like it!
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
