03-14-2015, 11:42 AM | #101 |
Re: 77 Cheyenne swb air ride accuair
Steering hooked up.
Jake
61 Ford uni http://67-72chevytrucks.com/vboard/s...d.php?t=623422 ryans 77 c10 http://67-72chevytrucks.com/vboard/s...d.php?t=626594 |
03-14-2015, 11:45 AM | #102 |
Pic of the truck back together.We ran in to an issue with the oil pan hitting the ground before the cross so he is getting a Milodon pan for it. It's quite a bit shorter and should workout great.So in this pic the font is about 1 inch from sitting .
Jake
03-14-2015, 04:03 PM | #103 |
I worried about this on mine as well (notched x-member w/an OE BBC 6qt deep pan). I swapped over a Milodon 5qt pan. Once the motor was dropped in place, it was about 1" above the bottom of the x-member scrubline.
03-14-2015, 04:14 PM | #104 | |
Jake
03-14-2015, 05:30 PM | #105 |
89 gen IV 7.4l
03-15-2015, 05:43 AM | #106 |
Diggin The SquareLife
looks good! do u have part numbers for the u joints u used?
03-15-2015, 05:22 PM | #107 |
Looks good! Btw I'm dead in the middle of y'all two, with my gen v 454.
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
04-08-2015, 07:22 PM | #108 |
what size tire does he have on the back and what bed cover is that....also part numbers for the u joints etc? thanks
06-29-2015, 11:15 PM | #109 | |
Jake
06-29-2015, 11:18 PM | #110 |
It's alive and running and he's putting miles on it so far so good said it drives nice sits on the side tanks and bolts for the trans cross.The Milodon pan worked out great he also put on patriot chevell headers 3 in to spin tech mufflers.Next is to finish the bed.
Jake
06-30-2015, 12:05 AM | #111 | |
06-30-2015, 12:30 AM | #112 |
This is inspiration for me and my long bed. Looks great!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-30-2015, 12:30 PM | #113 |
Lookin' good! Hope to see it in September!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
07-03-2015, 11:42 PM | #114 |
Thanks yeah we will be there.
Jake
09-04-2015, 02:49 PM | #115 |
It followed me home?
any updates?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
09-04-2015, 06:34 PM | #116 |
I raised the wheel tubs and put in the notch cover and its seam sealed.He is going to get it lined next week.
Jake
09-04-2015, 06:35 PM | #117 |
Tubs raised and tacked in.
Jake
09-04-2015, 06:36 PM | #118 |
Everything spotted in.
Jake
09-08-2015, 12:29 PM | #119 |
It looked good at the Last Cruise!
09-08-2015, 02:25 PM | #120 |
67-72 parts collector,…
Very clean and simple!
09-09-2015, 04:52 PM | #121 |
It's lined
Jake
09-09-2015, 05:03 PM | #122 |
09-09-2015, 06:16 PM | #123 |
What type liner did he opt for? Been researching which one to go with for my duallys floor/bed.
09-16-2015, 03:39 PM | #124 |
A pic Autofaze took at the ATN.
Jake
09-16-2015, 03:41 PM | #125 | |
Jake
