Old 03-02-2015, 09:46 PM   #101
NoClassic
Re: 1958 3200 Long Bed 5.3l/Jag IFS
The weather has been bad here so no chance to drive the truck yet. We did change the oil and let the motor run long enough to accumulate any fault codes that may have been pending. It registered a P0785 which was an issue with the 3-2 downshift solenoid in the trans. I checked the engine harness and all was good there so the trans pan then came off. The trans shop forgot to plug in the solenoid which made for an easy fix but did not give me warm fuzzies about the rest of the work they did.
The repaired heater core is also leaking. It must be hard to get these things sealed because this is the third time we have had one leak even after using a different shop than on our last project.
With the bed installed I ordered tubing to fabricate the gas filler neck. It will be going in the rear portion of the drivers fender.
NoClassic is offline   Reply With Quote
Old 03-08-2015, 03:24 PM   #102
NoClassic
The tubing for the gas filler neck showed up so I got that done yesterday.
I took the truck for a short first drive and all seems well. We will get it registered this coming week and finish up painting the patched areas.
Once all of the paint is done I will get some video and images posted.
Old 03-08-2015, 04:01 PM   #103
yossarian19
Curiosity - can you take a tape measure and get the distance from the front fender's lip to the centerline of the hub? Trying to compare ride heights and see if there's an IFS right for me
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 03-08-2015, 04:15 PM   #104
NoClassic
It is right at 12".
If I were to do it over again I would notch the frame or subframe a couple inches and bring it up a bit. As it sits right now front suspension travel is a bit less than I would like.
Old 03-09-2015, 07:24 PM   #105
NoClassic
The front suspension settled at little so we pulled the wheels to re-shim for camber before having the toe set.
When doing that I noticed both front brake calipers had a slow leak from the pistons. This is the third time we have had to deal with reman jag calipers leaking. Whoever is building these things for oreilly autoparts is doing something wrong or just does not had access to good cores. We are waiting to hear back on a refund so we can try another vendor.
One of the window regulator guide wheels also broke so my Dad pulled that and repaired it earlier today.
Old 03-10-2015, 06:48 PM   #106
NoClassic
My dad did the registration and picked up some new calipers today. He also had some new glass cut for the side mirrors so those will go back on soon.
I was just able to drive it a bit more and the rear end is making noise under load. I did some reading and it seems like it may be the pinion bearing failing or a pre-load issue. Would it be worth checking the pre-load value and tightening it if out of spec, or should I just pull it and have it gone through?
I am also considering painting the hubcaps the same white as the wheels so opinions on that would be great.
Old 03-10-2015, 08:07 PM   #107
Kim57
Kim57's Avatar
Truck looks real nice.
I like the contrast of the caps. Maybe just paint the logo area.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-11-2015, 08:53 PM   #108
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Love the caps! You might add a 1in 3 rib trim ring!!
ChuckDriver is offline   Reply With Quote
Old 03-12-2015, 01:35 PM   #109
NoClassic
I am not really a fan of the trim rings, but I think you are right about keeping the caps how they are. I may still go ahead and paint the bow tie black or white.
We are going to go ahead and pull the axle and have it looked at. I am sure it will need at the very least a pinion bearing and will likely just end up getting a complete rebuild.
Old 03-12-2015, 04:11 PM   #110
RockinKees
RockinKees's Avatar
Nice stance!
I only would paint the Bowtie and leave the rest.
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 03-12-2015, 05:28 PM   #111
ChuckDriver
This looks nice!
Old 04-05-2015, 08:17 PM   #112
NoClassic
We ended up pulling the rear axle and having it rebuilt. The housing is already back in the truck and we are picking up one of the shafts from having some bearing wheel bearing wear tomorrow. It should be driving by Wednesday.
We are taking it to Austin for the Lonestar roundup if anyone will be there and wants to check it out.
Old 04-06-2015, 01:15 AM   #113
BC Toy chest
BC Toy chest's Avatar
Nice, lovin' that stance and tire wheel combo.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 04-20-2015, 08:13 PM   #114
NoClassic
We ended up pulling the cut coil springs and installing slam specialties 5.5" bags. The cut springs were too soft and caused the suspension to bottom out easily.
The freshly rebuild rear end also had a leak at the pinion seal which prevented us from being able to drive it to Austin for the Lonestar Roundup. We were however able to take my Dads 5.3L 1951 3100 and brother in laws LS1 1955 F100. The trucks both made the drive from Dallas without any issues even through some pretty heavy rain.
The axle is being dropped off for a new pinion seal tomorrow and we should have it back in before weeks end.
Old 04-23-2015, 05:24 PM   #115
NoClassic
The pinion seal is fixed and I just finished up using CLR on the rest of the truck.
We should have the paint matched next week and the primer areas covered.
Old 04-23-2015, 05:42 PM   #116
Kim57
Kim57's Avatar
Looks real sharp.
Kim
My build thread
Old 06-14-2015, 09:13 PM   #117
NoClassic
Sorry for the lack of updates. We finally got the paint matched to what I think is a close as it will get considering the state of the original stuff.
We have just been driving the truck around and fixing small issues as they come up. Mainly just rattles and a small coolant leak from a heater hose.
One issue we can resolve though is the headliner panel falling down. With the heat we have here adhesive is not working. Does anyone have a solution that works?
The truck is also for sale if anyone is interested.
Old 06-14-2015, 09:59 PM   #118
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 06-15-2015, 05:21 PM   #119
RockinKees
RockinKees's Avatar
Looks good, stance is super!
Cheers!! Kees.
Kool Guyz CC
Old 06-19-2015, 10:51 PM   #120
ChuckDriver
Love the patina!
