Old 04-16-2017, 12:23 AM   #101
Sickfast1964
Re: 1964 C10 build
Originally Posted by Shady Rascal View Post
I didn't want to be a dick and mention it when you posted that picture on the first page. Roll the upper shafts 180 degrees and put the convex square shim inside. The nut should go directly against the flat side of the shaft.
Also, your upper ball joint bolts are installed wrong. The bolt head goes on the underside and the nut goes on top. The reason why is when you fully grease the balljoints, the boots will swell and tend to rub on the sharp threads of the bolt sticking out of the nut if you install them the way you have. That's also why the bolts have lo-profile heads rather than normal tall heads. Most manufacturers of ball joints put a little instruction sheet in the box (which no one reads) that explains this.
Correct on the upper arms. And I had never heard that before on the ball joinfs. Thanks for the information. I will address this asap.
Sickfast1964 is offline   Reply With Quote
Old 04-19-2017, 08:56 AM   #102
Sickfast1964
Re: 1964 C10 build
We have glass and tail lights. Yay !!!
Old 04-19-2017, 12:28 PM   #103
The1960APE
The1960APE's Avatar
Re: 1964 C10 build
Looking good, I was pretty excited to have glass in myself!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 04-19-2017, 12:57 PM   #104
Sickfast1964
Re: 1964 C10 build
Ya, not sure why this was such a turning point, but it was like a hill I had topped and was now on the other side. Now to finish wiring .... Yuck !!!
Old 05-03-2017, 08:31 AM   #105
Sickfast1964
Re: 1964 C10 build
Got the rear lights in. Cant afford the real backup lights, so I cheated.
Old 05-03-2017, 08:32 AM   #106
Sickfast1964
Re: 1964 C10 build
A quick look at the bed
Old 05-03-2017, 08:34 AM   #107
Sickfast1964
Re: 1964 C10 build
I put the dash in for the final time. Like the wiper knob.
Old 05-03-2017, 08:35 AM   #108
Sickfast1964
Re: 1964 C10 build
Took it to the alignment shop on Saturday. all looked good. The guy put too much camber in it. I will take it back once its on the road.
Old 05-03-2017, 11:26 AM   #109
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: 1964 C10 build
How much camber did he put in the front?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-03-2017, 07:56 PM   #110
Sickfast1964
Re: 1964 C10 build
It had about .5-.6 degrees of positive camber. Tires tilted in at top too much
