Old 03-31-2015, 08:28 AM   #101
texasld
texasld's Avatar
Re: Blood Sweat and Tears.. 67 Build Thread
My rear end was a pain to clean too!
Those brakes look SWEET!!!
Sometimes I feel the same way you do when I walk into the garage. I look at all the crap laying around and it beats on me. So I go fishing and come back to it another day. Hang in there!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline   Reply With Quote
Old 04-04-2015, 01:23 PM   #102
RRR18
RRR18's Avatar
Weather is finally getting turned around. Time to work.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 04-04-2015, 06:12 PM   #103
Possmguts
Possmguts's Avatar
I was "trying" to get some assembly done today on my rear end and learned something is wrong... wrong parts...
The carrier is making contact with the pinion gear. Carrier bearings are probably a good 1/4 inch from even going in the seats, so something is very very wrong... Summit tech line is closed, so..... on to the Rum and Coke.
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 04-04-2015, 07:17 PM   #104
Advanced Design
Advanced Design's Avatar
Just went through your build and really appreciate the work you are doing. Nice! Bummer about the carrier. Did Summit send you the wrong one?
Advanced Design is offline   Reply With Quote
Old 04-04-2015, 07:29 PM   #105
Possmguts
Possmguts's Avatar
Thanks man, I really appreciate that... I went back and checked everything again and again... I still think i have the right parts... The way the Richmond pinion is made looks a little different than the factory pinion in the taper on the end facing the carrier. I put the same shim thickness as was with the factory gears and carrier to start with. I was putting it all together without the crush sleeve so I could check the contact pattern but the carrier wouldn't go all the way into the bearing seats before it started making contact with the pinion. Im not sure how much room there should actually be between the pinion and the carrier, but I would think that just having a few thousands to much in shims wouldn't allow contact. Im using 28 thousands on the shims to start with. Im stumped right now.
Old 04-04-2015, 07:35 PM   #106
RRR18
RRR18's Avatar
I'm guessin you got wrong series carrier with wrong gears?
'67 BAD IDEA
Ryan
Old 04-04-2015, 07:42 PM   #107
Possmguts
Possmguts's Avatar
I dunno brother, Its all for the 8-7/8" 12 bolt.
Ill post part numbers and if anyone wants to check it out and see if they can tell something is wrong.
Ring and Pinion set is RMG-12BT373T
Eaton unit is 19556-010
Both from Summit
Old 04-04-2015, 09:41 PM   #108
RRR18
RRR18's Avatar
I'm pretty sure you got the series screwed up.
Part numbers you HAVE
-Carrier 19556-010 is a 4 series
-Ring and Pinion set RMG-12BT373T is 3 series
These won't work together.
If you keep one or other correct part numbers should be....
For a 4 series Carrier - Carrier 19556-010 and New 12BT373 Gears
For a 3 series Carrier - New Carrier 19587-010 and RMG-12BT373T Gears
'67 BAD IDEA
Ryan
Old 04-04-2015, 09:59 PM   #109
Possmguts
Possmguts's Avatar
Well Im sure they wont take any parts back after being installed... sort of... so the cheaper way out would be the gears... Now the 4 series does work with the housing right??
Old 04-04-2015, 10:07 PM   #110
RRR18
RRR18's Avatar
Yes, either series works in housing.
The series HAVE TO match or they won't work at all.
'67 BAD IDEA
Ryan
Old 04-04-2015, 10:17 PM   #111
Possmguts
Possmguts's Avatar
Awesome, at least I know now that Im only out 165 bucks and not damn near 500 if they dont take them back. Thanks brother.
Old 04-06-2015, 09:16 AM   #112
Possmguts
Possmguts's Avatar
Well... just sitting around waiting on the machine shop to get that bearing off the pinion shaft hoping they dont mark up the pinion so I can just go down to Summit and swap out the gears for the right ones...
Old 04-07-2015, 07:34 PM   #113
Possmguts
Possmguts's Avatar
Ok, the rear end is set up and ready to roll with .010 backlash. It called for .008 to .012 so we are right smack dab in the middle happy place. Contact pattern looks good as well. Cant wait to see how it works on the street.
Old 04-08-2015, 06:13 PM   #114
Possmguts
Possmguts's Avatar
I cant say it enough about how nice and clean this Wilwood setup is. Its so simple to install and everything just bolts right up where its supposed to. That drum style E-brake is such a nice design that doesn't leave the calipers with a bunch of springs and junk hanging off. Just a nice clean design all around. Ill be ordering the front setup as soon as I can and will be using their master cylinder as well. Probably one of the best, if not Best, upgrades one could do to their old vehicle.
Old 04-08-2015, 07:42 PM   #115
Saclandman
Saclandman's Avatar
That's a sweet set up. Good job.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline   Reply With Quote
Old 04-08-2015, 07:57 PM   #116
Advanced Design
Good quality parts that do what they are supposed to do are a pleasure. Looks good!
Pattern looks good too. Nice job.
Old 04-08-2015, 08:11 PM   #117
Possmguts
Possmguts's Avatar
The wife just looked at me funny when I told her Im about to really make a push for the super nationals in June... she said "there is no way you will be done by then". I told her "I didnt say I would be done, Ill just be cruising sitting on a 5 gal bucket if i have to" She said "You cant do that"... I said "dont worry baby, Ill but a milk crate on your side for you"
Old 04-09-2015, 08:28 PM   #118
Possmguts
Possmguts's Avatar
Ladies and Gentlemen.... we have a roller....
Old 04-09-2015, 08:52 PM   #119
flashed
Congrats ,moving right along .
flashed is offline   Reply With Quote
Old 04-09-2015, 09:34 PM   #120
Advanced Design
Something about a freshly painted chassis with new parts that still excites me. Looks good!
Old 04-10-2015, 03:52 AM   #121
lower50's
lower50's's Avatar
Chassis looks great. Glad you didn't give up, rebuilding is a big job and really big by yourself. Don't look at everything all at once, one thing at a time and then one day you will have a truck. Brakes look amazing, I get mine later today hope they bolt up as nice as yours.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 04-10-2015, 07:57 AM   #122
Possmguts
Possmguts's Avatar
Thanks, the only thing I might complain about on the brake kit is they didnt come with bolts for the mounting bracket. We have a bolt place in town and I had them match up the old fine thread bolts... As much as the kit costs one would thing it would have come with the 8 bolts it takes to mount them to the axle housing with
Old 04-10-2015, 10:33 PM   #123
RRR18
RRR18's Avatar
Making major headway.
'67 BAD IDEA
Ryan
Old 04-16-2015, 07:37 PM   #124
Possmguts
Possmguts's Avatar
Haven't been able to do much for several days now. I did kick it out of the garage the other day to do some much needed garage cleaning... While it was out of the way I pulled the cab out and did some undercoating removal on the bottom of the firewall. No parts money
Old 04-18-2015, 05:52 PM   #125
Possmguts
Possmguts's Avatar
I think I found my least favorite part of this build.... This stuff is not coming off without a fight. Im not going to worry about trying to get the outer floor clean as I will be replacing both sides anyway. I really dont think I need to try to replace the whole floor.
