Old 08-02-2020, 12:28 PM   #101
Acregger
Re: 4x4 LS cross member
Correct. My Np205 is bolted back in the factory location with the advance adapter kit installed. You will have to shorten the cross member some. I measured it up to find out about where the cross member would mount and put it in the frame before sitting the engine/trans. Position the cross member so the dip points to the front. It will hit the oil pan if it is pointed to the rear.
Acregger is offline   Reply With Quote
Old 08-04-2020, 08:48 AM   #102
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I went with the Pac Fab/Tilden crossmember in my 71 K10 5.3L LM7 4L60E swap. I kept the location of the transfer case mount the same. I didn't have to modify the driveshafts at all. The passenger side head is close to the firewall, but does not hit. I ended up using Speed Engineering headers (model 25-1021) because of rear cross member and transfer case. I didn't want mid-length headers aiming directly at the cross member. You can check out my build thread link below if interested. I just finished it up.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 08-07-2020, 07:32 AM   #103
C.I.Blazer
Dan, what is your lift size and what wheel/tire combo are you running. I think I have a 4" lift in my blazer but it looks like I have about half the space between the cross member and the front differential. Thanks!
C.I.Blazer is offline   Reply With Quote
Old 08-07-2020, 08:40 AM   #104
derotoreut
derotoreut's Avatar
My lift is Skyjacker 2-1/2" lift. They are new springs with zero rate block in the back. My tires are 33 X 12.5 X 15. You can check it out in my thread. http://67-72chevytrucks.com/vboard/s...d.php?t=620627
~ Dan
Old 08-08-2020, 07:27 AM   #105
C.I.Blazer
Thanks! Trying to figure out the lift tire combination for mine and think yours looks great. Mine is 4" but nowhere near the same clearance. Probably just because they are old and sagged.
