Old 04-09-2015, 11:15 PM   #101
oldman3
oldman3's Avatar
Re: How to make door panels
Now that all the is over with I can finish up the panel build. It's late tonight, so I will bring you up to date tomorrow...Jim
oldman3 is offline   Reply With Quote
Old 04-09-2015, 11:27 PM   #102
oldman3
oldman3's Avatar
Originally Posted by Possmguts View Post
Glad to see you're back at it... dont over do it. Those arm rests look nice, cant wait to see how you go about covering them.
Thank you, glad to be back, and I'm watching myself close. Arm rest coming up tomorrow.
Originally Posted by Advanced Design View Post
Didn't look like much needed to be removed Jim. Were you able to test fit before securing the panel back together? Great detail!
Hey Doug, correct it wasn't much, but you could feel and hear the leather against the metal. I would guess about 3/32", panel is 1/8" and I took away about half or a little more. No couldn't check, but I felt it was enough...Jim
Old 04-10-2015, 04:01 PM   #103
oldman3
oldman3's Avatar
Now we will get back to the rest of the panel build.
Pic 1 Covering the passenger arm rest.
Pic 2 Relief cuts for arm pull area.
Pic 3 Here it is installed (will go into more detail on the drivers side, didn't take pics on this one, wanted to make sure it turned out first).
Pic 4 Entire panel on the car.
Pic 5 Here is the panel and showing the rest of the interior. The curve design of the panel is close to the curve of the center console.
Old 04-10-2015, 04:22 PM   #104
oldman3
oldman3's Avatar
More details on how to cover the arm rest.
Pic 1 Glue applied to leather and the arm rest. Don't have a pic, but you have to stretch the leather tight across the face of the armrest, then across the top and bottom. Keep all flat as possible.
Pic 2 Here I've pulled everything tight into the area, made relief cuts in the material, now apply glue and pull and shape around the corner.
Pic 3 Here is how it should look
Pic 4 Everything stapled down.
Pic 5 Finished edge.
Old 04-10-2015, 04:51 PM   #105
oldman3
oldman3's Avatar
Pic 1 Back to the front of arm rest. Here I've pulled most of the leather into shape, and only have the point to finish. I've cut relief cuts in leather to help me pull all the wrinkles out.
Pic 2 Her it's been pulled and stapled down, it's not perfect, but not bad for an at home job. Pro's use steamers to get this out, I don't have one so I do the best I can.
Pic 3 The finish edge.
Pic 4 Cutting relief's for arm pull
Pic 5 glued down.
Old 04-10-2015, 04:52 PM   #106
oldman3
oldman3's Avatar
Have to stop here for now, need to get stuff done, will try and finish posting tonight...Jim
Old 04-10-2015, 10:51 PM   #107
oldman3
oldman3's Avatar
Back to finish up
Pic 1 With the metal pull in place
Pic 2 This is the screws I used to attach the arm rest to the panel.
Pic 3 Front of arm on the panel
Pic 4 Rear of arm on the panel, again not perfect, but not bad.
Pic 5 Finished panel.
Old 04-10-2015, 10:59 PM   #108
oldman3
oldman3's Avatar
Pic 1 My son Mark (reaper71) was nice and cut my grass this day, which allowed me to work in the shop all day on the panels.
Pic 2 Got the passenger kick panel laid out and cut, ready for foam and leather.
Your up to date now, so I'll show more, when I get back to the shop...Jim
Old 04-11-2015, 07:56 AM   #109
Advanced Design
Advanced Design's Avatar
Jim,
The door panel looks spectacular!
Did you make a pattern for the door arm rest material or just eye ball and cut to fit? Also, do you have a favorite place for material purchasing?
Good for Mark on cutting the grass. Looks like red bud trees are blooming and the yard looks really good. If dry enough I need to cut grass and maybe spray drives today too.
Thanks for sharing the knowledge!
Doug
Advanced Design is offline   Reply With Quote
Old 04-11-2015, 10:48 AM   #110
oldman3
oldman3's Avatar
Jim,
Doug
Doug, thanks for the compliment. No pattern for the arm rest, like you said just eye ball it. I don't do much interior work, so no favorite place, just look for the best price on the inter-net, etc.. Ed (owner) brought me his material to match what he had. Red buds looked really good this year....Jim
Old 04-12-2015, 07:24 PM   #111
quadzero
quadzero's Avatar
If I didn't want to make door panels before, I sure do now. Thanks for the great info and inspiration. Your panel is amazing and totally professional. Thanks for sharing this.
quadzero is offline   Reply With Quote
Old 04-12-2015, 08:09 PM   #112
Greenlee
Greenlee's Avatar
Nice work!
Greenlee is offline   Reply With Quote
Old 04-12-2015, 11:07 PM   #113
oldman3
oldman3's Avatar
Originally Posted by Greenlee View Post
Nice work!
Thanks guys, glad to share. Should finish up in a day or two, if nothing get's in the way ...Jim
Old 04-15-2015, 04:16 PM   #114
oldman3
oldman3's Avatar
OK troops, an update and finish to this panel work. Dates on pics tell when I did the work.
These three pics are of the metal door pulls and speaker covers that I painted to match the interior. Local paint store mixed up paint and put in a spray can for me.
Old 04-15-2015, 04:26 PM   #115
oldman3
oldman3's Avatar
The next four pics are of the finished passenger kick panel. This was put together the same as the large panel.
Old 04-15-2015, 04:34 PM   #116
oldman3
oldman3's Avatar
The next two pics are of the panel installed in the car.
Old 04-15-2015, 04:40 PM   #117
oldman3
oldman3's Avatar
I also got the drivers side kick panel ready, applied glue to both the leather, and the foam.
Old 04-15-2015, 04:50 PM   #118
oldman3
oldman3's Avatar
Decided I should show how I do my corners, if I hadn't already.
1st pic Bothe the pieces coming to the corner are cut on a 45 degree, and stapled down.
2nd pic Here I've trimmed the piece down to this thin strip.
3rd pic Pulled tight and stapled in place. Should be fairly flat and not bulky.
Old 04-15-2015, 04:55 PM   #119
oldman3
oldman3's Avatar
1st pic The finished back side.
2nd pic The finished front side and ready to install.
Old 04-15-2015, 05:02 PM   #120
oldman3
oldman3's Avatar
These two pics are of Ed's car, ready to go back home.
Hope you enjoyed this little panel build, sorry it took so long, but you know that story.
Till something comes along again...Jim
Old 04-15-2015, 09:09 PM   #121
Advanced Design
Again, great tutorial Jim! Nice work on the detail insets of the kick panel lining up with the door panel. Looks really good.
Thank you for sharing.
Old 04-15-2015, 10:58 PM   #122
oldman3
oldman3's Avatar
Thanks Doug, appreciate you checking in out...Jim
Old 04-16-2015, 12:05 AM   #123
Low68
Low68's Avatar
Thanks for taking the time to document that for us. I will be doing my own interior on my truck and appreciate the tips! The results are fantastic looking!
Build Thread
Low68 is offline   Reply With Quote
Old 04-16-2015, 09:28 AM   #124
aggie91
I'm just glad to be here!
aggie91's Avatar
Jim
Panels look great! Thanks for sharing this with all of us. This is the kind of thing I would like to see in an Interior Forum once we get enough support.
Thanks again!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-16-2015, 10:53 PM   #125
oldman3
oldman3's Avatar
Originally Posted by aggie91 View Post
Jim
Thanks again!
Thank you Karl, for trying to get the Interior Forum started. I for one hope it happens....Jim
