Old 07-17-2015, 12:09 PM   #101
solidaxel
solidaxel's Avatar
Re: Another way to skin the cat; the High Torque 292 LS swap
May be too late for that up grade on the ECM, I will be happy if I can get the compressor to turn on and off!
I do have a trianary switch mounted to the drier and will need to look up the schematic to see how it is wired
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-17-2015, 01:12 PM   #102
Willie Makeit
Willie Makeit's Avatar
nice welds
Willie Makeit is offline   Reply With Quote
Old 07-19-2015, 03:00 AM   #103
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by dayj1 View Post
Thanks! Is this what you want? I'm in the middle of adding A/C right now. Please excuse the bulkhead connectors above the heater core housing with no lines attached
Yes, exactly what I was looking for. Super clean. It's like you were in my brain. Love it.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 09-02-2015, 12:18 PM   #104
Tork?
this is exactly how an LS swap should look. I'm really impressed with the subtle fabrications you did. Great work!
Tork? is offline   Reply With Quote
Old 10-07-2015, 08:57 PM   #105
mooseknuckles
mooseknuckles's Avatar
very cool! you do great work.
mooseknuckles is offline   Reply With Quote
Old 11-25-2015, 03:55 PM   #106
king-918
king-918's Avatar
Nice build
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 11-26-2015, 06:18 PM   #107
dayj1
Originally Posted by king-918 View Post
Nice build
Thanks for the compliments!
dayj1 is offline   Reply With Quote
Old 11-27-2015, 03:47 AM   #108
Cobalt964ruf
Cobalt964ruf's Avatar
nice build, good attention to details.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 12-31-2015, 12:39 AM   #109
lt155ruck
lt155ruck's Avatar
Re: Mounts:
Would this be considered in the "stock" location or inch back etc?
The first order of business was the mounts. I've done several swaps, but this is the first time that I had a SBC and a Gen 3 motor sitting side by side. So, armed with my trusty tape measure I came up with adapter plates for the stock towers and mounts to place the motor just where I wanted it. I made these mounts out of 3/8 plate. There pretty much run of the mill plates, except that the SBC mount holes are 1/4" below the Gen 3 mounting holes. This will raise the motor by about 1/4".
Here are the plates in the middle of painting:
I also needed to modify the passenger's side tower. First, I removed the top of the tower:
Then a duplicate of the mount "top" in flat steel:
Welded together and a rough pass with the flap wheel:
Gusseted under the edges to add back some strength and blasted:
All done, in paint:
lt155ruck is offline   Reply With Quote
Old 12-31-2015, 12:52 AM   #110
dayj1
Re: Mounts:
Using the bell housing mounting surface as the point of reference, the plates that I made move the "LS" engine 1 inch forward of the SBC.
Old 01-01-2016, 01:10 PM   #111
lt155ruck
lt155ruck's Avatar
Thanks for that, I'm not sure why that seems to confuse me... must be getting older.
Old 03-04-2016, 03:02 AM   #112
toolboxchev
That is a nice build! Sleeper style for sure! My compliments to all your fab work, quite impressive.
toolboxchev is offline   Reply With Quote
Old 03-04-2016, 10:59 AM   #113
66ChevyMax
66ChevyMax's Avatar
Awesome work!
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 03-12-2016, 02:31 PM   #114
Custom/20
Custom/20's Avatar
Thumbs up Re: Another way to skin the cat; the High Torque 292 LS swap
Incredible job!
Custom/20 is offline   Reply With Quote
Old 03-14-2016, 11:21 AM   #115
juddss
Nice work. Fantastic job!!!!!!!!
juddss is offline   Reply With Quote
Old 03-20-2016, 10:24 PM   #116
SierraMtns
SierraMtns's Avatar
Hey Dayj1,
Can you talk about how you set up the transmission and column shifter?
SierraMtns is offline   Reply With Quote
Old 03-21-2016, 12:10 AM   #117
dayj1
Thanks for all the compliments!
Originally Posted by SierraMtns View Post
Hey Dayj1,
The truck had a th350 behind a 350 when I bought it. It already had what I think is a CPP crossmember and universal column shift linkage (rod type). I reused both on the 4l60 and bought an overdrive indicator lens from speedway motors. Is that the info you were looking for?
Old 03-21-2016, 11:45 AM   #118
SierraMtns
SierraMtns's Avatar
Thanks that helps. I guess I was assuming you where running a 4l60e and I was wondering how the column shifter and electric trans was hooked up.
Old 03-24-2016, 10:13 PM   #119
mcnally351
mcnally351's Avatar
Wow love this build. I like how the motor looks stock. I'm sure people give it a double take at cruise nights��
87 k5 silverado 4x4 350 38k stock
77 k5 Cheyenne 2wd 5.3 4l60e project
mcnally351 is offline   Reply With Quote
Old 07-24-2016, 08:26 PM   #120
t300
Just went through this build, great job!
t300 is offline   Reply With Quote
Old 07-27-2016, 12:57 PM   #121
SCOTI
SCOTI's Avatar
Very nice build w/great detailed info!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-27-2016, 03:40 PM   #122
smbrouss70
smbrouss70's Avatar
Every time this thread pops up, it makes me want to rip the 5.3/4l60e out of my old '99 that is just sitting there and drop it in the Blazer looking similar to this. Unfortunately, I have too much money wrapped up in a new SBC to abandon that course. I just love the look and functionality of this, maybe on the next one.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-27-2016, 07:38 PM   #123
dayj1
Old 07-27-2016, 10:38 PM   #124
ls1nova71
ls1nova71's Avatar
So just curious, but what ever happened to the gold '68?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 07-29-2016, 09:20 PM   #125
dayj1
I need to start a build thread on it. But, at this point, I've successfully disassembled and scattered a perfectly good running truck.
This is what it looked like after I mocked up the suspension and just before I tore it down to the frame.
And this is the current state of the new LQ4 in it now.
