Old 10-20-2015, 09:04 AM   #101
sperger72
Re: My 67 short stepside
Those tail lights just blend in and disappear without them lit up. Really cool.
sperger72 is offline   Reply With Quote
Old 10-20-2015, 10:31 AM   #102
sperger72
Adam,
What door handles and mirrors did you use?
Old 10-20-2015, 10:35 AM   #103
BossHogg69
motor exploder
BossHogg69's Avatar
Originally Posted by sperger72 View Post
Adam,
Thank for the info. Are the Hagan LEDs bright at night? Yours are Hagen LEDs, and Lambert makes basically the same lights.
Is the extra 10mm on the 345 really noticeable? It is only .393" wider.
The stance in the rear on your truck is awesome. That is what I am going for on mine, close. Is that a Mar-K rollpan?
Thanks for the help
Zach
They are just bright enough in the daylight and fairly bright at night. Of course they are under 4 coats of paint and a few coats of clear. we sprayed and tested after 2 coats of base, and decided on two additional coats.
I did the switch to 345/19's more for height than width. if you put the wheels side by side, there is a little difference in width, but the shape of the tire is a little different too. the Michelins seem a little more squared off at the shoulder. 335/345/355 all probably look the same from a rear view. I'm usually powersliding mine sideways through the first three gears, so the vaporized rubber hides the view of the tires for the most part.
Rollpan, tailgate, header panel, bed strips, latch kit, bolts and wood are all Mar-K. I used the stock bedsides and fenders, that's about it. I used their regular smooth rollpan with the license plate box, then cut the slots for the lights.
As far as the help, that's what this forum is all about! I like the way you did the back of your cab - I only welded the seam, but yours look even better with that peak rolled out the way you did it.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-20-2015, 10:37 AM   #104
BossHogg69
motor exploder
BossHogg69's Avatar
Adam,
Don't get any ideas!!! Kindig It designs on the handles, Streetrod HQ again on the mirrors.
Adam
Old 10-20-2015, 10:44 AM   #105
sperger72
Thanks Adam for the advice and yes I really like these forums for the been there done that... and should have went another way aspect. Seems like there are some great people in this forum.
Thanks, the peak I think will turn out pretty cool when we finish, a lot like the Goodguys giveaway truck done by Scotts Hot Rods.
I do really like the door handles, my wife wants originals but... Have ant pictures of your truck from the side?
Old 10-20-2015, 10:47 AM   #106
sperger72
That is why they blend in so much... painted over. sweet idea. Mine will be Dark Sapphire candy blue so I do not think they will show up. Awesome idea though.
What does your interior look like?
Old 10-20-2015, 11:02 AM   #107
BossHogg69
motor exploder
BossHogg69's Avatar
I'm waiting in line for the interior - I'm 'next' so he says. Supposed to be this month, then 4-6 weeks to complete. Ring Brothers and Lokar hardware, scat procar rally seats. Nothing special.
I could've easily built two trucks with all the screw-ups and do-overs I had, no to mention saving a TON of money.
Adam
Old 10-20-2015, 11:38 AM   #108
sperger72
I am going with a buddy seat with Katzskin black leather covers. Maybe some suede to keep me in the seat when corning.
The tires coming loose and not gripping is what I am worried about too. We will see. I guess 800 plus hp anything would loose the grip on the road!
Old 10-20-2015, 11:40 AM   #109
sperger72
Adam,
So you have a cage? Did you use the Art Morrison kit or have a shop make it weld it in? Hell of a start on the interior
Old 10-20-2015, 01:46 PM   #110
BossHogg69
motor exploder
BossHogg69's Avatar
Adam,
It's an Autoweld kit with the 'roadrace' option for the door bars and welded it up myself. I didn't want to cut the back of my cab to run the down bars, so really mine's more or a rollbar/harness bar than anything else. I have Schroth 4 pt harnesses that attach the the back bar behind the seats.
Wow, 800hp?! yeah, it only takes about half of that to get loose in one of these trucks on street tires!
Adam
Old 10-20-2015, 02:37 PM   #111
sperger72
Adam,
Your cage look good.
I am trying to stiffen the chassis up, so I am going to use an Art Morrison 10 pt and make the door bars low so it is easy to get into. Will have down bars low though the cab and bed.
I have the engine built just not dynoed. We are thinking at 15 lbs of boost it will be over 900 hp. We will tune for a little less. Heck it may not make but 700hp, not sure. The parts are there for some serious hp. Going to run some road courses and good guys auto cross events and the Texas Mile.
Old 10-20-2015, 02:38 PM   #112
sperger72
Stroked LSX with Magnuson supercharger. TCI six speed.
Old 10-20-2015, 02:41 PM   #113
sperger72
New fuel cell, cab peak removed and my LSX
Old 10-20-2015, 04:25 PM   #114
BossHogg69
motor exploder
BossHogg69's Avatar
You definitely have a top notch build in the works. It will definitely kick much @$$ with that LSX454 and the blower. I plan to 'debut' my truck at the Goodguys Spring Nats in DFW, and wring it out on the autocross as well. I hope to see you there!
Adam
Old 10-20-2015, 04:57 PM   #115
sperger72
Hopefully mine is their too. That is my goal Texas spring nationals. You are much farther along than I am.
Old 10-20-2015, 06:04 PM   #116
sperger72
Peak removed
Old 10-20-2015, 07:37 PM   #117
pat english
pat english's Avatar
Peak removed
That looks good.
pat english is offline   Reply With Quote
Old 10-20-2015, 10:02 PM   #118
jlsanborn
jlsanborn's Avatar
Holy smokes! You do some b!tchin' work there man and FAST! Judging by the gear you've got to go in, you are used to fast I'm sub'd up and will be looking for the burnout video next week. What's with all the heat exchangers in that photo a few pages back?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 10-21-2015, 12:21 PM   #119
sperger72
Jlsanborn,
The picture with the backspace tool? That was taken in my office. I manufacture those style tube and fin coils.
Not used to fast, only second big build. Trying to get ready for Texas Nationals in March.
Zach
Old 10-21-2015, 12:22 PM   #120
sperger72
Just want to smoke or come close the C10r truck of Rob Phillips.
Old 10-21-2015, 01:13 PM   #121
sperger72
This build is not about beating anyone, Rob is a great guy. It is about building my first truck when I was in high school again with my two boys and wonderful wife. I really that is what this hobby is all about. Now thrashing something you built is always lots of fun!
Old 10-22-2015, 12:19 PM   #122
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Badass build!
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 10-22-2015, 01:52 PM   #123
BossHogg69
motor exploder
BossHogg69's Avatar
Yeah, but you are obviously WAY more talented than I am and work a heck of a lot faster!!
Adam
Old 10-22-2015, 03:53 PM   #124
sperger72
Finally put the cab back on the chassis. Starting to look like a truck again. Have a long way to go.
Old 10-22-2015, 03:54 PM   #125
sperger72
One more picture on the trailer.
