Old 10-07-2015, 10:54 PM   #101
thelonerife
thelonerife's Avatar
Re: 67 long box
I just saw your build. Your metal work looks great!
thelonerife is offline   Reply With Quote
Old 10-07-2015, 11:28 PM   #102
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks, there was a lot of swiss cheese in the cab. Something I know to look for next time.
Metaldoc is offline   Reply With Quote
Old 10-08-2015, 11:59 AM   #103
Bomp
Bomp's Avatar
Re: 67 long box
Love the attention to detail.
Dig that cab cart too.
Bomp is offline   Reply With Quote
Old 10-08-2015, 12:52 PM   #104
Metaldoc
Metaldoc's Avatar
Re: 67 long box
two pieces of tube and wheels. thanks, some times I put to much work in parts never to be seen again, but I know what it looks like.
Old 10-08-2015, 12:57 PM   #105
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Just found out the rear axles have bad bearing surfaces after all that work not sure what way to go. I have 5 lug front and now have to buy new axles or rear end. Any suggestions?
Old 10-08-2015, 11:57 PM   #106
71Sleeper
71Sleeper's Avatar
Re: 67 long box
Set of new axles and bearings will probably run about $300. Could always see what a local shop would charge to rebuild the whole thing and they might have a used set of good axles that will fit. I would probably work with what I had versus buying another rear end and finding the same problems.
71Sleeper is offline   Reply With Quote
Old 10-09-2015, 10:54 AM   #107
Metaldoc
Metaldoc's Avatar
Re: 67 long box
If I lived in the US that would be the price but here in Canada its closer to 500- 600. Everything is twice what you guys pay. I going to try some other shops but it looks like new ones. I don't have a lot of money to spend being on disability.
Old 10-09-2015, 12:08 PM   #108
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Just checked ECE and without delivery I'm up $515.00 with tax and exchange rate. Canada sucks for performance parts.
Old 10-09-2015, 04:30 PM   #109
71Sleeper
71Sleeper's Avatar
Re: 67 long box
That really sucks didn't figure cost to Canada. Well it might be best to take a chance and purchase another used rear.
Old 10-09-2015, 06:11 PM   #110
Xeen
Xeen's Avatar
Re: 67 long box
Moser has very good prices on 5x5 conversion axles for the narrow 1965-69 rear end, $260 USD.
http://www.moserengineering.com/axle...spline-62.html
Also $260 for the 1970-81 5x5 stock axles.
http://www.moserengineering.com/axle...spline-30.html
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-09-2015, 06:15 PM   #111
trac209
Re: 67 long box
Canada sucks for buying anything to be honest. We've been getting screwed for decades and it's never going to get any better I assume
trac209 is offline   Reply With Quote
Old 10-09-2015, 06:19 PM   #112
Xeen
Xeen's Avatar
Re: 67 long box
Metaldoc with your fabrication skills you could make a killing in the custom car scene you should offer up your services locally and make some money off of your talent.
Old 10-09-2015, 07:52 PM   #113
Metaldoc
Metaldoc's Avatar
Re: 67 long box
even at 260 it's 385 here before shipping. why
Old 10-09-2015, 07:59 PM   #114
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks man, I suffer from migraines daily, up to 8 a day and no one will hire an unreliable guy. I build my own for therapy but I'm always building something for friends . Just imagine if I had real tools what I could build.
Old 10-10-2015, 11:31 PM   #115
Metaldoc
Metaldoc's Avatar
Re: 67 long box
de rusted the top and back so it's ready for flat/satin mix clear coat. The inside is in primer now and ready for paint, floor is getting stone guard sprayed on it both sides. I'll finish the cab corners and rockers once mounted on the frame. I had a few spots to clean up after metal work was done on the fire wall. It's coming out looking nice.
Old 10-11-2015, 11:29 AM   #116
Xeen
Xeen's Avatar
Re: 67 long box
See what you do is you say, "I take my time and it gets done when it gets done but it will be right when you get it back" and since you have less overhead than a shop you can charge less and do one car or truck at a time and guys can be on a waiting list to get their ride worked on, you can make it work.
Old 10-11-2015, 12:06 PM   #117
ripper70
ripper70's Avatar
Re: 67 long box
Nice job on the metal work! Another 1 SAVED to be back on the streets! I had alot of metal work on mine as well. Keep up the good work.
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 10-11-2015, 05:56 PM   #118
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I'd say ya had some sheet metal repair and I'm just about ready to start reassembly. I had the ability to save it which helps. Thanks and the same on your build.
Derek
Old 10-11-2015, 06:04 PM   #119
Metaldoc
Metaldoc's Avatar
Re: 67 long box
My waiting list already has a 1971 chevelle (wife, 1951 chevy coupe (oldest daughter and chevy HHR modified to her liking for the other daughter. Could be why I get the headaches living with three women
Old 10-11-2015, 09:13 PM   #120
Xeen
Xeen's Avatar
Re: 67 long box
Originally Posted by metaldoc View Post
could be why i get the headaches living with three women
rofl!
Old 10-12-2015, 02:12 PM   #121
Metaldoc
Metaldoc's Avatar
Re: 67 long box
inside floor done with stone guard, just the right texture and great sound deadener.
Old 10-14-2015, 11:30 PM   #122
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Found out my fire alarm expired 2009 I guess I could replace it. Did some work on the cab corners and being the only body work on the outside it didn't need to be on the frame. It was so much easy this way too. I also finished the body prep on the kick panels. Some blue, clear, and black paint should be just like 1967 on the inside and now on the out side. Oh and that's Lola my watch dog, she came to inspect again.
Old 10-16-2015, 03:02 PM   #123
Metaldoc
Metaldoc's Avatar
Re: 67 long box
seam sealer done on the drip edge. looks easy and not too bad with thinner instead of spit on my finger. Then washed it with a brush and thinners to smooth out. Brushing it made it blend better.
Old 10-16-2015, 07:25 PM   #124
Advanced Design
Advanced Design's Avatar
Re: 67 long box
That looks good. I got a good chuckle on the fire alarm!
Advanced Design is offline   Reply With Quote
Old 10-18-2015, 03:08 PM   #125
Metaldoc
Metaldoc's Avatar
Re: 67 long box
It seems I'm done seaming after three tubes of seam sealer. Had left over white from drip guard and used it too. Now bed spray under the floor to sound deadened it and make it impervious to the rain and road crap.
