Old 02-08-2016, 12:44 AM   #101
iowaboynca
iowaboynca's Avatar
Re: Harold's '48 S10 LS1 Build
wow.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 02-08-2016, 01:30 AM   #102
Flysocal
Man you do great work
Flysocal is offline   Reply With Quote
Old 02-08-2016, 10:03 PM   #103
Advanced Design
Advanced Design's Avatar
Very nice!
Advanced Design is offline   Reply With Quote
Old 02-08-2016, 10:34 PM   #104
iowaboynca
iowaboynca's Avatar
Originally Posted by Tikal48 View Post
I'll have to finish this out after Easter. Last few shots before Lent.
Did you give up working on your truck?
Old 02-08-2016, 11:17 PM   #105
Tikal48
Tikal48's Avatar
Yeah, that I did. Give up something you love, right?
It'll give me a chance to catch up on some of the home projects.
Tikal48 is offline   Reply With Quote
Old 02-08-2016, 11:47 PM   #106
ricott
Great craftsmanship on a truck with a great story. Your console looks really good. What was the map light out of?
ricott is offline   Reply With Quote
Old 02-09-2016, 12:09 AM   #107
Tikal48
Tikal48's Avatar
Thanks everyone! I appreciate the encouraging words! The fiberglass work has definitely been a fun project, and I don't have to worry about it rusting . . .ha ha!
Ricott- The map light is from a 01-04 Hyundai XG350 xG300. I found more similar styles for Hyundai Genesis, Santa Fe and etc. on Ebay. I've had a heck of a time trying to find any aftermarket map lights. Especially anything that I liked. I liked that this one had the built in sun glass case.
Old 04-09-2016, 10:33 PM   #108
Tikal48
Tikal48's Avatar
Well I managed to get through Lent without working on the truck. That was a bit tough, but I did get some yard work done.
I picked back up where I left off on the console. I wanted to at least get the first coats of primer on it before I moved on to something else. I was happy with the way the contours looked with the primer, but I do have plenty of areas that still need work.
I completely dissembled the map light and removed the old liner in the eye glass case. I was fighting trying to remove it, until I soaked it in Acetone. Then it came right off. I used a plastic paint on the map light console, and will re-line the glass case with felt.
Old 04-09-2016, 10:49 PM   #109
99 to Life
99 to Life's Avatar
welcome back, looking good.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 04-09-2016, 10:52 PM   #110
Tikal48
Tikal48's Avatar
I also started work on the seat risers. I wanted to raise the seats about 3". This should set them to a comfortable height.
Old 04-09-2016, 11:17 PM   #111
Tikal48
Tikal48's Avatar
Thanks 99, its good to be working on the truck again.
My original intent was to buy some purple heart wood for the bed wood, but in an attempt to defray a little cost, I've been doing some research on dying some oak. Here are a couple of test pieces that I did. This is using RIT dye. Has any one else here tried this?
I tried the first piece with a purple dye, but it came out looking more brown than purple. The next piece I stained first with a couple of coats of Fushia dye. I went over half of that test piece with the purple dye. That's closer to the color that I want.
Old 04-10-2016, 10:33 AM   #112
iowaboynca
iowaboynca's Avatar
You are pretty much staining the wood but you're able to dial in the color more to your desire for a custom piece.
My only concern would be longevity, as i'm thinking about how dyed clothes can fade over time with use. But on the flipside, as i mentioned above, you've got a cost effective, custom piece that you can replicate in the future.
Old 04-17-2016, 10:28 PM   #113
Tikal48
Tikal48's Avatar
I've been doing a little more work on the hood. I finished roughing out the body work on the hood and around the vents. I have a little more finish work, but I need to do the repairs to the front bottom lip of the hood, and to clean the bottom side of the hood.
I also received my stainless wire mesh to go behind the vents. I made some frames to hold the wire mesh in place, and to give a neater appearance.
Old 04-18-2016, 08:51 AM   #114
99 to Life
99 to Life's Avatar
Nice touch, that will def help keep that engine bay cool
Old 04-18-2016, 08:35 PM   #115
Advanced Design
Cool look well done!
Old 04-19-2016, 07:59 AM   #116
roushinator
roushinator's Avatar
Nice Work!!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 04-22-2016, 09:01 PM   #117
Tikal48
Tikal48's Avatar
I started on the bottom lip of the hood. This was pretty thin in some areas, so I left about a 1/8" lip of the existing metal, and inserted the new pieces underneath. I did not want to burn over the edge. I welded the two lip pieces together in the middle, which was a mistake. I will split that tomorrow because the sides need to squeeze in a little.
I did a few repairs to the front latch bracket. I installed the replacement square nuts that I made and tack welded them in place. I hope to get the inside of the hood cleaned up tomorrow, where I can get it primed.
Old 04-22-2016, 11:52 PM   #118
99 to Life
99 to Life's Avatar
nice job, that area is a biaatch
Old 04-23-2016, 10:20 PM   #119
Tikal48
Tikal48's Avatar
I started cleaning the inside of the hood today, among other things. This had an undercoating that was a pain to remove. I've tried last summer with some of the useless strippers that they carry at Home Depot and Lowe's. Those didn't touch it. I found some of the good aircraft stripper at O'reilly's, and luckily it was a warm day. It still took about three coats of stripper.
Some of the areas under the paint and undercoat were rusted. I used some Phosphoric acid to clean the rust, and I have a couple of small areas that will be faster to sandblast. I should be able to get this finished up and primed tomorrow.
Old 04-23-2016, 10:47 PM   #120
Tikal48
Tikal48's Avatar
It's a shame to have to cut a new fender to correct a gap problem. The driver side fender had a weird bend where it joined the cowl. I tried straightening this as best I could, but it still had about a 1/8" gap in the middle. I split the fender and used a 1/8" metal rod to fill the gap. After welding it out, I used a little All Metal and block sanded it. I just received my new Devilbiss Finishline 4 FLG paint gun, so this gave me a chance to try it out. It was well worth the money.
Old 04-23-2016, 11:14 PM   #121
Tikal48
Tikal48's Avatar
My one big goal this weekend was to get the grille in and start work on fitting the lower grille support and the front section of my inner fender wells.
When I tried to install the grille, the front of my frame was hitting the vertical braces on the grille. Times like these makes me regret not putting a modern suspension under the old frame. I pulled off the two supports of the grille that were hitting the frame. I got the grille in with a bit of slotting and cussing, and not necessarily in that order. It seems that the holes in the fender did not line up with the holes in the radiator support.
Old 04-23-2016, 11:35 PM   #122
99 to Life
99 to Life's Avatar
nice work. yeah a lot of this stuff doesn't seem to "line" up. Sorry I missed but did you get repop front fenders? also putting the grille in usually sux a bit.
Old 04-24-2016, 12:09 AM   #123
Tikal48
Tikal48's Avatar
Yes, these are re-pop fenders. On my first attempt to install the grille things looked worse. But I changed the order of how I was bolting it up, and it made a world of difference. All of the holes in the fender to the grill matched up fine. It was just the holes to the radiator support, and hood latch panel that were the major problems. Of course, I haven't even tried to bolt up the custom inner fender well pieces yet. That will definitely be loads of fun.
Old 04-24-2016, 09:31 PM   #124
Tikal48
Tikal48's Avatar
Finally, the last of the rust that I have to clean! I wound up spending all day on this. At least its behind me! The bed and rear fenders will be new.
Old 04-24-2016, 10:55 PM   #125
99 to Life
99 to Life's Avatar
I know that feeling of having something behind ya. You're making this stuff look fast and easy.
'48, bearclaw, ls1, s10
