Old 02-12-2016, 11:02 PM   #101
The1960APE
The1960APE's Avatar
Re: New member with a 1960
A little progress
The1960APE is offline   Reply With Quote
Old 02-24-2016, 05:13 PM   #102
The1960APE
The1960APE's Avatar
We are making a little bit of progress, the machine work is finished, the engine should be together in the next 2 weeks, transmission is finished... Now if we can get the patch panels finished up it will be time to do some mockup!
Old 02-24-2016, 09:53 PM   #103
DPowers
DPowers's Avatar
Looks good.
DPowers is offline   Reply With Quote
Old 02-25-2016, 05:15 PM   #104
The1960APE
The1960APE's Avatar
Originally Posted by DPowers View Post
Looks good.
Thank you sir!
Old 03-02-2016, 05:21 PM   #105
The1960APE
The1960APE's Avatar
Things are still creeping right along!
Old 03-02-2016, 08:44 PM   #106
flashed
Nice seats and a very cool table too.
flashed is offline   Reply With Quote
Old 03-03-2016, 11:36 AM   #107
The1960APE
The1960APE's Avatar
I never realized how small the cab is on these trucks, being 6'4 this is going to be a challenge, I am going to have to order another steering wheel with less offset, and I am considering cutting the "roll" out from under the rear window...
Old 05-03-2016, 02:18 PM   #108
The1960APE
The1960APE's Avatar
Well, the seats pictured are gone, I am going another route! We are slowly working on replacing the missing metal...LOL, The engine is coming right along, tranny is finished, and I am about to jump on the power window install!
Old 05-03-2016, 02:36 PM   #109
forestb
forestb's Avatar
What type of leather on those seats?
forestb is offline   Reply With Quote
Old 05-04-2016, 09:51 AM   #110
The1960APE
The1960APE's Avatar
Chyenne Stirrup from Carrol leather
Old 06-05-2016, 06:44 PM   #111
The1960APE
The1960APE's Avatar
Old 06-05-2016, 10:45 PM   #112
DPowers
DPowers's Avatar
Quite the engine there- nice
Old 06-06-2016, 09:30 AM   #113
The1960APE
The1960APE's Avatar
Thank you, I am having one heck of a time finding the parts to install this into my 61, I cannot seem to get a straight answer from anywhere!
Old 06-13-2016, 08:40 PM   #114
62CiscoKid
The info is around but it seems we'll have to dig it up...unfortunately T-Bar trucks have different frames than the later trucks that do have mounts made for them. Our frames are narrower and have shorter C channels. In some cases like my GMC the frame is boxed and possibly thicker.
Some have gotten away with notching the frame with later model mounts and other have simply had to spacer the top of the mounts. I'm currently having issues with my POL mounts, but when I get it figured out, I'll post what I come up with.
There doesn't seem to be a "bolt on" solution.
Header clearance is another issue and since I'm not building a race truck the long tube and big diameter headers don't interest me. That might be the case for your motor though. Lookin damn fine BTW.
-Joe
62CiscoKid is offline   Reply With Quote
Old 06-13-2016, 10:44 PM   #115
mb63Chevy
WOW Some ruff tough trucks here - Mine and Org 63 Like to know what it may sell for?
63 Calf Black tags new paint work all org 283V8 3 speed with OD Custom.[IMG]C:\Users\burbom\Pictures\Back G Photos[/IMG]
mb63Chevy is offline   Reply With Quote
Old 06-14-2016, 12:29 AM   #116
Captainfab
60-66 Nut
The closest fitting factory engine mount brackets for the '60-'62 frames are the '67-'72 small block engine mount brackets. Although some say they had to add a .250" spacer on top of the frame. Then you will need the '63-'72 engine mounts and an adapter plate for the LSx engine. Other than those, I do not know of any off the shelf engine mount solutions. Depending on just what you are wanting, the engine mounts might just have to be custom fabricated.
This is one of the reasons I don't care for the '60-'62 frames.
Old 07-06-2016, 07:04 AM   #117
The1960APE
The1960APE's Avatar
Thanks for the advice, that's exactly what we ended up doing.....
Old 07-06-2016, 07:27 AM   #118
The1960APE
The1960APE's Avatar
I really like POR-15 but wasn't happy with the firewall finish using POR-15, I took it down to the metal, primed it, sanded and shot it with a Jet black acrylic enamel. I'm much happier, once it cures I will wet sand and buff it out.
My 65 Olds project is about to come to a close, so its full steam ahead on the Apache....
Old 07-06-2016, 11:37 AM   #119
DPowers
DPowers's Avatar
Very nice.
You going down to the Maggie Valley show next weeK?
Old 07-06-2016, 11:52 AM   #120
The1960APE
The1960APE's Avatar
Very nice.
Yes Sir,
I will defiantly be there! Are you going? What are you taking?
Old 07-06-2016, 04:27 PM   #121
DPowers
DPowers's Avatar
Quite a bit of stuff.
64-66 and 60-63 doors, GMC Hood and Chevy 64-66 Hood, complete dashs for '62, 64-66 and a GMC. Barn and Clamshell doors. Rat Rod step bed as well as some other goodies.
Old 07-14-2016, 09:07 AM   #122
The1960APE
The1960APE's Avatar
I'd love to find some nice chrome turn signal bezels...
Old 07-14-2016, 01:10 PM   #123
The1960APE
The1960APE's Avatar
The front windshield and wheel tubs came in today, I ordered Mobsteel (Detroit steel) wheels today, 20x11 & 20x8 and tires Nitto 245/40/20 & 315/35/20.
The engine has been mocked up and will be in place soon! We are having to cut and modify the Torsion bar cross member for clearance of the 4L80E but its all working out nicely!
Old 07-15-2016, 08:16 AM   #124
The1960APE
The1960APE's Avatar
A little more progress, the CPP LS conversion kit brackets for the frame are no where near a proper fit, but we fixed that
We cut the center out of the torsion bar cross member, drilled it and remounted it to the stock outer location and the inner frame rail, we are going to weld a bracket back in place to reconnect it and be able to use it as a tranny mount and quick disconnect, in stock form the transmission was hitting the torsion cross member dead center!
Old 07-19-2016, 12:59 PM   #125
The1960APE
The1960APE's Avatar
A little more progress, below shows what we had to do to the torsion cross member, it seems to work excellent! Headers clear very well, the AC compressor ...well not so much, we are going to have to modify the frame for line clearance !
New Rear Tires
