#101 |
Re: What did you do to your Suburban Today?
Jumping in on this thing again
#102 |
Changed the thermostat, installed new valve covers and gaskets.
Today I also installed a new window regulator in the drivers door. |
#103 |
I HAVE A 86 GMC 2500 I am trouble having troubles with the brake proportioning valve the right rear break locks up all the time if I could down the road and hold my foot on the brake pedal and warm the breaks up a little bit everything is fine
#104 |
![]() Join Date: Jul 2010
Installed my autosound slidebar radio this weekend. I opted for the Bluetooth option. Quite an easy set up to install. Instructions were quite detailed and the radio programming was straightforward. The bluetooth interface worked like a dream, can make and receive hands free calls. Can also stream Pandora and any other audio from my smartypants phones bluetooth. The pita was reinstalling the center AC vent.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
#105 |
JB, are those custom gauges, or did you redo the originals with white face?
Nice radio install, by-the-way.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
#106 |
Here are a few more pics of the finished product. Gauges are white vinyl overlays.
#107 |
![]() Join Date: Sep 2013
Replaced my 2X4 hatch holder with gas struts
My OE hatch hinges never worked right so I've been using a 2X4 to keep the door from dropping on my head. Finally sourced some gas struts from McMaster: http://www.mcmaster.com/#gas-struts/=10gvykk and now the hatch stays up by itself!
#108 | |
Re: Replaced my 2X4 hatch holder with gas struts
#109 |
Mostly plug and play but I did need to tap new threads into the original holes. I'll dig up the receipt and post the McMaster PN when I get home.
#110 |
McMaster-Carr PN 4138T585
Here's the strut I used...specify the 50lb version
#111 |
not to hijack your thread but has anyone done this to the cargo doors?
#112 |
#113 |
Re: McMaster-Carr PN 4138T585
#114 |
Got one more door done! Rough body work and 2 coats of epoxy primer. Two more and the body comes home!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
#115 |
The Older Generation
Yup, I installed them in the '67 Panel Truck and they work great. You will find out quick if your hinges are bad because it will spread the top of your doors apart....
![]() LockDoc
#116 |
I spent the last two weeks on my driver side qtr panel replacing the fuel filler and some rust. Here's a couple "before" pics of the old door and rust and a finished pic with the new flush push/twist release cap.
#117 | |
Any more info on the cap. ie: brand, part #, link to web site. The fill on my '67 Panel Truck is on the inside and it has to go. I don't get any gas odor but it's a pain in the butt to have to open the rear doors to fuel it up. LockDoc
#118 | |
#119 | |
Thanks. I will check it out.... LockDoc
#120 |
Caused some body damage to one of them...no big deal, though.
1953 Suburban Carryall 3106, 1993 S10 4x4 ext cab 1958 Suburban Carryall 3116 ex school bus 1959 Apache 36, 1984 C30 3+3 DRW 6.2 4MT 1967 C10 fleetside LWB, 1969 Chevy Suburban C10 1972 GMC Suburban C10 1972 Chevy Suburban C10 clam shell/tailgate |
#121 |
Had door locks installed in the yellow 1972 suburban I have, to keep my new custom Sundown Audio sub system in the back where it belongs!
#122 |
I replaced my halogen 6 inch Unity spotlight bulb with a Whelen PAR146 LED spotlight bulb from Sirennet. A couple of before and afters. I went from about 1000 lumens to around 2000. The amp draw is significantly less as well.
Before shot illuminating some masking paper on my toolbox. Another before, the light isn't shining directly at the camera, it washed out the shot too much. Notice the reflection on the hood compared to the last pic, noticeable difference. After. Spot detail is much more defined. I am certain that at night this more focused beam will broadcast much further with better clarity. After.
#123 |
Put it on a quick diet by pulling the heavy tow hitch.
#124 |
Removed the stock pan hard bar and then added the deluxe from CPP.
It is like night and day driving it, I should have done this a long time ago. |
#125 | |
Thanks for any insight- Brian
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
