Old 11-16-2021, 12:16 AM   #101
68bowtie
68bowtie's Avatar
Re: 72 Cheyenne Super
I wonder how those wheels would look with year correct stainless hub caps?? I went that direction with my 68 even though it came with factory covers.
Old 11-16-2021, 12:32 AM   #102
geunther
geunther's Avatar
Originally Posted by 68bowtie View Post
Really dig this, nice work so far keep it up!
Thanks sir.
I think the wheels would look better with some poverty caps or the year correct caps like you posted. Somewhat limited given they need to be 11.5" if I remember correctly. Something shiny to break it up some
geunther is offline   Reply With Quote
Old 11-18-2021, 11:55 PM   #103
geunther
geunther's Avatar
Well I got it running again. Runs smooth with new timing set. Transmission wouldn't turn the tires but it just needed some more oil so all good there.
Couple little issues. The water pump is seeping out of the back. I sacrificed some wrenches, ground them down to tighten the 6 bolts. It slowed it down but doesn't appear to have stopped. Ill double check again tomorrow but it will probably need a new back gasket. Man, I don't want to pull it all apart, chip bolt paint etc. So frustrating.
Also when I had the rad re-cored I went with a three core. Not knowing there was a difference in shrouds. it doesn't fit like it did before. I used some small hose for spacers for the time being.
I guess there were a lot of things done to not have any problems.
Old 11-23-2021, 07:29 PM   #104
geunther
geunther's Avatar
Wheeled it outside to rinse off the year's worth of garage dust and drove it for its maiden test run. The only issue is a loose connection or ground for the voltage regulator.
There is still some work to do, bumper, headlights, antenna etc but it's winding down. Just in time for winter.
The stance is just about right for me as I didn't want it too low.
I'm considering Sniper Qjet fuel injection. They say to get it running first so I went that route vs putting it in as part of the project.
Old 11-23-2021, 08:06 PM   #105
Louisvillekytruck
Very nice truck
Louisvillekytruck is online now   Reply With Quote
Old 06-28-2022, 10:27 AM   #106
geunther
geunther's Avatar
Sacrilege
To make the truck more user friendly and to not load up on fuel on slow drives, I took the plunge and installed a Sniper Qjet and upgraded the 37 amp alternator to an internally regulated unit. Nothing was permanently altered (which for whatever reason I still find important).
I was able to tuck the fitech (50006 mini) up under the batter to keep it hidden. I used an angled fitting for the pressure gauge which has the side benefit of making the gauge readable looking between the batter and radiator support.
Old 03-11-2023, 11:11 AM   #107
geunther
geunther's Avatar
Running the Sniper with the original points distributor left a lot of room for improvement. It was tough to get the fuel tables dialed in because of the inconsistency with the points.
I took the plunge and installed the Hyperspark. The improvement has been better than the difference between the carb and fuel injection. The drivability has made the Sniper and Hyperspark worth it.
Caveat, I have been unable to join the Holley forums. I go through the registration process but I never get approved by a moderator. I am wondering if anyone else has had issues joining Holley's forum. My presence here indicates that I know how join a forum : ).
The lid is stuck on my jar of anti seize
Old 03-12-2023, 12:14 AM   #108
chevmn
Originally Posted by geunther View Post
They were a Cheyenne Super only thing apparently. They are sort of a pain and even the factory units did not fit in there all that great. Supposed to help with road noise.
72 Cheyennes had them, or mine did. I am not bothering replacing mine as they are not really noticeable, and I am not going for a 100 percent correct restore.
chevmn is offline   Reply With Quote
Old 03-15-2023, 07:33 AM   #109
mr.mud1
mr.mud1's Avatar
very nice truck and great attention to detail,the way it should be,for me anyway.she's a beauty.
mr.mud1 is offline   Reply With Quote
Old 05-19-2023, 05:18 PM   #110
yote1234
yote1234's Avatar
love the truck, color, and most of all keeping it mostly original. awesome job
1971 K5 CST Blazer
1965 C10 Short bed all original
1949 gmc 100
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 12-01-2025, 06:44 PM   #111
geunther
geunther's Avatar
I looked for a couple of years for an NOS or great condition inner fender for the pass side. I ended up ordering a repo and now I am deciding to use the whole thing or go for a patch. The underside brackets are shaped somewhat differently so leaning towards a patch using the original reinforcement.
Old 12-03-2025, 11:08 PM   #112
72 tigger
72 tigger's Avatar
Nice work- going to be a fun truck next summer
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 12-04-2025, 12:41 AM   #113
geunther
geunther's Avatar
I opted for the patch to keep as much original as I can. Lots of welding and grinding to go but the test fit showed I welded in the right spot.
Old 12-19-2025, 07:36 PM   #114
geunther
geunther's Avatar
When hitting a bump at speed, the rear end would get a little squirrely, almost like rear steering.
I don't know how the should of the trailing arm bushings being cracked affects handling, but it can't hurt to replace the likely original bushings. I am also running the original shocks on the rear but I will replace those as well.
Old 12-20-2025, 12:06 PM   #115
Lokin4AReason
Lokin4AReason's Avatar
nice work on the inner fender
i would ve done the same esp patching it like that
cant beat the original stamping
its also hard sourcing out nos parts
also depends on the item
some are just scarce or they want to much coin for it
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-21-2025, 03:38 PM   #116
geunther
geunther's Avatar
Thank you. I put off fixing it as long as I could. Issue is, both sides are visible which can make it a challenge to have both sides looking like there is no patch. Undercoating will help.
While I had the trailing arms out for bushing replacement, I decided to clean them up and stitch weld before painting.
Old 01-13-2026, 10:15 PM   #117
geunther
geunther's Avatar
I don't know how well this is going to work out but it is time to get in and repair the A pillar. I want to make sure I get everything lined up the way it is now so I built a removable jig to make sure the rocker ends up in the same place.
Old 01-14-2026, 10:05 AM   #118
raggedjim
raggedjim's Avatar
Great idea, I have had a couple of rockers I fought with to get them to fit and that would have helped. I think most of my rocker problems were caused by the inner rocker/floor panels not being stamped correctly.
raggedjim is online now   Reply With Quote
Old 01-19-2026, 05:23 PM   #119
geunther
geunther's Avatar
I am hoping to avoid door fitment issues by creating several jig points so I made another for the rear of the inner rocker. Ill have more at the front which give me up and down along with in and out points of reference.
Certainly someone has done this before so Id be interested in how it worked out or if I am wasting my time and should just put the door on and off numerous times.
Old 01-19-2026, 08:50 PM   #120
raggedjim
raggedjim's Avatar
I was never smart enough to do that! I'm a door on/door off repeated endlessly until it worked kinda guy! It's gotta be better than my process.
Old 01-20-2026, 09:38 AM   #121
clay68c10
clay68c10's Avatar
That's a great idea. I used measurements off reference marks and it turned out ok, but I like your idea better.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 02-01-2026, 11:56 PM   #122
geunther
geunther's Avatar
Im glad I made the jig stops. I began fitting the inner rocker and was able to tell it was about 3/16" to 1/4" too high at the step for the outer rocker. I might not have been able to notice otherwise. So, I made a pie cut to lower it at the rear. It fits fine at the front. Of course I now have more welding to do.
Old 02-02-2026, 09:41 AM   #123
raggedjim
raggedjim's Avatar
And that one jig right there would have saved me a weeks worth of cutting and cussing. Great job.
Old 02-23-2026, 12:36 AM   #124
geunther
geunther's Avatar
Thank you.
I got the inner fitting well and about welded in with the B pillar tacked. I am disappointed on how the A pillar fit. Using the jig to locate the fender bolt hole and the cab support bolts to locate the patch, the line up was pretty bad.
I got the face moved over and now I will slice the rear near the bolts and get all sides lined up.
