#101 |
![]() Join Date: Aug 2007
Re: My winter project
Cleaning up the heavy things. I picked up energy suspension trans case mounts and need to get seals for the trans and and case.
Just for the fun of it |
#102 |
Thanks for the great post, I am just starting my 71 blazer.
#103 | |
Thanks 7D2N
#104 |
I found out that truck bed liner will come off the the hatch with a little heat, prying and pulling but fairly easy to remove. I was also surprised the hatch was in pretty good shape.
#105 |
WOW that's crazy
72 Chevy K5 CST |
#106 |
Your project is really coming along and looks great. Keep up the good work,
#107 | |
7D2N
#108 |
Well after rolling around on my back scraping, grinding, and sanding the underside of the tub and frame it's time to paint. I used a roll-on satin black on the underside of the tub and can spray the frame. Trans and transfer case ready to go back in.
Just for the fun of it Last edited by 7D2N; 12-04-2021 at 09:06 PM. |
#109 |
Painted under side of the tub and frame, for a driver truck what do you think white or black firewall?
#110 |
Moving to engine stuff, looks pretty clean inside but a previous rebuild had the cam break in fail. Need to get to the machine shop.
#111 |
If it's any help....
-Bruce 1971 K5 Blazer 4WD
#112 |
Yes it does thanks and very nice, any reason you didn't paint the under side of the hood white?
7D2N
#113 |
Thank you, and glad it helped. No particular reason that I recall, but I think would look nice as well.
#114 |
The engine went to the machine shop and had a few things done will have it this week. New home is ready.
#115 |
2WD Jimmy
Wow... you’ve made a lot of progress since I saw you last!
#116 |
![]() Join Date: Aug 2013
Looks good like the process.
#117 |
So you decided on the white firewall; looks good!
#118 |
Thanks guys, I know it's a yawning build and nothing like some of the members have done but I'll keep playing.
#119 |
I have the engine back from the machine shop and will to start cleaning the outside stuff for some paint. I did stumble on this steering wheel and shiftier to replace the custom wheel and late model shiftier that I have now.
#120 |
Starting to put these back where they go. I'll clean the outside engine for some paint and I'll be ready for the next move.
#121 |
I've started some motor assembly and have a question, the exhaust manifold is very close to the starter and previous exhaust shop made it work by sizing the pipe to fit around the starter, should I change to different manifold before I break in.
Thanks 7D2N
#122 |
![]() Join Date: May 2015
Your Blazer would have come with straight dump manifolds. I believe the correct casting for 1972 is 3989036
#123 |
Thanks Jack B, the engine is not original to the blazer but 1970 block. I'll look for some straight down type.
thanks again, 7D2N
#124 |
Engine is painted and on the run stand, cleaning up misc brackets and stuff. I'll need a few little things then I can start it up.
#125 |
I could use some help or info if I may. I have my motor on the run stand and plan to start soon, question is should I fill the trans and transfer case with fluids until I put the engine in?
Thanks 7D2N
| Bookmarks |
