Old 12-14-2015, 03:13 AM   #101
tinydb84
tinydb84's Avatar
Re: My 83' Crew Cab Dually project
I hate grinding too but man that looks good.
David
Instagram: myfabguy
Old 12-14-2015, 05:33 PM   #102
64chevtruck
Nice smooth work thank you for posting the info, I have the front end apart on mine right now and am looking for info on this.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 12-14-2015, 09:55 PM   #103
DblTrbl
DblTrbl's Avatar
Alright fellas...I can use a little help with the steering. Tinydb84, I know that you did yours a while back. I also remember Scott or Scotty or something from another thread that has a shop that sells the parts...
Here's what I have. Where is the best place to buy and what exactly do I need? I know it's a couple of u joints and a heim or Johnny joint...
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 12-15-2015, 12:21 AM   #104
64chevtruck
Howdy, When you Zd the frame, you had to lower the core support in front also yes>? Did you have to remove an inch up there since you stretched it an inch>?
Old 12-15-2015, 12:31 AM   #105
DblTrbl
DblTrbl's Avatar
Yes. I haven't gotten that far yet, but I will have to drop the horns down 4" and back 1" to account for the changes behind the engine...otherwise the body panels won't line up. The front is simple in comparison.
Instagram: lofab77
Old 12-15-2015, 03:38 AM   #106
tinydb84
tinydb84's Avatar
Mine is different from yours. The steering changed in the late 70's.
You should need a 3/4'' DD shaft, one 3/4'' heim joint, two 3/4"DD x 3/4"DD u-joints, and one 30 spline x 3/4" DD u-joint.
Double check everything though. There were three(?) different steering columns and two steering boxes.
I ordered all my stuff from Travis at AZ Pro Performance. He gave me a discount too if I remember correctly. Just call him and he will know exactly what you need. Just tell him you are Z'ing a truck.
David
Instagram: myfabguy
Old 12-20-2015, 11:16 PM   #107
DblTrbl
DblTrbl's Avatar
In spite of a fairly busy weekend, I was able to squeeze in some time this afternoon on the truck.
I built both the trans and carrier bearing crossmembers. The trans was pretty simple; straight bar of 2x3x.25 with a couple of pieces of flat stock on each end, so I can drill them and boot it in place.
The carrier bearing crossmember was a little more complicated to work out and I'm still not sure if it's going to leave me enough clearance for exhaust pipes on either side, but I can work that out once it's in. By flipping the bearing over, I only had to raise the mounting surface 1/2 to match the 4" that I Z'd the front end. Unfortunately, that puts the driveshaft an inch into the floor...so I'll be tunneling all the way back instead of just the trans hump it seems.
So, I finally dropped the whole thing down off the stands and put the four link back in place and started setting it up with the gussets and lower bag brackets. The axle is sitting about 1/4" below the notch with the truck on the ground, so it should be perfect when I mount some lower profile tires...currently 235/85's.
Anyway...it's on pinch.
Instagram: lofab77
Old 12-21-2015, 01:00 AM   #108
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
You probably said it before, but what are you doing for the upper bag bracket? Looks like you'll have to cut into the floor a bunch to make the bags fit.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 12-21-2015, 01:09 AM   #109
DblTrbl
DblTrbl's Avatar
The bed is going to be raised a ton. I'm already into the bed with the front four link mounts and the driveline. The bridge is about 10" above the floor. With the bodydrop, there's not much choice...if I'd gone bag-over-axle, my bridge would have been almost even with the top bed rail. I plan to cut the floor out when I drop the bed back on and go from there.
Instagram: lofab77
Old 12-21-2015, 01:10 AM   #110
Ghostwhite
Squarebody guy
Ghostwhite's Avatar
Looking amazing!
Progress is coming right along, I need to get some plate to button up my Z and get started out back.
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress
Ghostwhite is offline   Reply With Quote
Old 12-26-2015, 07:06 PM   #111
DblTrbl
DblTrbl's Avatar
Got my new steering linkage installed. Built a simple bracket to hold the heim joint...
Instagram: lofab77
Old 12-26-2015, 08:20 PM   #112
ruffrida2005
Looks good
Paul
Old 12-27-2015, 02:33 PM   #113
DblTrbl
DblTrbl's Avatar
This body work is tough business...think I've got it figured out.
Instagram: lofab77
Old 12-27-2015, 06:33 PM   #114
bbbc10
Diggin The SquareLife
Looking good whats the part # on the u joint u used from tge column to the dd shaft
bbbc10 is offline   Reply With Quote
Old 12-27-2015, 07:19 PM   #115
DblTrbl
DblTrbl's Avatar
It's a 1"DD -> 3/4"DD. I don't have a part #. I ended up buying it from "bro-speed on eBay. The Unisteer stuff was a little more than I wanted to spend and I honestly don't see the reason other than going with a brand name. The parts I got are also a high quality and I have no doubt that they'll do exactly what I need without problems...
Instagram: lofab77
Old 12-28-2015, 12:27 AM   #116
DblTrbl
DblTrbl's Avatar
I really wish I had more time. It seems like as soon as I get moving at pretty good pace, I run out of time...
Nonetheless, I got the rear upper mounts built and burned in today. I'll be tackling some kind of a crossmember to tie them together next weekend.
Ooh look...pics!
Instagram: lofab77
Old 12-28-2015, 02:24 AM   #117
tinydb84
tinydb84's Avatar
Looks good. I thought the mounts were going to have to be taller. I like it.
David
Instagram: myfabguy
Old 12-31-2015, 12:31 AM   #118
54earl
54earl's Avatar
Looking good.
54earl is offline   Reply With Quote
Old 01-02-2016, 04:18 PM   #119
slammed427
slammed427's Avatar
That looks good. How's the bag look at ride height?
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
Old 01-03-2016, 02:54 AM   #120
DblTrbl
DblTrbl's Avatar
It seems like the little things take up a lot of time and progress just crawls sometimes. I spent quite a bit of time just welding things off that I'd tacked in for mock up once I got everything moving the way I wanted it to. The panhard bar proved to be a major pain in the ass to get positioned with the least movement and still clear everything. It's tight, but it works...
Built a bracket for the panhard - yep, it's a little rusty; I didn't have any clean 1/4" material and 3/16" just didn't seem strong enough:
Installed:
Removed a small part of the original frame where it kicks up just ahead of the step for clearance on the bags at full air up.
Aired up as requested...this is a little above ride height:
And hooked up to shop air @80lbs:
http://s82.photobucket.com/user/sbeb...81D09.mp4.html
Instagram: lofab77
Old 01-03-2016, 05:58 PM   #121
tinydb84
tinydb84's Avatar
Looks really good man.
David
Instagram: myfabguy
Old 01-11-2016, 12:55 AM   #122
DblTrbl
DblTrbl's Avatar
I'm at the point that I need to set the engine and trans back in so I can figure out how much floor to trim. Of course, I can't set the greasy old motor back in a new frame, so I steam washed it, gave it a fresh coat of paint and started bolting on the shiny bits...
Tip: electrical "rockets" make great spark plug hole plugs...
Everyone's dropping LS's in and I'm here making my sbc shiny...
Instagram: lofab77
Old 01-11-2016, 01:26 AM   #123
54earl
54earl's Avatar
Did your truck originally come with a small block?
Old 01-11-2016, 01:30 AM   #124
DblTrbl
DblTrbl's Avatar
Yes it did. I've considered going bigger but this is a solid motor and it pulls me around just fine for now. Fuel mileage isn't too bad either.
Instagram: lofab77
Old 01-11-2016, 01:34 AM   #125
54earl
54earl's Avatar
I just bought an 82 crew cab dually (200). No engine or trains, but I have a small block 350 and a turbo 400 as well as a 700r4. I have been trying to figure out a good bag selection and if the 350 would work out.
