Old 08-22-2016, 09:07 AM   #101
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 4x4 1971 K20 build
Good deal! It's looking great!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-22-2016, 10:46 AM   #102
Rednwhitec20
Rednwhitec20's Avatar
Thank you!
1971 C20 Daily, Built 350/700R4
1971 K20 Project, LLY Duramax, 5 speed Allison, and 8 in lift on 37x13.50s
K20 Build
Rednwhitec20 is offline   Reply With Quote
Old 08-22-2016, 02:25 PM   #103
Rednwhitec20
Going to try and finish drilling and bolting it up today.
K20 Build
Old 08-26-2016, 01:50 PM   #104
Rednwhitec20
The intercooler and body wiring harness are ordered in. The factory intercooler is way too big. Front clip is on.
K20 Build
Old 08-26-2016, 02:32 PM   #105
Wide Open
Looks like it fits in there nicely.
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 08-26-2016, 03:23 PM   #106
Dieselwrencher
Very nice!
Ryan
Old 08-26-2016, 06:19 PM   #107
Rednwhitec20
It sure does! Just looks like a big block on steroids.
Going over tomorrow to get my starter in. Going to take pictures and put them in my post on how I did it. What would you guys recommend on doing with my steering gears? It is a little leaky. Go redhead? It's going to have to turn a lot more tire and a lot more weight.
K20 Build
Old 08-28-2016, 04:30 PM   #108
Rednwhitec20
So problems... Intercooler nor the radiator will fit. They are just too tall. Anyone have a recommendation on a radiator I should use?
K20 Build
Old 08-28-2016, 04:34 PM   #109
ripdog28
ripdog28's Avatar
I would consider tilting it back if too tall. Fab some brackets to hold the top. Otherwise, Summit and Jegs brand radiators work great and less expensive than most. I have one on my truck and fit perfect. Just measure your support. Had mine for 6-7 years and no issues on a BBC.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 08-28-2016, 07:21 PM   #110
Rednwhitec20
If I tried tilting it back it would be in my fan. It's about 2.5" too tall. I will look, thanks!
K20 Build
Old 08-28-2016, 11:18 PM   #111
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Somehow I Missed your duramax swap. My build is similar but still haven't got to fitting my duramax driveline. Looks good from another Kansan to another. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 08-29-2016, 12:31 AM   #112
Rednwhitec20
Thanks! Your build is awesome and I may have to have you make me a crew one day? I would like to come check it out someday! I'm from Ottawa.
K20 Build
Old 08-29-2016, 09:11 AM   #113
Rednwhitec20
First picture is the side of the engine stand. I used 1.5" square tubing with a 1/4" wall thickness.
Second is the trans cross member, bolted in the same factory holes.
Third is from the bottom. You can see the washer spacers we used on the bottom of the stand with a bolt through them to keep them aligned. The cross member was not modified other than the corners were trimmed to get it in. It is about 8" from the front cross member.
Fourth shows the mounting plate and the sbc motor mounts. I had bought Mounting plates off of Merchant Automotive but it would be better off to build your own since they are too small to fit a sbc motor mount.
Overall I am very happy where it sits. The oil filter and housing sits right in the center of the frame rail which i think is nice. The starter can come out without moving the engine. I think I will have to put a resonator plug as my turbo silencer might sit too high. The only thing that was cut was a small piece up under the pedal to clear a sensor, and the tabs that were all around the trans tunnel were trimmed off. We may have to raise the floor up a bit above the transfer case, we will find out soon.
K20 Build
Old 09-05-2016, 11:35 AM   #114
Rednwhitec20
New intercooler is mounted. Getting lights and wiring ran.
K20 Build
Old 09-05-2016, 11:37 AM   #115
Rednwhitec20
Good clears good with a few inches to spare. Glass is in. Getting anxious!
K20 Build
Old 09-05-2016, 03:47 PM   #116
ripper70
ripper70's Avatar
Nice Build man. Been awhile since I been on and just read from beginning. Nice to see another 4x4. I'm just about done with mine, I'm subscribing!
1970 K20
1967 Blown Stepside
2016 Chevy 2500 Duramax
1989 Jeep Cherokee
1995 S-10
2014 Infinity Q-50 AWD
1970 Chevy K20 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=634164
1967 stepside rebuild
http://67-72chevytrucks.com/vboard/s...d.php?t=684913
Shop build http://www.garagejournal.com/forum/s...d.php?t=225559
ripper70 is offline   Reply With Quote
Old 09-10-2016, 02:49 PM   #117
Rednwhitec20
Went and picked the beast up to bring back to our shop on Thursday. Down to wiring, brakes and fuel. Have a few things here and there. Will probably order my radiator within the next week or so. Sadly it will not be finished this year for the local car show. I will be taking my c20 in though and I'll try to get some pictures of some 67-72 rides. There were quite a bit of them last year. There's already around 1300 preregistered. If your close come on down.
K20 Build
Old 09-14-2016, 01:21 AM   #118
Rednwhitec20
Well my driver side drop idea just won't quite work as it will hit the oil pan on the trans and possibly the engine if it was flexed enough and depending on how far my yoke sits out. I believe it could be done but it is just way too close for my liking and I want to do it right. Maybe I just need more lift. (The pan was designed to clear a driver side front shaft so they moved the pan over to keep the capacity.) Damn lucky 2wd guys. Any how I will be finding a manual shift driver drop case (NP261 or NP241 with input shaft swap) to get it running but it wont be 4wd until I can find and afford a 78-79 ford dana 60. I am hoping to hear it run by the end of November but we will see. We started corn harvest so I will not have much time to work on it unless it is wet out. But that just means more money to spend on the rig.
K20 Build
Old 09-18-2016, 02:45 PM   #119
Rednwhitec20
Pretty cool shot of these Blazers. Not my picture, I forgot to take pictures. The orange on is on a 90s dodge frame with a Cummins that is still turbo'd and is also supercharged. Sitting on 37's.
K20 Build
Old 09-19-2016, 05:36 PM   #120
Dieselwrencher
I've seen that orange one at Des Moines Good guys last year I think.
Ryan
Old 09-19-2016, 06:00 PM   #121
Rednwhitec20
Another 6bt swap
K20 Build
Old 09-19-2016, 06:04 PM   #122
Dieselwrencher
Have anymore of that truck? That is awesome!
Ryan
Old 09-19-2016, 06:42 PM   #123
Rednwhitec20
Just ones other people took, my stupid self forgot to take some.
K20 Build
Old 09-19-2016, 06:43 PM   #124
Rednwhitec20
My favorite there was this sweet LS9 swapped GMC.
K20 Build
Old 09-19-2016, 06:46 PM   #125
Rednwhitec20
This crew was widened the best feeling to fit on an LBZ chassis. Still a dually, has the 07 dash, and was built to haul his camper. Had a lot of bodywork done. He said the hood was 14 pieces to get it to fit. There were 2078 cars that went for the 30th! Hope the Dmax is done for the 31st!
K20 Build
4x4 build, 6 inch lift, duramax conversion, duramax swap, k20
