Old 02-25-2016, 09:14 AM   #101
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Let's Build A 1 Ton Crew Cab 4x4
Hmm I would try eBay for the u bolts. Or, if you call ord, they will sell you just the rear u bolts.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-25-2016, 09:19 AM   #102
NastyBuzzard
NastyBuzzard's Avatar
Yeah I have been searching ebay and the net.. Seems like longer U bolts that are 5/8" diameter and 3.375 wide are just really expensive. Cheapest set I have found was like $70 with shipping. For that price I should just buy ORD's U bolt flip kit, which is like $87 plus shipping so probably $100. I haven't decided.
I did find a cheap set for like $30 but turned out they were just grade 5 and I don't trust that. Especially when it isn't supposed to be torqued over 110#.
Still no luck finding clutch/brake pedals for what I need and no luck on a reasonably priced transfer case either.
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 02-25-2016, 10:07 AM   #103
MTCK
MTCK's Avatar
I had to look long and hard for the hydro clutch pedal setup. Eventually bought one from a guy advertising on pirate. All the junk yards I looked at were cleaned out and it ended up costing me close to $300 for the pedals, mater, slave, line and reservoir. Good luck. Oh and I can have custom u bolts made locally, so maybe check that option in your area.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-25-2016, 10:13 AM   #104
NastyBuzzard
Unfortunately, I live in a very rural town out in the country. The town I commute to for work is larger but really doesn't have jack in it as far as getting stuff like that done but I do have some calls to make.
Yeah that price sounds about right.. I have seen pedal assemblies for $300 just for the pedals at least you got the other parts. I have a few places to go look but I don't have high hopes.
Old 02-25-2016, 01:47 PM   #105
slotard
Originally Posted by daddyjeep View Post
My local Napa will bend whatever U bolts a guy could need. I'm not sure if it is just my store, but have you checked locally for the bolts?
It's your store. I asked the one near me a week or two ago about U bolts and they suggested some other places.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 02-25-2016, 01:56 PM   #106
NastyBuzzard
Yeah my napa acted like they didn't even understand the question.
Old 02-26-2016, 07:57 AM   #107
NastyBuzzard
I got all of the rear hangers off. Plus the little hanger support for the rear which I noticed I am missing for my 4x4 hangers. May have found one though so that's not too big of a deal.
I started to mount the rear last night but was kind of hesitant. I am going to pull my other 4x4 up to the shop to take measurements. I want to place these in the correct position the first time.
Old 02-27-2016, 12:43 PM   #108
NastyBuzzard
Wink Re: Let's Build A 1 Ton Crew Cab 4x4
Teaser
Old 02-28-2016, 04:53 PM   #109
COS399
COS399's Avatar
Looking good. How much did you cut out of your frame?
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-28-2016, 06:04 PM   #110
NastyBuzzard
To make it a short bed? If so, I've cut out 14" behind cab but I still have a few to cut off at the rear of the frame just haven't done it yet.
Old 02-28-2016, 10:48 PM   #111
COS399
COS399's Avatar
Yes, to make it a short bed. Thanks for the information. Keep it up.
Old 02-29-2016, 10:55 AM   #112
y5mgisi
y5mgisi's Avatar
Nice work!
Old 02-29-2016, 04:06 PM   #113
NorCalAnthony
Nice work! I've always wanted a short bed crew cab square and can't wait to see how yours turns out
NorCalAnthony is offline   Reply With Quote
Old 02-29-2016, 04:18 PM   #114
NastyBuzzard
Thanks!! I'm liking it more and more that is for sure!
Just wish I could get my dang engine!
Old 03-01-2016, 09:47 AM   #115
NastyBuzzard
I will start off by saying this was very scary to me and I hope I did it right! What I did was measure exactly the same as the 4x4 donor frame then drop it down 1". I hope this will work out. For some reason drilling this 2" hole with my hole saw and little dewalt drill took 45 min and lots of breaks. The other side took like 15 but I used my giant milwuakee drill.
This was a good feeling. I am worried about the rear shackle angle. However, not a lot I can do without all the weight on it.
I also finally opened up the 79 rear diff to see what gears it had so I would know what gears my Dana 60 has. Turns out it is 4.10's which is exactly what my 88s stock gears where so no worries about not matching gears anymore.
One thing I could really use some HELP on is the engine crossmember. Most threads I have read people used DIY4x crossmember or something other than oem stuff. I am having problems with fitment so I will need to figure out what to do here.
I wanted to see what it would need to take to get this thing level so I threw some temporary blocks on the back.. I hate blocks and doing this motivates me to buy what I need whether it is 4" springs or the shack flip kit which is way too expensive now a days. I may just make my own.
I feel like once all the weight is on it will sit somewhat level but I tell you, it is a heck of a lot taller than I thought! Which isn't bad or good but still shocking me at this point.
Old 03-01-2016, 01:27 PM   #116
daddyjeep
daddyjeep's Avatar
I would think the shackle flip could be built quite easily for about $40 versus almost $200 to buy it.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 03-01-2016, 01:43 PM   #117
NastyBuzzard
It is ridiculous! I remember when DIY4x was cheap!
My friend has a design for one so I may just get my other friend with plasma cutter to cut it out and weld it together. Temporarily though I have to track down just 2 u bolts 2.5" wide and about 13" long. I am even having a hard time finding that for a reasonable price.
I have to find someway to get the engine crossmember in so that I will feel safe removing the front crossmember that the brake proportioning valve is bolted to so I can replace it with the 4x4 version. Which I heard may not just fit right in either.
Old 03-01-2016, 03:53 PM   #118
y5mgisi
y5mgisi's Avatar
I seem to recall that there is a frame height difference between 2wd and 4wd in the engine crossmemeber areas? What is your fitment problem? I remember seeing in one thread that the 4x4 engine mount brackets were too tall to fit in the 2wd frame so a guy just made some kind of 1/4" slots in the brackets so they would slide into/onto the upper frame rail lip. Is that the trouble you are having?
Old 03-01-2016, 03:59 PM   #119
NastyBuzzard
Yes the problem is that the 4x4 engine mount brackets that attach to the crossmember seem too tall to fit inside the frame rail like they are supposed to.
The crossmember itself slides in no problem.
I am not understanding what you mean when you say they slotted them to make them fit.
I haven't spent a lot of time trying to make them fit either.
Old 03-01-2016, 05:26 PM   #120
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
On my 76, I used 2wd rear spring/shackle hangers, a DIY4x shackle, and no block to get my rear suspension up. This required cutting the spring perches off the rear axle to reset pinion angle though. It was cheap and works. In the pic, I still have to make or install the lower half support bracket for the hanger.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-01-2016, 08:23 PM   #121
y5mgisi
y5mgisi's Avatar
Like this.
Old 03-01-2016, 08:24 PM   #122
y5mgisi
y5mgisi's Avatar
So it's basically like a sliced a slot into the engine mount bracket for the frame rail to slide into.
Old 03-01-2016, 08:29 PM   #123
NastyBuzzard
Thanks for that. I understand now.
Old 03-02-2016, 08:23 AM   #124
NastyBuzzard
I went out and tinkered for a minute last night.
Here is the engine mount slotted. The 4wd frame is 1/2" taller in the area that the engine cross member mounts. More bad news is where the front cross member that the brake proportioning valve mounts to is like 6" tall from the 4x4 but the 2wd frame rail is only about 5-1/4" tall in the area it should mount so that is going to be interesting as well...
I was installing my new U bolts and found some issues I need to resolve. Always something. I need a shorter stud for one.
Still need to find somewhere I can buy just 2 cheap U bolts that are square, for a 2.5" wide leaf spring and 13" long. These will temporarily mount the blocks until I can build my rear hangers. I need to be able to roll this thing out the shop soon to clean and paint the frame.
Old 03-02-2016, 08:34 AM   #125
y5mgisi
y5mgisi's Avatar
Are those from ord?
