Old 05-07-2016, 12:25 PM   #101
6t9camaro
6t9camaro's Avatar
Re: 67 C10 "Green Gobblin" straight from the field!
Finally Primer!
6t9camaro is offline   Reply With Quote
Old 05-08-2016, 11:11 AM   #102
6t9camaro
6t9camaro's Avatar
Pics of the fenders bodywork/primer
Old 05-08-2016, 11:16 AM   #103
6t9camaro
6t9camaro's Avatar
Inside cab dash blocked and remainder of interior sanded and seam sealed ready for paint!
Old 05-08-2016, 11:23 AM   #104
6t9camaro
6t9camaro's Avatar
Interior cab painted factory Green. (finally)
Old 05-08-2016, 11:25 AM   #105
6t9camaro
6t9camaro's Avatar
More
Old 05-08-2016, 06:02 PM   #106
mooseknuckles
mooseknuckles's Avatar
looks good!
mooseknuckles is offline   Reply With Quote
Old 05-25-2016, 06:18 PM   #107
6t9camaro
6t9camaro's Avatar
Finally got back onto the truck and got some green paint on it! I think the worst part if putting the floor in so far has been sanding it!!! It turned out pretty good though but now i have to mock the fenders and doors up and blend the patina!
Old 05-25-2016, 06:22 PM   #108
6t9camaro
6t9camaro's Avatar
More Floor
Old 05-25-2016, 06:24 PM   #109
6t9camaro
6t9camaro's Avatar
One of the fenders! kind of a shame to scuff it up and spray some brown?blk onto it! lol
Old 05-25-2016, 08:22 PM   #110
flashed
Wow,you got it looking great .
flashed is offline   Reply With Quote
Old 05-25-2016, 09:28 PM   #111
hewittca
hewittca's Avatar
wow! That is some impressive metal work. Looking forward to the rest of the project. I also have a dark green truck. You don't see too many of them in this color. Yours is some definite motivation!
hewittca is offline   Reply With Quote
Old 05-26-2016, 07:32 AM   #112
Shady Rascal
Shady Rascal's Avatar
Solid work ethic.
What paint are you using ?
Shady Rascal is offline   Reply With Quote
Old 05-26-2016, 08:16 AM   #113
Bennett68C10
Bennett68C10's Avatar
Nice job!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-26-2016, 08:56 AM   #114
MMcMasters
MMcMasters's Avatar
Excellent work!
Mike
Mike
70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804
Instagram- protouring66
MMcMasters is offline   Reply With Quote
Old 05-26-2016, 09:19 AM   #115
roushinator
roushinator's Avatar
Nice Work!!
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 05-26-2016, 09:56 AM   #116
6t9camaro
6t9camaro's Avatar
Originally Posted by Bennett68C10 View Post
Nice job!
Originally Posted by MMcMasters View Post
Excellent work!
Mike
Originally Posted by roushinator View Post
Nice Work!!
Thanks guys! She's getting there! Yes hewittca you gotta love the old green trucks!
Old 05-26-2016, 10:03 AM   #117
6t9camaro
6t9camaro's Avatar
Originally Posted by Shady Rascal View Post
Solid work ethic.
Thanks! I'm using PPG Omni acrylic enamel I find I could get a good match and it blends pretty good once sanded and cleared with a Matt finish.
Old 05-26-2016, 10:48 AM   #118
aggie91
I'm just glad to be here!
aggie91's Avatar
Little late to the build, but your work is top notch. I really like the spots you chose to fix patch the dash, way less finish work involved in those spots!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-30-2016, 10:57 PM   #119
6t9camaro
6t9camaro's Avatar
Thanks! Ya i figured those spots were perfect as there mostly covered by the glove box, dash pad or gauges.
Old 05-30-2016, 11:06 PM   #120
6t9camaro
6t9camaro's Avatar
Today was a good day as i started tearing down the doors and i also finally got some parts in that I've been trying to track down since i got the truck! My big concern was finding a tailgate with the right patina! Thanks to a fellow member on here that lead me to a seller! I paid a good buck for it but when i finally saw it in person it was worth it as the match is perfect!
Old 05-30-2016, 11:13 PM   #121
6t9camaro
6t9camaro's Avatar
I also got a pile of trim! I was actually only looking for 2 pieces to change some damaged ones. I also wanted used ones to match the rest but i ended up having to buy a whole pile of it! Also got my nicely used and rusty center caps to go with my 15x8 wheels! One of them is in a little to good shape but i will fix that up and make it match! lol
Old 06-01-2016, 07:56 PM   #122
6t9camaro
6t9camaro's Avatar
Got back to the doors today! I stripped all the guts out and have all new internals on order (LMC) Doors are nice and solid with some light rust but a lot of dents/damage at the bottom. I didn't want to go to crazy with fixing the damage but i did want to stop the rust so i cleaned it up and put the Por15 to the test again! (if it doesn't last then i will change out the bottoms) After the Por 15 dried i sanded them down and put a nice topcoat of green and clear over it.
Old 06-01-2016, 07:58 PM   #123
6t9camaro
6t9camaro's Avatar
Paint
Old 06-01-2016, 08:03 PM   #124
6t9camaro
6t9camaro's Avatar
Got the Doors back on and the alignment and gaps set! I even had my daughter come give me a hand!
Old 06-01-2016, 08:29 PM   #125
jlsanborn
jlsanborn's Avatar
Nicely done! I'll follow this along too. I've never seen that much re-pop metal go down without any drama. See guys installing all this x-bracing and such to hold it true but the doors still don't fit worth a sh!t. I didn't read the whole thing but did notice that you have six lug wheels? Thought you were using the '72 stuff?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
