Old 04-09-2016, 09:31 AM   #101
reaper71
reaper71's Avatar
Re: Reed 78 FJ40 Rebuild
Thank's Kees...
The orange would look better in a diff. application. The Customer absolutely loves the new look..
Mark...
reaper71 is offline   Reply With Quote
Old 04-10-2016, 10:46 AM   #102
Advanced Design
Advanced Design's Avatar
Originally Posted by reaper71 View Post
Quick update...
Pic #1. The mount all welded in and final.
Pic #2. We felt the orange was a bit much for this rig...
Pic #3. After some wrinkle black and masking.
Pic #4. The final product.
What you Guy's think?
Mark...
That looks good and was some pretty impressive tape work. Razor blades and Exacto knives?
Advanced Design is offline   Reply With Quote
Old 04-11-2016, 09:58 AM   #103
reaper71
reaper71's Avatar
Yes....Kind of
The valve covers came with the stickers on them...So I kinda cheated
Mark...
Old 04-15-2016, 10:18 AM   #104
reaper71
reaper71's Avatar
Pic #1. The steering was finalized and installed.
Pic #2. Another view (if your curious the angle is 20 degrees) specs are 30
Pic #3. I also started on getting the new seats and mounts mocked up.
Pic #4. Will need to make a riser for Drivers side seat (sits lower than passenger side A factory thing I guess)
Mark...
Old 04-18-2016, 11:37 AM   #105
RockinKees
RockinKees's Avatar
Reminds me of the Jeep M38, when I was in the army a little while ago
The drivers seat was also on the fueltank.
As if there's no place else to put them
It's going to be a very nice car! Something to be proud of
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 04-18-2016, 07:33 PM   #106
BlueJeep
BlueJeep's Avatar
I have a couple of flatfenders waiting to be worked on, so I've done a bit of research. The design philosophy on the military jeeps having the fuel tank under the driver's seat was to minimize the "kill zone". Use that piece of trivia in a game sometime!
FJ looks great!
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-19-2016, 07:28 AM   #107
roushinator
roushinator's Avatar
Awesome Work! I wish i would have kept my FJ40
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 04-19-2016, 09:25 AM   #108
reaper71
reaper71's Avatar
Thanks Kees, it's a bit spooky sitting on top of a bomb!
I was going to put a fuel cell under the body in the rear but he decided on the extra muffler instead.
Bluejeep thank's for the "tidbit" And thank's for checking out the build.
Roushinator thank's, it's been alot of work getting it to this point, but well worth the effort.
Mark...
Old 05-02-2016, 09:54 AM   #109
reaper71
reaper71's Avatar
Pic #1. I had to make a 1" spacer for the Drivers seat (it sits lower than the passenger do to the tank)
Pic #2. Setting up the twin stick blocks and linkage for the 4wd
Pic #3. The sticks after getting them bent to fit through the floor.
Pic #4.
Old 05-04-2016, 09:31 AM   #110
reaper71
reaper71's Avatar
Pic #1. The new sticks installed and ready to make the new rings for the boot etc.
Pic #2. New rings made and installed and hump modified to accommodate shifter.
Pic #3. Roll cage back in to mockup pull handles,rear seats and seat belts.
Pic #4. Cage getting welded up.
Pic #5. Getting more comfortable with the new TIG unit.
Mark...
Old 05-04-2016, 08:20 PM   #111
Advanced Design
Nice Tig welds Mark. Mine don't look like that....yet.
Old 05-05-2016, 10:51 AM   #112
reaper71
reaper71's Avatar
Thank's Doug, It's all seat time...practice,practice my friend!
It will come I have no doubt
Mark
Old 06-09-2016, 09:50 AM   #113
reaper71
reaper71's Avatar
So, The FJ came back in for another round of fabrication.
This time it is (rock sliders) to protect the rocker panels.
Pic #1. After alot of figuring on how and where I needed to mount the first plate I marked out the 4 holes and drilled.
Pic #2. In this pick It shows the 2nd plate installed.
How I figured all this was having the slider set in place for measuring (Not Pictured) I had it set on 2 high tech lifting units (milk crates )
Pic #3. After the tubes were cut and fit I then tacked them to the slider and then did my final weld pictured here.
Pic #4. Next, was making some gussets for the tubes that were welded to the plates.
Pic #5. The Gussets all welded in place.
Mark...
Old 06-09-2016, 09:59 AM   #114
reaper71
reaper71's Avatar
Pic #1. The finished product...Now the passenger side.
After I finished the passenger side I moved to the back.
Pic #2. In this shot it is the new rear bumper, The 3 plates that are sticking up are for mounting it the the rear chassis plate. They all have to be drilled out for mounting. (No template comes with the kit, so I made my own)
Pic #3. I used my trusty poster board and cut 4" pieces to fit the full length across the plates and marked out the holes.
Mark...
Old 06-09-2016, 02:56 PM   #115
RockinKees
RockinKees's Avatar
Those rocker protectors look quit sturdy!
Are they from stainless steel so you can polish them?
Or are they going to be painted?
Cheers!! Kees.
Kool Guyz CC
Old 06-10-2016, 10:03 AM   #116
reaper71
reaper71's Avatar
They are pretty heavy pieces (50 lbs or so)
No made from carbon steel. They will be powder coated wrinkle black to match the rest of the components.
Mark...
Old 06-10-2016, 10:11 AM   #117
reaper71
reaper71's Avatar
Pic #1. The bumper all mounted up.
Pic #2. The spindle looking pieces are for swing out arms mounted on bearings. These will have the spare tire mounted to the drivers side and a cooler mount on the passenger side.
Mark...
Old 06-10-2016, 12:11 PM   #118
dug224
dug224's Avatar
Beautiful work. Really enjoying the build. dug
dug224 is offline   Reply With Quote
Old 06-13-2016, 09:15 AM   #119
reaper71
reaper71's Avatar
Thank's again Dug..
Old 06-13-2016, 01:46 PM   #120
Low Elco
Super nice stuff!
Low Elco is offline   Reply With Quote
Old 06-14-2016, 09:55 AM   #121
reaper71
reaper71's Avatar
Thank's, The quality of the components the customer has been getting is really nice stuff and Really heavy duty.
Mark...
Old 08-11-2016, 09:29 AM   #122
reaper71
reaper71's Avatar
It's been awhile since I posted on the FJ....
It came back a few weeks ago and I have been getting a few things done.
Now that the GMC is finished I can get to work on this one..
Pic #1. The morning it came back to the shop.
Pic #2. The new Radiator/shroud and fan from Champion.
Pic #3. The expansion tank added as well.
Will have more to show later.
Mark..
Old 08-11-2016, 05:11 PM   #123
RockinKees
RockinKees's Avatar
All looks nice Mark!
The FJ looks very big in front of your shop!
Cheers!! Kees.
Kool Guyz CC
Old 08-11-2016, 08:37 PM   #124
Advanced Design
Continued nice work Mark, looking forward to the updates.
What is the vehicle with yellow and black stripes in the first pic next to shop?
Old 08-11-2016, 10:33 PM   #125
reaper71
reaper71's Avatar
Thanks Kees!
Yes it is a bigger vehicle for how small it really is...
When the rollcage is bolted on it takes on a whole new look!!
Doug....That beast in the background is a 89 ford e350 conversion bus..
it is (Grishams ) Tailgate/party bus for Missouri football games.
it was at the shop for a few repairs.
It's not something I would normally work on but foe John I will
Mark...
