Old 05-16-2016, 05:05 PM   #101
Ski-me
Ski-me's Avatar
Re: LS swap for my 75
Originally Posted by lowrodderchev View Post
Finally got my drivelines back buuuut lol guy put larger u joints for a newer truck not a 75 blazer with 1310 u joints so tomorrow I gotta shoot the drivelines back to him and well see how long it takes
Attachment 1531425
Can you just install a conversion u-joint instead? Or is the driveline shop local?
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 05-16-2016, 05:44 PM   #102
lowrodderchev
lowrodderchev's Avatar
He's local. I got it all button up and the angles were off. So I put a inch spacer on the t case. Hopefully I won't have any vibrations
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 05-16-2016, 05:58 PM   #103
Ski-me
Ski-me's Avatar
Ahhhh.....the joys of driveline vibration! Hopefully that will fix it. Be sure to use good quality bolts rather than just using the factory ones. Better strength.
- Jeff
Old 05-16-2016, 06:21 PM   #104
lowrodderchev
I picked up grade 8's with matching nuts �� and drilled out some 1x1 heavy duty square tubing I had laying around its not about 2 degrees off from each other which if I heard correctly is ok
Old 05-17-2016, 09:43 AM   #105
Ski-me
Ski-me's Avatar
For non-CV drivelines (what you have I believe), you want the t-case angle, and the axle pinion angle, parallel to one another.
In other words, if the t-case is down 4 degrees from horizontal, you want your axle pinion pointing up 4 degrees from horizontal.
- Jeff
Old 05-17-2016, 09:43 AM   #106
lowrodderchev
Yeah so I used a app on my phone to measure the angles and it was way off lol turned out I was only 3 degrees difference minus the spacers. 7 up front 19 in the middle and 10 in the rear. Spent all day lowering it, moving the shifter linkage, then some how the rod on my column for the key came out so I gotta fix that now. I really miss driving her
Old 06-08-2016, 09:21 PM   #107
lowrodderchev
Exhaust is done but I'm a little worried about how close they are to my transfer case. what do you guys think?
Old 06-08-2016, 09:23 PM   #108
lowrodderchev
few more pix just for the heck of it. the tow truck driving picking her up to go to the exhaust shop and my new AC delco plugs and wires
Old 06-08-2016, 09:55 PM   #109
68Timber
I know the pieces fit
68Timber's Avatar
I'll check mine in the morning and see how it compares but that does look a little close. How long are the mufflers and how close is the end of the muffler to the rear axle? If they're long mufflers he may not have had much choice.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 06-08-2016, 10:10 PM   #110
lowrodderchev
there flowmaster 44's I think there not long. the use to be further down the way from the case. I'm not sure why the put them there. but before I go talk to the guy thought I'd get your guys opinion
Old 06-08-2016, 11:44 PM   #111
68Timber
68Timber's Avatar
Super 44's are relatively small iirc, maybe 14 or 16" case. I'll check it against mine in the morning. First guess is the mid-pipes were cut a bit short but we'll see.
John
74 Honda Z50 build
Old 06-09-2016, 09:42 AM   #112
68Timber
68Timber's Avatar
I dunno why they put them there, I had to look to verify but there's plenty of room to keep them away from the xfer case. Here's mine for reference and it has 14" mufflers.
John
74 Honda Z50 build
Old 06-09-2016, 09:46 AM   #113
lowrodderchev
That's were mine use to be I have no idea either. Do you think I will have a issue with heat on the t case right there
Old 06-09-2016, 10:02 AM   #114
68Timber
68Timber's Avatar
It's hard to say, it might run till the end of time with no issues. Here's how I'd approach it. If it adds heat to the xfer case right there the tailshaft seal will take the brunt of it and if that fails you've got the possibility of transmission fluid getting on the mufflers. Now you're up to potential fire hazard/burning your truck down etc. I would want them to move the mufflers back. Is this a shop you've used before?
John
74 Honda Z50 build
Old 06-09-2016, 11:57 AM   #115
lowrodderchev
I've used this shop before there pretty reputable. I called them this morning he said because the flowmaster is a high flowing muffler it doesn't trap much heat and it would be ok. so I guess i'll roll the dice and see what happens LOL
Old 06-09-2016, 01:54 PM   #116
68Timber
68Timber's Avatar
You'll probably be fine, just check that seal when you're under it.
John
74 Honda Z50 build
Old 06-14-2016, 10:29 AM   #117
lowrodderchev
Got her fired up yesterday. So far only two issues, not charging guessing wiring since I dont know what I'm doing and a cracked tranny line just need to put a new line she
Old 06-14-2016, 10:50 AM   #118
Ski-me
Ski-me's Avatar
Excellent progress and looks great in there!
- Jeff
Old 06-14-2016, 11:02 AM   #119
68Timber
68Timber's Avatar
Congrats!
John
74 Honda Z50 build
Old 06-14-2016, 04:46 PM   #120
lowrodderchev
when I first fired her up I wasn't happy with the exhaust. sounded to weak but after running for about 15 minutes the sound changed. going to try to make time in the next few days to get the other stuff fixed. after that I'm going to satin black the whole truck just to match the old new fenders I put up front
Old 06-26-2016, 05:59 PM   #121
lowrodderchev
for awhile there I was saying I should have just kept the 350 screw this LS swap crap. well I would like to retract my previous statement LOL I finally got to drive her yesterday and I gotta say the power is amazing. wow its a huge difference night and day. I have a few bugs to work out but I'm pretty happy so far. I'm going to start looking into a code reader just in case cause I pretty sure i'll be doing another soon
Old 06-28-2016, 11:13 PM   #122
68Timber
68Timber's Avatar
Are you running the stock tune?
John
74 Honda Z50 build
Old 06-28-2016, 11:58 PM   #123
lowrodderchev
The guy who did it said they adjusted it for little more power im still working out bugs today seem like it was running hot
Old 06-30-2016, 09:51 AM   #124
lowrodderchev
Not happy with the exhaust not as loud and aggressive as it was with the 350. Running flowmasters with 2 1/2 pipe
Old 06-30-2016, 10:03 AM   #125
68Timber
68Timber's Avatar
Post a vid of it running?
John
74 Honda Z50 build
