02-07-2017, 11:45 PM | #101 |
Re: 1965 C10 ... Project Name: Just Learnin'
02-08-2017, 06:21 AM | #102 |
Engine color looks good!
02-08-2017, 10:35 AM | #103 |
Coming along nicely!
What's the story on the VW in the background? Mark.
http://67-72chevytrucks.com/vboard/s...d.php?t=645774 Project Orangepeel 52 A.D. http://67-72chevytrucks.com/vboard/s...d.php?t=653337 John's LS 49 dodge http://67-72chevytrucks.com/vboard/s...d.php?t=655780 Blake's 67 GMC LS stepside http://67-72chevytrucks.com/vboard/s...d.php?t=690527 Reed 78 FJ40 Rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=733259 Barger's 78 FJ40 |
02-08-2017, 10:45 PM | #104 |
02-08-2017, 10:47 PM | #105 | |
I will get some better pictures for you tomorrow its a pretty slick little ride.. |
02-11-2017, 01:32 AM | #106 |
02-11-2017, 09:07 AM | #107 |
02-16-2017, 03:03 PM | #108 |
Ok guys I'm running into serious wiring issues.... (Yes I hate electrical stuff)
Here is what I have laid out so far, my problem is the two black question marks, not sure first of all if I am at all correct but also now that I have removed the coil and switched to her I'm wondering what to do with the wire from the firewall plug that used to go to the coil. Any help today would be greatly appreciated!! Also just for fun here's how she currently sits Posted via Mobile Device |
02-16-2017, 07:15 PM | #109 |
Get rid of the wire from the HEI to the starter. It is not a true 12V. Take and run a wire from a switched 12V source directly to the HEI.
Some folks run a wire directly from the Fuse box switched connection to the HEI. I happened to use the 12V that was supposed to go to for the water temp light on the dash to the engine sensor. Since it was already in the harness and I wasn't using both the hot and cold light power leads, I used one for the HEI. Some folks use the ign power to operate a relay that runs the HEI power straight from the battery.
02-16-2017, 11:04 PM | #110 | |
Sorry Im sure I've said it before but I'm terrrrrrrible with electronics |
02-17-2017, 06:23 AM | #111 |
Myabe these will help
02-18-2017, 07:31 PM | #112 |
Thank you!! These were a huge help, I just could not visualize what was supposed to be going on, I think I have everything planned out and roughed in so tomorrow morning I hope to get over to the shop and put wire to metal.
Total side note but DEAR GOD I WANT MY OWN SHOP!! when we moved away from our old shop i figured it wasn't that bad, only a 20 minute drive from our new pace. But a 40 minute round trip just to do an hour or so of work here and there sure becomes very frustrating over time, its all fun and games if i have time to go for 5 or 6 hours but some days it sure sucks. ok I'm done *****ing for today. |
02-21-2017, 11:32 PM | #113 |
Not much to update but managed to figure out my wiring issues yesterday... rebuild and cleaned up my passenger side harness and tied it in with my air system harness, everything comes up pretty tidy.
Next step will be tackling the drivers side harness tomorrow if I can find some time. When I first bought the truck I drove it to a local shop because the horn would no longer work properly, when you pressed the horn it would sound and not stop, so due to my lack of electrical knowledge I figured I would take it to a pro.... turned out the asshole was too lazy "to figure out which one was the horn wire in all those wires". He actually drilled a hole in my dash (WITHOUT ASKING) and directly wired a push button straight to the horn... so now I have to figure out what was wrong there..... |
03-03-2017, 05:35 PM | #114 |
well progress is slow, apparently my orders for carpet and lmc stuff are in at the border, now i just have to find time to get down there and pick them up
03-04-2017, 01:05 AM | #115 |
60-66 Nut
It looks to me like you have long water pump pulleys with your short water pump. Do any of the belt grooves line up?
03-04-2017, 01:12 AM | #116 | |
03-06-2017, 01:13 AM | #117 |
So I wanted to switch up the fan from the ugly ol stocker and I decided to switch it up a little..
started with this guy a little elbow grease and ended with this guy (have i told you how much i hate chrome and silver) and here she is folks, finally done and spitting flames again! blew the fuel pump on start up but thats best of a bad situation i guess... |
03-06-2017, 01:19 AM | #118 |
03-06-2017, 10:18 AM | #119 |
You gotta love the snotted up mess that you find on these thing's some times!
Mark.
03-06-2017, 11:01 AM | #120 |
Engine looks great sitting in there! Unfortunately with these old rigs there will be a lot to "de-silver and de-chrome" for you .
03-11-2017, 10:08 PM | #121 |
Thanks man, shot a whole lotta flames and just about burnt the shop down when the fuel pump let go but sure am happy with the way she runs too
03-11-2017, 10:14 PM | #122 |
Well got a couple hours in the shop this morning and the girly friend even lent me a hand to hang some doors, going to take some time to get them to fit properly but it was sure nice to see things going back together!!
03-12-2017, 12:00 PM | #123 |
03-12-2017, 12:05 PM | #124 |
Now time to tackle this old thing
First i took a dremel and gave myself a bigger groove to work with A little bit of quick steel from the dirt bike world... apparently the bush boys use it repair case cracks in the woods so i hope it can hold up to a steering wheel.. Now todayI will try and sand it down and get the shape back t factor lines |
03-13-2017, 10:43 PM | #125 |
Looking good man, keep the updates coming.
