#101 | |
Equal opportunity joke ofender
![]() Join Date: Oct 2011
Re: 67-72 Suburban OE seats
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
#102 |
Junior Member
![]() Join Date: Mar 2015
That is excellent news, certainly broadens my range of search options!!
#103 |
This 3/4 2nd row seat appears to be a factory seat, but I cant say the same for the mounting brackets...
#104 |
I have a question maybe one you fine folks can answer for me. Were the seat brackets and bases always painted black or did other colors get used?
Thanks in advance.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#105 |
Black is the only color I have seen other than the orange burb I just dismantled and they were chrome but obviously done at a later point in life
#106 |
Thanks again Richard. Just trying to figure out what color to paint the brackets for my new second row seat.
#107 |
Now that i finally have two short rows and all brackets, I'm trying to put 3 point seat belts in the back two rows. (kids you know?)
I get that the middle straps and lap belts go through to the floor brackets that have a nut welded onto the back (already shown in this thread somewhere). I have those on both of my seats. However in the back, I attached a photo where the original OUTER lap belt came through ( this was a blazer, not sure if suburban is exactly the same). I could technically bolt the retractor onto this right? I might need to trim my seat covers to make it fit.. On the seat the is taken apart the threads are pretty large, I can use a large bolt? What have other people done for mounting rear three point belts? Also - anyone done it on a short row? I feel like the three point would get into the way for anyone trying to get in the back. I might only mount three point on the left side of the back two seats which would look strange but function for all my kids. |
#108 |
Personally I wouldn't attach it to the seat frame that high up. Too much of a chance for things to detach or deform during an accident for my liking.
This link shows how member BeachBurban did his. Scroll down to post 340. I hope this helps http://67-72chevytrucks.com/vboard/s...680126&page=14
#109 |
Hi folks-
I am looking to unload a front bench seat from my 1971 GMC Suburban. Free. To the first person who can pick it up in Sun Valley, CA. Frame is good, rails are good. Vinyl and foam are less than good. Maybe a broken spring or two. Free. PM me. Ok; I'll post a pic if I can figure it out. In the meantime, PM for a pic. Last edited by gratefuldog; 12-16-2019 at 09:53 PM. Reason: clarity |
#110 | |
PM sent... Woody |
#111 |
I picked up a 1968 K10 in decent shape. I have what i believe second and third row seats. Both seats measure 48.5' seat width and 50' with arm rest. From the seating diagram in this discussion i believe those measurement are correct. Can someone confirm that for me. I have both sets of second row brackets and third row brackets. Can someone confirm that too. Orginal seat belt placement, do the seats belts mount to the floor w/ the underside bracket or so they bolt to the seat bracket?
#112 | |
You also need four "hold-down" clamps and four bolts for the front tubular brackets...two for each seat...but they mount differently on the rear seat than they do on the center seat! The first "hold-down" picture shows the center seat with the clamps running in a "front to back" direction, where the second picture shows the rear seat clamp running in a "side to side" direction. The holes in your floor should line-up with a factory welded nut under the brace. I hope this helps? Woody Last edited by Beach-Burban; 12-18-2019 at 07:27 PM. Reason: Add picture |
#113 |
From the holes in the floor it looks like that '68 originally had just a front and middle seat.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#114 |
#115 |
Woody I just got the spare tank. Yes it was for the shorter 2nd row. At least mine was. Great member gave it to me. Here’s pics of bracket. I’m not sure if tank required diff seat legs or was just underneath
#116 | |
Woody |
#117 |
Let me do better pics. I’m not sure I have an easily accessible seat right now but the killer is cutting a hole for the gas fill
#118 |
Yes I just pulled the second row tank out!! The second row seat matches up to the bolt pattern on the fuel tank.
#119 | |
Woody Last edited by Beach-Burban; 12-19-2019 at 06:48 PM. Reason: Clarity |
#120 | |
The seat does not sit off to the drivers side. It sits in the middle over the tank. Just take off the front tubular brackets and the tank bolts right up to the seat. |
#121 | |
No problem rotating the photos...I had the same issue at first, then a member here helped me out! It seems that this is an inherent problem with pictures taken on an IPhone...and the trick is to copy the picture into a different album or file, then use that one for posting! A couple extra steps...but it worked! I hope it works for you, too! Woody |
#122 | |
Last edited by LockDoc; 12-29-2019 at 12:39 PM. Reason: Need to be a Premium member to post stuff for sale |
#123 |
Question on front row seats. Are front bench seats from 67-72 Suburban interchangeable with front bench from 67-72 trucks?
#124 |
I had thought so myself but the general consensus is yes they are the same. But there are differences over the years involving seat mounts and seat backs. There is more information in the link.
https://67-72chevytrucks.com/vboard/...d.php?t=804108
#125 |
What?
Yes, but the back of PU seats are not covered.
The tracks are different, but they will bolt in fine.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
| Bookmarks |
