Old 01-27-2004, 04:17 PM   #101
miket
miket's Avatar
Busterwivell:
Better make sure all ancillary items that will touch that motor are new or flushed (radiator). If anything goes wrong they will look at that very closely...
It wouldn't be bad to video tape the beak in procedure so that you can prove you did it right....
After this episode I am a firm believer in a motor dyno before install....especially if its close to you....
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 01-27-2004, 04:57 PM   #102
68racer
Yeah baby!
68racer's Avatar
Mike, very nice! My 502 showed up early, now I've got to find time to fit it. Which engine mounts and position are you using? It looks good set back like that. I am hoping to use the inline six mounts that the 350 is on.
Girlfriend just bought a steel model B Ford tudor and wants half the garage to keep it in. Women Going to make it tight putting the 502 in with that in the way.
11.37 @116
68racer is offline   Reply With Quote
Old 01-31-2004, 01:32 AM   #103
miket
miket's Avatar
I used the original BB mounts complete...got them from pickmup in Oly, Wa. Good luck and let us know how it turns out.
Old 01-31-2004, 01:41 AM   #104
miket
miket's Avatar
Closure...
Okay I think it's time to wrap this up. I have driven my truck a few times now since getting it back. It's completely different. I don't know how to describe it but, it just seems like it is more refined. The ZZ502 out of the crate, in comparison seemed to fight itself, didn't seem to have the throttle response that this version does. It sounds different too.
Would I do this exact same thing again? No. but I got an education and know things I didn't before and hopefully this thread will help others too.
I do have to give kudos to Tom Sallee at Sallee Chevrolet. He stepped up to the plate when in fact he didn't have to and took care of the problem. I would have liked this to occur earlier but nonetheless, I ended up with a cooler motor. They are a very knowledgeable group and can build anything for you (and dyno it)!
I think this thread about covers any questions someone may have but if anyone has any....feel free to ask.
Old 02-04-2004, 12:42 AM   #105
phantom dually
Project92 SWB stepside
phantom dually's Avatar
MikeT do you have any BBC parts for sale?? Pm me if so.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 02-04-2004, 01:54 AM   #106
Stingray42
Woot.
Stingray42's Avatar
sweet, glad everything ended up good for you on your motor, sounds like your gonna have some fun with her! I have learned alot in this thread, you should deffinatly do the FAQ! Thanks!
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 02-04-2004, 03:48 AM   #107
miket
miket's Avatar
I did..posted them on the board and within 5 minutes they got snatched up. Thanks though.
Old 02-18-2004, 01:55 AM   #108
miket
miket's Avatar
Just an FYI....someone emailed me regarding my 502 issues offline. After sending a few emails back and forth, I got the final one today.....good info...
"It turns out my problem of a high RPM studder was with the lifters and was
caused by oil foam. I have my ZZ502 in a 55 Chevy which required changing
oil pans to a deep sump Moroso pan. The stock windage tray that came with
the motor would not work so I went ahead and assembled it without a windage
tray. Tell your friends, DON"T DO THIS, as the oil will foam causing the
hydraulic rollers to collapse at high RPM's and will run you nuts trying to
figure out the problem. I changed ignitions, carburetors, plugs, wires, you
name it all with no help. Finally I called Crane Cams who makes the cam for
GM and talked to one of the tech guys. He said, "oh yeah, thats oil foam
causing your problem", and I'm like DAMN! why didn't I talk to you first.
So I fabricated a new windage tray and the problem seems to be solved.
Anyway, thanks for responding and I'll make sure my lifter valley splash
guard is firmly in place."
Old 02-18-2004, 03:47 AM   #109
cobb_ben
cobb_ben's Avatar
Mike get that puney air filer off of that motor fast, its not letting it breath you need at least a 14x5!!!! It's suckin through a straw instead of drinking out of the glass, if you know what I mean. Man that truck is awsome, next you need a drivetrain, doubt it'll stand up long under all of those 663hp and 625ft lbs
'69 Chevy C10
400sb-350 crank 400 destroker!!! 377
2.02 dart pro1 alum.heads
msd, holley db
hooker pro-comps-3in exh.
3 spd. saginaw-3.73posi
Flat Bed...want Reg bed...trades?
cobb_ben is offline   Reply With Quote
Old 02-18-2004, 12:58 PM   #110
miket
miket's Avatar
Yup..it's long gone....took care of that asap. I have AOL's Tops speed electronic bug catcher scoop on it now!!LOL!
