Old 06-19-2017, 06:03 AM   #101
Joseph2001
Re: Newbie, Buying my first. 72 GMC K20
Thank you everyone! Its been a long couple of months. I guess I'll start this morning with cleaning her out, and later on when the suns out she may get hosed off. Also my Dad asked me this last night, should we run a fuel addative with this modern gas?
Joseph2001 is offline   Reply With Quote
Old 06-19-2017, 07:22 AM   #102
AJC
I don't run any fuel additive, but I drive mine every day. I seams that sitting with ethanol fuel blends causes problems. Others might have a better answer.
AJC
AJC is offline   Reply With Quote
Old 06-19-2017, 08:20 AM   #103
Moose Monkey
Moose Monkey's Avatar
Well Joseph, how does it feel on the start of this new journey? Glan you got her home.clean that tank out new filters fresh fuel
70 c 10 daily Rider
Moose Monkey is offline   Reply With Quote
Old 06-19-2017, 12:47 PM   #104
Joseph2001
I Pulled the flat bed this morning, hitting 2 birds with 1 stone, I can now see the amount of rusted out sections of frame (Not as bad as I was bracing for) and now I can get frame measurements for a better flatbed design. I am going out in a little bit to pull the seat and see how bad the floor actually is, Still think ill put a new floor pan in it eventually Anyways. And yes it feels good to be working on her, im covered in mud,dirt and grime and I love it.
Old 06-19-2017, 06:18 PM   #105
Joseph2001
Bed pulled, cab cleaned out. Dig some digging and was able go use the camera on my phone to get a picture of casting numbers on the block, Found transfer case numbers and identified axles. She is a 350 v8, transfer case is theNp205, and I've got a Dana 44 front axle, and the rear is a Dana 60. The Dana 44 was standard equipment on all trucks? And research tells me that you could get an Eaton HO52 or the Dana 60. Still haven't found an Id tag on the transmission yet, My dad thinks its a th400. Its raining now, tomorrow ill go out and pics of everything. Heres a pic of her with the flatbed removed, about 20 some odd bolts and I rolled the bed of in almost 1 piece, couple boards broke when I stood on the bed.
Old 06-19-2017, 06:19 PM   #106
Joseph2001
And of course the picture didn't upload right!
Old 06-19-2017, 06:29 PM   #107
outfield
Now the fun begins!
outfield is offline   Reply With Quote
Old 06-19-2017, 07:18 PM   #108
57taskforce
All about them K’s
57taskforce's Avatar
If it's an auto and original to the truck it will be a turbo 350. These trucks never got the turbo 400 from the factory in a 4x4. Looks like a great start!
Tyler
57taskforce is offline   Reply With Quote
Old 06-19-2017, 11:44 PM   #109
El Dorado Jim
congrats on finally getting your truck home, I love those old K20's....also, if your rear end is big and round it is an eaton, with a removable third member
El Dorado Jim is offline   Reply With Quote
Old 06-19-2017, 11:51 PM   #110
El Dorado Jim
here are some pics how to tell what trans you have, just by the shape of the oil pan
Old 06-19-2017, 11:53 PM   #111
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Chevyis a ho52 but gmc should be a dana 60. X2 on the 400. Originally would be a turbo 350. Pics would help us help you identify it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 06-19-2017, 11:58 PM   #112
El Dorado Jim
here is an eaton
Old 06-20-2017, 12:11 AM   #113
Chevyland
Chevyland's Avatar
This is where it's at!
Way to go kid
You look good in that thing
Chevyland is offline   Reply With Quote
Old 06-20-2017, 07:55 AM   #114
Joseph2001
I found some sorta Id numbers on the rear, C-30255, ill get some pics here soon, and ill get some pics of the oil pan and see what transmission it has. Also, any secrets to pulling the steering, or should I just go get the steering wheel puller? Id like to put in the new wheel Mr Terry sent me.
Old 06-20-2017, 08:16 AM   #115
Moose Monkey
Happy homecoming
70 c 10 daily Rider
Old 06-20-2017, 08:47 AM   #116
Moose Monkey
In reply to pulling wheel, please do not do the hammer trick. Do you have any pillars? A flat medal piece with holes where to threaded holes on the wheel and a nut on the top of the shaft. Tight down on the bolts evenly will pop to wheel up. I have done it using a short combo wrench
70 c 10 daily Rider
Old 06-20-2017, 09:02 AM   #117
Joseph2001
Unfortunately no, and if I tried the hammer trick, Id hit myself in the face. Ill go rent a steering wheel puller, I think its like 20-25$ at Auto Zone
Heres a pic of the rear, and yeah its a th350, just got under to check.
Old 06-20-2017, 11:51 AM   #118
Ol Blue K20
That's a Dana 60
Dale
Old 06-20-2017, 08:18 PM   #119
mud.man.rj
mud.man.rj's Avatar
Sounds like a good project, nice to have a K20, bit tougher than a 1/2 ton, can get some use puling whatever you want too.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 06-20-2017, 08:26 PM   #120
jocko
jocko's Avatar
Welcome and congrats on your new project. My first car was a 57 Bel Air in similar shape TH350 should be expected for the trans, that's the only automatic that came in K10/20 trucks - TH400 not a 4x4 trans option in this era, only came behind 2WD until in the later square years.
Old 06-20-2017, 09:25 PM   #121
Joseph2001
Thanks Y'all. She's gonna be a hard worker, Once she's built, Im hoping she'll tow a horse trailer well. Thinking about 1ton helpers in the rear and mounting a 5th wheel on the new flatbed.
Old 06-21-2017, 01:12 AM   #122
El Dorado Jim
I dont rent tools, if i need a tool once,I will need it again down the road, a steering wheel puller shouldnt cost more than $20.00 to buy
Old 06-21-2017, 09:08 AM   #123
Joseph2001
My Dad looked and there's a steering wheel puller at the Machine Shop, he's gonna bring it home this evening, If he remembers.
Old 06-21-2017, 08:01 PM   #124
midniteblues
midniteblues's Avatar
Nothing like the thrill of your first vehicle and you got a classic no less, even more exciting.
Congrats on finally making it the few mi. Home.
I think alot of us guys been watching this thread and waiting rite along with you, a few of us probably would have pushed it home by now
My oldest boy was 15 when we drug home his 67 short fleet.
It took us 3 years before getting it safe, legal and road worthy.
He washed dishes and scrubbed toilets at a restaurant for 2 1/2 yrs and put almost every penny he made into it of course alot of the bigger ticket items(motor,wheels, were either Christmas or b day gifts.
But in the end he still ended up with a $400 s10 dd that he also fell in love with.
But he did get too drive the 67 too his prom and graduation.
And he is still whooping on it now that he is 26.
Time and patience pays off, just don't lose track of your dream.
For now it looks as if you have alot of cleaning up to do.
A pressure washer sure comes in handy with that.
Just be extra carefull of what you do to it now ya might regret a wrong move one day.
And just to let you know we are all glad to see you finally get it home.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 06-22-2017, 09:23 AM   #125
Joseph2001
Thank you Midniteblues, and ill be right along the same, going to be saving every penny, Finding a little pickup so I have a daily driver when I get my license. Probably be a little 4.3 v6 s10.
On other news, pulled the tank and got it cleaned, I forgot to get pics, my dad might have some. Got the tank back in place and the bench seat back in. And My Dad forgot the steering wheel puller, I have to text him today and remind him.Going to work on the radio and speaker today, Gotta have tunes while im working.
