Old 11-21-2018, 06:21 PM   #101
lv2tri2
Re: 57 Short Box 235 5sp C4
Just found your truck today and I will follow your progress. Good decisions, IMO on everything so far.
lv2tri2 is offline   Reply With Quote
Old 11-23-2018, 09:38 PM   #102
svr
svr's Avatar
Got the cab back on the frame, next get it wired and fired.
57 short box, 235, T5, C4
http://67-72chevytrucks.com/vboard/s...d.php?t=739132
svr is offline   Reply With Quote
Old 02-04-2019, 10:01 PM   #103
BAM55
BAM55's Avatar
Really nice build and different too. I always like different. I really enjoy going through your build thread. Nothing like the first start with the engine installed. I was grinning ear to ear when I fired mine up for the first time.
BAM55 is offline   Reply With Quote
Old 02-05-2019, 12:46 AM   #104
svr
svr's Avatar
Bam thank you for your comments, WOW its been a while since i updated this thread. I'll get withit soon
Old 02-06-2019, 02:14 PM   #105
clegg
svr, I noticed on a few threads that you had used a key in steering column and shaved the ignition switch off of the column. How did you go about disabling the trans and steering locking?
I have an 80's tilt key in column and want to just use the in dash switch that I already have wired up.
clegg is offline   Reply With Quote
Old 02-06-2019, 08:04 PM   #106
svr
svr's Avatar
Clegg, evidently i didnt take any pics when i did that, at least i cant find any. What i did was dissaemble the column until could get the key cylinder out, all the guts that operate the ignition switch down on the column and the lock mechanism. I took the cone that held the key cylinder was in and cut the protrusion off until it was close to even. I made a plug from a piece of steel shaft to fill what was left of the hole the cylinder and glued it in with JB weld. From there it was grinding and finishing the cone and reassembly. Its been a couple yrs since i did that but thats what i remember. When i reassembled i replaced the bearings and the turn signal switch and lock tighted the screws that hold the tilt mechanism. If you have any more questions let me know.
Old 02-16-2019, 10:45 PM   #107
svr
svr's Avatar
Ok time to get caught up a bit. I found a nice small master cylinder reservour that i could mount on my firewall.
Old 02-16-2019, 10:59 PM   #108
svr
svr's Avatar
I bought a what was advertised a 55-59 22 circuit wireing harness. It didnt come with much for directions but at least all the wires were marked and color coded. I wasnt going with electric windows or locks so i had to sort out which wires i needed and which to pull out and sort them into groups to there end destinations. Lots of thinking rethinking reorganizing as i went about stringing the harness into place.
Old 02-16-2019, 11:07 PM   #109
svr
svr's Avatar
I bought some asphalt covered cloth wire loom and pulled the wires through rather than the split plastic loom.
Old 02-16-2019, 11:11 PM   #110
svr
svr's Avatar
Get everything hooked up and tested
Old 02-16-2019, 11:15 PM   #111
svr
svr's Avatar
Decided to put the battery behind the seat
Old 02-16-2019, 11:18 PM   #112
svr
svr's Avatar
Some killmat
Old 02-17-2019, 09:47 AM   #113
Black_Sheep
Black_Sheep's Avatar
Looking very good!
Black_Sheep is offline   Reply With Quote
Old 02-17-2019, 10:16 AM   #114
Kim57
Kim57's Avatar
Coming along nicely.
Battery behind the seat is interesting.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-17-2019, 02:13 PM   #115
svr
svr's Avatar
Decided to hange my doors and found a few issues i missed earlier in my haste, some problems are not caused by PO's, i cause some of my own.
Old 02-17-2019, 02:20 PM   #116
svr
svr's Avatar
When i did my Black Diesel 1 piece window mod i evidently got the window channels to far back and the latches would not fit flat like they should have. So i had to drill out the channel to relieve the knobs on the back of the latch.
Old 02-17-2019, 02:27 PM   #117
svr
svr's Avatar
Passenger door fit good, drivers not so much, outside profile not right.
Old 02-17-2019, 02:30 PM   #118
svr
svr's Avatar
Door had been damaged at some point in its life, inside wasnt right either
Old 02-17-2019, 02:36 PM   #119
svr
svr's Avatar
So a couple weeks set back to fix the door and hang the fenders to make sure all fit together right. Need to refinish some body work but maybe then be back on track.
Old 07-22-2019, 11:10 PM   #120
svr
svr's Avatar
Ok i been slacking off on up dates, pretty boring stuff, sand, prime, hammer, and again.
Old 07-22-2019, 11:11 PM   #121
svr
svr's Avatar
Another
Old 07-22-2019, 11:15 PM   #122
svr
svr's Avatar
Assembled the bed again after body work and 2k urethane primer, still needs lots of block and sanding before color.
Old 07-22-2019, 11:18 PM   #123
svr
svr's Avatar
Hood primed and color on the underside
Old 07-24-2019, 03:13 AM   #124
Nut Case
Nut Case's Avatar
SVR
Strong work, looking real good. What size / width / off set / back set do you have on the rims and what's the stats on the tires? They are looking great
How did you establish ride height using the C-4 vette suspension?
Thanks in advance, things are moving on your build, I'm jealous!
Keep on keepin on
Nutz
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 07-24-2019, 10:48 PM   #125
svr
svr's Avatar
Ok, on the ride height i am using the original corvette rear spring with 11”
Lowering bolts set at about 10”, i might let it down a bit more at some point. I set the upper shock mounts so regular ‘88 corvette shocks fit at this ride height. On the front i just set everything so the lower A arms are about level and am happy with that look. Right now front is held up by a couple pieces of square tube while im trying to figure out what spring rate to get for the coil overs for the front. The 235 is a heavy motor.
On the wheels and tires they are American Torq Thrust II Classic’s. Fronts are 17x8 with 225/50x17 on 8” rims if I remember correct about 4” back space. Rears are 17x9.5 with 285/40x17 on the 9.5” rims and i think back space was 5.5”. Thanks
