Old 10-14-2019, 09:31 PM   #101
Classic Bowties
Always on the hunt...
Re: F/S OE 72 Big Block Parts, Brackets, Stove Pipe, Air Cleaner, Towers and/or Reque
Here are the last two BBC fan shroud pics, we also have a matching OE BBC short water pump 19" six blade clutch fan available if needed. This fan was removed from an original 72 C/20 402 big block truck, the clutch is in real nice shape and has the large w/p bolt pattern. $100. Mel
Classic Bowties is offline   Reply With Quote
Old 10-15-2019, 12:27 PM   #102
GSFMECH
On the road
GSFMECH's Avatar
Mel, I do appreciate your honesty. I am still interested in it, it would be residential address and zip is 71457. Please be patient with me if I don't answer right away as I am working overseas on an offshore installation and communications can be probematic plus I am probably 11 hours ahead of West coast time. Many thanks
Mike
Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos
72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works.
My new build thread "Castro"
https://67-72chevytrucks.com/vboard/...d.php?t=820934
My old build thread, the blue truck
http://67-72chevytrucks.com/vboard/s...d.php?t=271489
www.louisianaclassictruckclub.com
GSFMECH is offline   Reply With Quote
Old 10-17-2019, 01:09 AM   #103
Classic Bowties
Hi Mike, shipping the big block shroud via fedex came in at $65.34 for residential/home delivery with a total transit time of four business days. The outer box dimensions are 32" x 24" x 6" @ 14 lbs. shipping from OR. Zip 97216 to LA. Zip 71457 if you wanted to check on any other quotes. Thanks, Mel
Old 10-17-2019, 10:44 PM   #104
GSFMECH
On the road
GSFMECH's Avatar
Mel I will take it all, PM sent
Mike
Old 10-18-2019, 12:02 AM   #105
AZ Chev
AZ Chev's Avatar
I’m looking for the upper AC bracket, the one on the manifold. Any chance you have that one?
AZ Chev is offline   Reply With Quote
Old 10-18-2019, 12:05 AM   #106
Classic Bowties
Mike, our info along with payment options have been returned via pm. Thanks, Mel
Old 10-18-2019, 09:46 AM   #107
Classic Bowties
Had a look this morning, we have the three below pictured rear of BBC A/C compressor brace/brackets for the intake manifold on hand/extra, all of them are OE pieces cast with p/n 3872726. If interested call out for the bracket of your choice, $75. shipped to your door via USPS priority. Thanks for the inquiry, Mel
Old 10-18-2019, 12:13 PM   #108
AZ Chev
AZ Chev's Avatar
I’ll take the middle one, please PM me your PP info, thanks.
Old 10-18-2019, 12:39 PM   #109
Classic Bowties
Our info for sending funds via paypal has been returned. Thanks, Mel
Old 10-18-2019, 12:58 PM   #110
AZ Chev
AZ Chev's Avatar
Payment Sent, thanks Mel.
Old 10-18-2019, 01:13 PM   #111
GSFMECH
On the road
GSFMECH's Avatar
Payment sent, thanks, Mike
Mike
Old 10-19-2019, 12:50 AM   #112
Classic Bowties
The BBC A/C intake manifold bracket (pictured center) has been shipped, your package went out via USPS priority on Fri. 10/18 and the expected delivery date is Mon. 10/21. Thanks again and let us know if we can help with anything else 67-72 related in the future, Mel
Hey Mike, funds received in full on the above pictured BBC shroud and clutch fan. Let me know when you are ready on your end for the shipment to be sent off, will get the package ready to go and we also still need an address confirmation. Thank you
Old 10-19-2019, 12:20 PM   #113
GSFMECH
On the road
GSFMECH's Avatar
Thanks Mel
Mike
Old 11-14-2019, 02:07 AM   #114
Classic Bowties
Thanks Mel
Hi Mike, hope your trip home was uneventful and went as planned. The big block fan shroud and clutch fan have been shipped out via FedEx home delivery on Wed. 11/13, as of this evening FedEx is projecting that you should see the box on Wed. 11/20 by the end of the day. Thanks again and let me know if we can help with anything else, Mel
Old 01-10-2020, 12:26 AM   #115
pg87starion
hello i am looking for the ac bracket that bolts to intake manifold as well as piece that attaches to it, the metal line for distributor advance and the throttle stop and bracket that attaches to the front of carb with single spade terminal that points straight out. all parts are for 72 model thanks phillip
pg87starion is offline   Reply With Quote
Old 01-10-2020, 11:46 PM   #116
Classic Bowties
Can check on these BBC items and update post in the morning, we should have the first three already pulled/stored on the shelf, one of them is pictured in above post #107. Will take a look let you know in the am, Mel
Old 01-13-2020, 02:24 PM   #117
pg87starion
just checking back thanks
Old 01-13-2020, 02:52 PM   #118
68Gold/white
Is any of the stuff in post still available???
68Gold/white is offline   Reply With Quote
Old 01-14-2020, 04:45 PM   #119
Eagle9502
Mel, sent you a PM about a carb spacer. Thanks.
Eagle9502 is offline   Reply With Quote
Old 01-14-2020, 06:21 PM   #120
Classic Bowties
If looking for BBC parts then yes, if you check first post you will see that the thread has been updated and multiples of these BBC parts have been added/sold over the last year plus. We decided to turn this one into a long running "request a BBC part" thread so that we don't have to have multiple threads for the same/like parts going at the same time and it also saves lots of room in our inbox storage as it cuts down on parts request pm's. Let me know which big block items you are looking for info on and we can add pics/pricing if parts are on hand. Thanks
Hello, just had a look back thru over two hundred messages and couldn't find anything from you on a carb spacer, if big block related just add requested parts info here and if we have it available I'll add it. Thanks, Mel
Old 01-14-2020, 06:51 PM   #121
Classic Bowties
Hello Phillip, here are the two requested BBC AC brackets and the BBC vacuum advance hard line w/hold down tab for your 72 big block truck, we are of no help on the q-jet idle solenoid and mounting bracket at this time. Cost is $125. on the pictured parts add $15. for shipping, forms of payment accepted will be check/money order or paypal + 3%. Thanks for the inquiry, Mel
Old 01-14-2020, 10:59 PM   #122
pg87starion
ill take them thank you
Old 01-15-2020, 10:06 AM   #123
Eagle9502
Mel, would you happen to have a carb spacer for the '68-69 396 engines with the "high rise" intake manifold? I believe the spacer for the earlier big block would've been shorter in height than '70-72. Also, how about the hard vacuum line for the earlier big block? My truck is a '68. Thanks.
Old 01-17-2020, 12:45 AM   #124
gregbr
Senoir Member
gregbr's Avatar
Thanks for all the great info & pictures listed here, they will help many of us with our BB projects. I've seen some pully numbers listed here for a 68 BB, but do you have the numbers for other years of 67-72? How about bracket numbers? Would be great to have a list of numbers for the brackets & pullies for SB & BB....never seen one. Thanks again!!
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 01-17-2020, 12:21 PM   #125
68Gold/white
OK, Do you still have the 68 air filter housing available, and would you have 68-396 exhaust manifolds, without the air injection holes???
THanks!
